bkoch1@wi.rr.com 2 #1 Posted June 4, 2022 I have a 1276 1966 i believe, intermittent trans leak from were the speed control lever goes in. I'm pretty sure its the o rings. New to me this year not sure if the ones in there were the right ones. 2 o rings looking for schematic or part number or info on what o rings to get to replace. Any help would be appreciated. My first post so if it should be done differently too let me know Thanks, Benny 2 Share this post Link to post Share on other sites
oliver2-44 11,663 #2 Posted June 4, 2022 @daveoman1966 or @pfrederi can probable help you out with that info 1 Share this post Link to post Share on other sites
daveoman1966 3,884 #3 Posted June 4, 2022 (edited) I presume you mean the leak is frm behind the Nylon cam... If so, there are 2 O-rings behind that may be bad. Circled here as items 63 & 64 (2) The part#s are listed in the lower left corner. You MAY be able top do the O-ring/seal replacement withthout separating the pump from the tractor, but the latter makes it so much easier. Here is a pic or two to access to the O-ring & Seal Edited June 4, 2022 by daveoman1966 1 2 Share this post Link to post Share on other sites
pfrederi 21,005 #5 Posted June 4, 2022 The O rings are #116 and 026 (I use 026S the square profile is easier to keep in place) PM your address i will mail you 2. 2 Share this post Link to post Share on other sites
bkoch1@wi.rr.com 2 #6 Posted June 5, 2022 On 6/4/2022 at 8:05 AM, pfrederi said: The O rings are #116 and 026 (I use 026S the square profile is easier to keep in place) PM your address i will mail you 2. Share this post Link to post Share on other sites
