Pullstart 66,635 #76 Posted August 5, 2022 On 8/2/2022 at 8:42 PM, wallfish said: I thought they stopped using shower head mufflers way before 64 Any of those pepper pot mufflers (spark arrestor) will look right. If you can deal with the tone and loudness of those things. Are shower heads any quieter? Share this post Link to post Share on other sites
ri702bill 9,348 #77 Posted August 5, 2022 5 minutes ago, Pullstart said: Are shower heads any quieter? I have one and took it off and put it away - Being a very short can and somewhat of a straight thru design, it gives off a rather annoying pop-pop-pop sound. Not mellow at all. I see the reason they did not last long in use - no baffle inside behind the dome - the exhaust flame cooks the front till it glows!! BUT - if you want a 100 point restoration, you need one... NOS ones are priced right up there with gold!! I use the pepper pot on the 7HP Kohlers and 5 HP Tecumseh, I use the larger coffee can style on the 8 HP 1 Share this post Link to post Share on other sites
Pullstart 66,635 #78 Posted August 5, 2022 27 minutes ago, ri702bill said: I have one and took it off and put it away - Being a very short can and somewhat of a straight thru design, it gives off a rather annoying pop-pop-pop sound. Not mellow at all. I see the reason they did not last long in use - no baffle inside behind the dome - the exhaust flame cooks the front till it glows!! BUT - if you want a 100 point restoration, you need one... NOS ones are priced right up there with gold!! I use the pepper pot on the 7HP Kohlers and 5 HP Tecumseh, I use the larger coffee can style on the 8 HP Well then last year, I bought a shower head and got a free RJ59 semi complete resto project and a handful of little Kohlers for free! Share this post Link to post Share on other sites
ri702bill 9,348 #79 Posted August 5, 2022 (edited) On 8/5/2022 at 8:40 AM, Pullstart said: a handful of little Kohlers for free! A litter of Wittle baby Kohlers - how cute!!! They make Great stocking stuffers!! Please post how much "fun" it is to work a "Nut Roaster" when it is done.. Edited August 18, 2022 by ri702bill 1 1 Share this post Link to post Share on other sites
dmoore 962 #80 Posted August 8, 2022 On 8/5/2022 at 8:12 AM, ri702bill said: I have one and took it off and put it away - Being a very short can and somewhat of a straight thru design, it gives off a rather annoying pop-pop-pop sound. Not mellow at all. I see the reason they did not last long in use - no baffle inside behind the dome - the exhaust flame cooks the front till it glows!! BUT - if you want a 100 point restoration, you need one... NOS ones are priced right up there with gold!! I use the pepper pot on the 7HP Kohlers and 5 HP Tecumseh, I use the larger coffee can style on the 8 HP So do you know of an an NOS piece??? Share this post Link to post Share on other sites
ri702bill 9,348 #81 Posted August 9, 2022 13 hours ago, dmoore said: So do you know of an an NOS piece??? Not at this time - P/N 234015 is NLA, discontinued a long way back ... Picture below for reference. 1 Share this post Link to post Share on other sites
dmoore 962 #82 Posted August 9, 2022 Maybe one will pop up...you never know. Thanks! Share this post Link to post Share on other sites
dmoore 962 #83 Posted August 11, 2022 On 8/5/2022 at 8:12 AM, ri702bill said: I have one and took it off and put it away - Being a very short can and somewhat of a straight thru design, it gives off a rather annoying pop-pop-pop sound. Not mellow at all. I see the reason they did not last long in use - no baffle inside behind the dome - the exhaust flame cooks the front till it glows!! BUT - if you want a 100 point restoration, you need one... NOS ones are priced right up there with gold!! I use the pepper pot on the 7HP Kohlers and 5 HP Tecumseh, I use the larger coffee can style on the 8 HP Bill who would you recommend to buy one from? Share this post Link to post Share on other sites
ri702bill 9,348 #84 Posted August 12, 2022 They show up time to time in the classifieds here - you may wish to post in thw Wanted Classifieds here that you are looking for a 1" version (there was a 3/4" version for the RJ's). Or, check with the folks in our Vendor section... It will be hard to find a usuable one and it will NOT be inexpensive..... 1 Share this post Link to post Share on other sites
dmoore 962 #85 Posted August 15, 2022 Gotcha. So who sells a close enough substitute that last a decent amount of time without burning out? Share this post Link to post Share on other sites
dmoore 962 #86 Posted August 16, 2022 I haven't had much time lately to finish up this 854 so tonight I snuck out to the garage and installed the key switch and all associated wiring. Then moved on to the steering shaft, bushing & wheel followed by choke & throttle cables. 5 Share this post Link to post Share on other sites
dmoore 962 #87 Posted August 16, 2022 (edited) I had bead blasted the hood over the weekend and started on smoothing it out some. Test fit it tonight. Little more work to do. Question, should the grill be in contact with the air cleaner housing? Edited August 16, 2022 by dmoore 1 Share this post Link to post Share on other sites
ineedanother 1,668 #88 Posted August 16, 2022 I've been watching your resto and it looks great. Motivational in fact. To answer your question...no. Others will likely chime in with NOE recommendations but air cleaner housings from what I have here are either 2" or 3" in depth. Yours looks to be 3" and a 2" should be stock with that hood and power plant. 1 Share this post Link to post Share on other sites
dmoore 962 #89 Posted August 16, 2022 And since I have convinced myself I will not find an original shower head muffler I ordered this genuine Kohler muffler off Ebay. At least it's made here. 2 Share this post Link to post Share on other sites
dmoore 962 #90 Posted August 16, 2022 2 minutes ago, ineedanother said: I've been watching your resto and it looks great. Motivational in fact. To answer your question...no. Others will likely chime in with NOE recommendations but air cleaner housings from what I have here are either 2" or 3" in depth. Yours looks to be 3" and a 2" should be stock with that hood and power plant. That's what I need to know. I thought as much. Thank you. 1 Share this post Link to post Share on other sites
Handy Don 13,980 #91 Posted August 16, 2022 (edited) 12 hours ago, ineedanother said: Tanswer your question...no. Others will likely chime in with NOE recommendations but air cleaner housings from what I have here are either 2" or 3" in depth. Yours looks to be 3" and a 2" should be stock with that hood and power plant. @dmoore Correct that the air cleaner housing should not contact the hood--but it will be mighty close! However, the 3" is correct for the 854 (the 2" can be fitted but will noticeably restrict airflow to the engine). To accommodate the extra length, 854's had a unique hood that is 1" longer than its sibling 500's and 700's. It measures 16" from the edge of the cut in front of the fuel tank to the seam. If yours is less than that, you don't have a 854 hood. You needn't ask how I (frustratingly) learned this. Edited August 16, 2022 by Handy Don 1 Share this post Link to post Share on other sites
dmoore 962 #92 Posted August 16, 2022 I thought that was the right air cleaner every other 854 I've seen has had the same one. Interesting tidbit on the 854 Hood only I will measure that. Share this post Link to post Share on other sites
Handy Don 13,980 #94 Posted August 16, 2022 4 hours ago, dmoore said: Mine is 2.5" Yours is correct. 3" is when measured from the face of the carburetor. This is an 854 hood in prep for painting. 1 Share this post Link to post Share on other sites
dmoore 962 #95 Posted August 17, 2022 I thought so. Thanks. I will take that measurement on mine. Share this post Link to post Share on other sites
dmoore 962 #96 Posted August 18, 2022 So tell me guy's, who makes a close match to the original chrome gas cap? Share this post Link to post Share on other sites
953 nut 59,784 #97 Posted August 18, 2022 17 minutes ago, dmoore said: So tell me guy's, who makes a close match to the original chrome gas cap? @Pullstart had a thread a while back where he found a chrome aftermarket gas cap for a C-10 Chevy pickup that was a great replacement, it is vented too I think. Share this post Link to post Share on other sites
Pullstart 66,635 #98 Posted August 18, 2022 I did have to modify the vent a little, just to make it work more freely. Share this post Link to post Share on other sites
dmoore 962 #99 Posted August 18, 2022 Thanks! I had a 21,000 mile 69 C20 truck in the shop a few weeks ago. I got looking at the s/s fuel cap and wondering if it would fit. It did. I just wasn't sure about the vent setup. Share this post Link to post Share on other sites
dmoore 962 #100 Posted August 18, 2022 (edited) Bad vid Edited August 18, 2022 by dmoore Share this post Link to post Share on other sites
