Mike C160 251 #1 Posted May 28, 2022 Greetings, What are you folks doing for cables? I have a choke cable on my C160 that is somehow too short. Really should be replaced. Many thanks in advance Cheers Share this post Link to post Share on other sites
SPINJIM 1,997 #2 Posted May 28, 2022 Ebay or Amazon. 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #3 Posted May 29, 2022 I personally recommend either of these: Don Share this post Link to post Share on other sites
peter lena 10,016 #4 Posted May 29, 2022 @ MIKE C160, https://www.zoro.com/super-lube-4-oz-hydraulic-oil-bottle-150-iso-viscosity-85w-sae- use this in those new cables to insure continuous smooth action , also take the time to et the cables be where they want to be, secure at smoothest movement point . makes a big difference. pete 2 1 Share this post Link to post Share on other sites
peter lena 10,016 #5 Posted May 29, 2022 @Snoopy11 , good pick on those cables , snoop, good back up , super lube , pete 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #6 Posted May 29, 2022 1 minute ago, peter lena said: super lube Excellent advice. Those new cables may not come with any type of lubricant... and you definitely don't want any corrosion getting in there!!! @peter lena Don 1 Share this post Link to post Share on other sites
Mike C160 251 #7 Posted May 29, 2022 @Snoopy11 So just cut the ends off and pinch them back onto the factory lever? Seems easy enough. I dont wish to ditch the factory lever system. 1 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #8 Posted May 29, 2022 3 minutes ago, Mike C160 said: So just cut the ends off and pinch them back onto the factory lever? Pretty much... yes. Again, I specifically recommend the last 2 cables that I mentioned, but buy what you wish... Don 1 Share this post Link to post Share on other sites
roadapples 6,987 #9 Posted May 29, 2022 1 hour ago, Mike C160 said: @Snoopy11 So just cut the ends off and pinch them back onto the factory lever? Seems easy enough. I dont wish to ditch the factory lever system. I got a universal cable at Lowes for about 8 bucks. Switched levers and cut to length.... 1 Share this post Link to post Share on other sites
peter lena 10,016 #10 Posted May 29, 2022 @Mike C160 , not to scare you , but have these springs added to my cable ends , springs gently pull cables / levers back to start point , also lubricate related movement areas . detail its function , thats what I did , strips of perforated , metal make good spring pull point , super lube , pete 1 Share this post Link to post Share on other sites
squonk 47,889 #11 Posted May 29, 2022 Z bend pliers make all the difference when making cables. 1 1 Share this post Link to post Share on other sites
Lagersolut 802 #12 Posted May 29, 2022 Last cable I replaced was the throttle on the 416-8 , original seized up over winter ....even after it was off the tractor I couldn't get it to move clamped in the vice ......ordered a universal on Flea Bay and a Z bend pliers off Amazon - cut to size - kept everything original minus the cable - although the newer replacement was a thinner gauge wire than the 37 year old one that was there it works great . +1 on that Z bend pliers @squonk posted above - exact one I picked up - for 19 bucks nice addition to the roll away makes easy work for the bends . 1 Share this post Link to post Share on other sites
