Mike C160 251 #1 Posted May 24, 2022 So, I have to remove this 1 inch nipple. Its too short. I have a early muffler in good condition i wish to install but this nipple is about 1/2 inch too short. The muffler wants to almost touch the points cover. Just too close. So does any one have a tip or two for removal? The sad part is i have no torches to heat it up with. Can this come out without heat? Cheers and thanks. 1 Share this post Link to post Share on other sites
adsm08 5,243 #2 Posted May 24, 2022 Try to tighten it a bit before attempting to remove. Last time I had the exhaust nipple out of my 855 I literally lifted the front wheels of the tractor off the ground by the pipe wrench trying to take it loose. Tightened it 1/4 turn and then it backed right out. 4 Share this post Link to post Share on other sites
WHX?? 58,347 #3 Posted May 24, 2022 I would cut the nipple from the inside down towards the threads of the block. Avoid going too far and not hitting the threads in the motor. Then collapse the nipple in on it self. Be careful if you use BF pipe wrenches... be real easy to squish that short a nipple making things worse. 4 1 Share this post Link to post Share on other sites
oliver2-44 11,816 #4 Posted May 24, 2022 1 hour ago, WHX?? said: I would cut the nipple from the inside down towards the threads of the block. Avoid going too far and not hitting the threads in the motor. Then collapse the nipple in on it self. Be careful if you use BF pipe wrenches... be real easy to squish that short a nipple making things worse. Cutting it in 2-3 places and crushing it is the way to go 5 1 Share this post Link to post Share on other sites
JoeM 10,318 #5 Posted May 24, 2022 I used a hacksaw blade by hand, takes a little time but works out. 5 2 Share this post Link to post Share on other sites
ebinmaine 81,139 #6 Posted May 24, 2022 3 hours ago, WHX?? said: I would cut the nipple from the inside down towards the threads of the block. Avoid going too far and not hitting the threads in the motor. Then collapse the nipple in on it self. Be careful if you use BF pipe wrenches... be real easy to squish that short a nipple making things worse. 2 hours ago, oliver2-44 said: Cutting it in 2-3 places and crushing it is the way to go Yepp. I do similar to the above pics but use a jig saw with a vacuum cleaner to remove any metal filings. Normally I'll cut the top. Use a fair sized punch to crush the pipe in on itself. Sometimes have to grab the leftovers with a vice grip and give em a healthy twist. 5 4 Share this post Link to post Share on other sites
wallfish 20,733 #7 Posted May 24, 2022 8 hours ago, Mike C160 said: The sad part is i have no torches to heat it up with Run the engine to heat it up and try backing it out. If that doesn't work then go the cut and fold route 3 1 Share this post Link to post Share on other sites
squonk 48,322 #8 Posted May 24, 2022 (edited) This nipple didn't look bad but a new elbow wouldn't start on it and it was marked up. Glad I changed it as it wasn't in very far and I found evidence a nipple had been cut out before. Just did this Saturday Stick a paper towel into the port. Leave the nipple long enough for a pipe wrench. Cut 2 slots just about through. Vacuum frequently. Pipe wrench will collapse nipple and it will either turn out or fall out. After removing paper towel. Vacuum out the hole. Then I used some large swabs with garb and brake cleaner to clean out the port. Edited May 24, 2022 by squonk 8 Share this post Link to post Share on other sites
stevasaurus 23,884 #9 Posted May 24, 2022 If you are not comfortable hacksawing a groove in the nipple, you do not have to. You can just cut the nipple off short (leave 1/4") and use a cold chisel and ball peen hammer to collapse the threads. Once you get it started, it will loosen and you can turn it out. Here is the proof. 5 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #10 Posted May 24, 2022 8 minutes ago, stevasaurus said: If you are no comfortable hacksawing groove in the nipple, you do not have to. My thoughts exactly. Many people probably wouldn't be comfortable doing that... perhaps... for good reason. Do what Steve says @Mike C160!!! Don 2 Share this post Link to post Share on other sites
stevasaurus 23,884 #11 Posted May 24, 2022 Buy 2 new nipples and use one to chase the threads in the head. Turn in a little and back out, use a light oil for cleaning. A lot cheaper then buying a pipe tap. 6 Share this post Link to post Share on other sites
squonk 48,322 #12 Posted May 24, 2022 A good dose of carb cleaner and then letting it soak a bit does wonders to loosen up the exhaust carbuncles in the threads. 6 Share this post Link to post Share on other sites
WHX?? 58,347 #13 Posted May 24, 2022 1 hour ago, stevasaurus said: Buy 2 new nipples and use one to chase the threads in the head. Better keep the hacksaw out and cut some kerfs in the other nipple.for thread chasing. Poor man's pipe tap. 2 1 Share this post Link to post Share on other sites
Mike C160 251 #14 Posted May 24, 2022 Wow, Lots of great responses. Back in the day some 30 year ago when i was a small engines tech in a rental company I remember we used to cut the sausage type exhaust off 5 horse briggs then use an air chisel to "cave in" the nipple in the block. Took only a few minutes. I can see similar logic applies here. Thanks for the tips. I didnt know if this was going to be and easy job or an ordeal Cheers and Thanks. I will report back later. 5 Share this post Link to post Share on other sites
stevasaurus 23,884 #15 Posted May 24, 2022 You are correct...only takes a couple of minutes. 2 Share this post Link to post Share on other sites
WHX?? 58,347 #16 Posted May 24, 2022 Yes let us know how it pans out. Obviously this PO did it but no ill effects on the block. I chased it with Dino's method before I procured taps and all was good. Might have to add this procedure to @953 nut s rites of passages. 1 Share this post Link to post Share on other sites
Moparfanforever 940 #17 Posted May 25, 2022 I use a medium size pipe wrench and a four foot long piece of pipe. Worked every time so far. 1 Share this post Link to post Share on other sites
squonk 48,322 #18 Posted May 26, 2022 For x-tra strength I like to use thicker wall schedule 80 black iron shoulder nipples. Here it is compared to a std nipple. 2 Share this post Link to post Share on other sites
Mike C160 251 #19 Posted May 26, 2022 Well, I finally got up the steam to get this one done. It was one of those jobs you walk a circle around of about 20 feet for a while as it seems like it was going to be an "ordeal" I am happy to say the cut and cave method worked great. I cut it open up to the block adapter then only a small slice in the hole. I didnt get into the threads of the block adapter. However the nipple was so brittle from age and heat, it collapsed without a fight at all and it pretty much fell right outta there. Its done. Phew. Wasnt the "ordeal" I thought it would be. 5 4 Share this post Link to post Share on other sites
WHX?? 58,347 #20 Posted May 27, 2022 Excellent Mike... yes one of those jobs I woulda had to sit and look awhile. Replacement looks A ok.. 2 Share this post Link to post Share on other sites
