Oldskool 6,678 #26 Posted April 6, 2022 I used Ford rotors with the outer disc cut off making it a drum. Then made band style brakes for it. Ford Ranger of Jeep Cherokee would be about the same. Also on my modified golf cart build I used a Ford Ranger rear axle with the small brake drums and WH rear wheels. Nice looking build so far. I'm really diggin it @jeepdan. Keep the pics and info coming. 3 2 Share this post Link to post Share on other sites
kpinnc 18,916 #27 Posted April 6, 2022 54 minutes ago, Handy Don said: I wonder if the disks/calipers now on downhill racing mountain bikes would be strong enough. They sure are compact. They are VERY strong for the size. They come in 6, 7, and 8 inch rotors. Hydraulics can be single or dual piston. They typically use mineral oil. Even though they have crazy stopping power, I doubt they are rugged enough for long-term abuse of these tractors. Just my $.02... 4 1 Share this post Link to post Share on other sites
Oldskool 6,678 #28 Posted April 6, 2022 Not sure if I missed it or not. Are you going to use E brake cable to operate the brakes or a cam lobe in place of the wheel cylinder.? Or twin master cylinder for hydraulic? 3 Share this post Link to post Share on other sites
Snoopy11 5,731 #29 Posted April 6, 2022 (edited) 19 minutes ago, Oldskool said: Also on my modified golf cart build I used a Ford Ranger rear axle with the small brake drums and WH rear wheels. Would you consider... either posting a picture here or PMing me one? I would absolutely love to see it!!! Also, would you mind sharing if it is a 7.5 inch rear end? Don Edited April 6, 2022 by Snoopy11 2 Share this post Link to post Share on other sites
Pullstart 71,160 #30 Posted April 6, 2022 32 minutes ago, Snoopy11 said: Would you consider... either posting a picture here or PMing me one? I would absolutely love to see it!!! Also, would you mind sharing if it is a 7.5 inch rear end? Don It!s in the link I posted ion page 1 I got to about where the turn brakes started. 1 Share this post Link to post Share on other sites
JoeM 10,189 #31 Posted April 6, 2022 I had a super cub with manual disc turning brakes, didn't see much difference. It would allow slight adjusts for guiding the machine without turning the wheel. The steering turning radius limited rear brake action for let r spin on a dime. If that is what you are going for?? Maybe a trike front end would allow it to turn like that. ??? 2 Share this post Link to post Share on other sites
roadapples 6,987 #32 Posted April 6, 2022 5 hours ago, jeepdan said: Here is a "teaser" photo. I will post more detailed info in the near future. Shouldn't need wheel weights... 3 Share this post Link to post Share on other sites
Oldskool 6,678 #33 Posted April 6, 2022 1 hour ago, Snoopy11 said: Would you consider... either posting a picture here or PMing me one? I would absolutely love to see it!!! Also, would you mind sharing if it is a 7.5 inch rear end? Don Yes it's the 7.5 rear. Which pics do you want? 1 1 Share this post Link to post Share on other sites
Oldskool 6,678 #34 Posted April 7, 2022 3 hours ago, Snoopy11 said: Would you consider... either posting a picture here or PMing me one? I would absolutely love to see it!!! Also, would you mind sharing if it is a 7.5 inch rear end? Don Pm'd you @Snoopy11 1 Share this post Link to post Share on other sites
jeepdan 337 #35 Posted April 9, 2022 Been working on brake linkages. The left side I'm very happy with, especially with keeping the factory parking brake system. Still haven't finalized what I'm going to do on the right yet. The drive belt is in the way to allow discrete routing of a rod. The rod for the right pedal may end up on top of the floorboard, but at least it will be inwards close to the belt guard. Will have to fabricate a cover over it. 4 3 Share this post Link to post Share on other sites
Snoopy11 5,731 #36 Posted April 9, 2022 (edited) 1 hour ago, jeepdan said: The rod for the right pedal may end up on top of the floorboard, but at least it will be inwards close to the belt guard. Will have to fabricate a cover over it I think it would look fine even without a cover. Just as a thought... what I wonder... is can you bend the rods to go under...? Is that possible? Would probably require heating the rods in the places that you want to bend. Don Edited April 9, 2022 by Snoopy11 3 Share this post Link to post Share on other sites
jeepdan 337 #37 Posted April 9, 2022 2 hours ago, Snoopy11 said: I think it would look fine even without a cover. Just as a thought... what I wonder... is can you bend the rods to go under...? Is that possible? Would probably require heating the rods in the places that you want to bend. Don Could be done with a cable. If I remember right, my 36"RD mower deck has bumpers that rest up against the underside of the floorboards. Need to investigate further. 2 Share this post Link to post Share on other sites
jeepdan 337 #38 Posted April 14, 2022 (edited) Almost have the pedals finished up. I think that the 3/8" rod passing over the foot board will be fine. Not going to make a cover for it at this time. Edited April 14, 2022 by jeepdan 1 7 Share this post Link to post Share on other sites
ebinmaine 80,461 #39 Posted April 14, 2022 1 hour ago, jeepdan said: pedals Can ya 'splain me how 'dis works?? I'm not seein' how the pedals are independent of each other. 1 Share this post Link to post Share on other sites
Pullstart 71,160 #40 Posted April 14, 2022 @ebinmaine there’s a lever that will likely rotate 100+ degrees inward that will unlock the brakes. During normal use, they’ll slow together. Unlocked, they are independent. It mirrors many large tractor pedal designs. 1 1 1 Share this post Link to post Share on other sites
ebinmaine 80,461 #41 Posted April 14, 2022 13 minutes ago, Pullstart said: @ebinmaine there’s a lever that will likely rotate 100+ degrees inward that will unlock the brakes. During normal use, they’ll slow together. Unlocked, they are independent. It mirrors many large tractor pedal designs. Only one I've ever seen up close is my 1949 Ferguson. That has a pedal on each side of the tractor for independent usage. 2 Share this post Link to post Share on other sites
jeepdan 337 #42 Posted April 14, 2022 (edited) 45 minutes ago, Pullstart said: @ebinmaine there’s a lever that will likely rotate 100+ degrees inward that will unlock the brakes. During normal use, they’ll slow together. Unlocked, they are independent. It mirrors many large tractor pedal designs. Correct. And, being a photo is worth a thousand words, here are two. Edited April 14, 2022 by jeepdan 2 7 Share this post Link to post Share on other sites
ebinmaine 80,461 #43 Posted April 14, 2022 I love it. I love it. I love it. I love it. 1 1 Share this post Link to post Share on other sites
Pullstart 71,160 #44 Posted April 14, 2022 @jeepdan it would be really cool if you could flip that lever from the seat… toe action? 2 Share this post Link to post Share on other sites
jeepdan 337 #45 Posted April 15, 2022 2 hours ago, Pullstart said: @jeepdan it would be really cool if you could flip that lever from the seat… toe action? Pretty sure that I can lean over and reach the lever with my fingers. My Kubota is set up the same way with the lever behind the pedals, and I can reach it fine from the seat. Toe action? Not for me as I'm a below the knee amputee. 1 1 Share this post Link to post Share on other sites
oliver2-44 11,716 #46 Posted April 15, 2022 On 4/6/2022 at 12:52 PM, Pullstart said: what about just one shoe instead of two, or turn the drum down and put a band around it? Panzer used one shoe and lever linkage on their narrowed dodge Plymouth rear ends 1 Share this post Link to post Share on other sites
sjoemie himself 3,180 #47 Posted April 15, 2022 7 hours ago, jeepdan said: Toe action? Not for me as I'm a below the knee amputee. It's no joke you lost your leg but still it made me laugh how dry you stated that fact. Hope I didn't offend you 2 Share this post Link to post Share on other sites
jeepdan 337 #48 Posted April 15, 2022 3 hours ago, sjoemie himself said: It's no joke you lost your leg but still it made me laugh how dry you stated that fact. Hope I didn't offend you Not offended at all. Guess that was a little funny. 1 1 Share this post Link to post Share on other sites
