prondzy 3,890 #1 Posted March 26, 2022 Well im 1 week in on my knee surgery. And bored out of my mind. Doc says at least 7 more weeks before i can return to work. I tore my Meniscus back at the end of January finally got in and stitched it up on Monday the 21st. Everythimg went well in surgery, Im glad to be headed in the right direction of healing now. Long slow painful process. Crutches, and driving restricitions and pain killers keep me planted in my chair most of the day. 2 2 12 Share this post Link to post Share on other sites
peter lena 10,076 #2 Posted March 26, 2022 @ proendzy , having had both of mine done , first thing I can recommend is to get off your butt and get to a rehab gym. usually a dr,s prescription will help in the cost . did they replace the entire knee? had mine done 6 months apart , dr I went to was the first to use the Mako robotic laser assist , and was very in your face about rehab , if you don't establish movement and use , thats what causes problems . found a hardwood floor and a roller Stoll was my go to at home , making you balance , and pull / push on the knee. went to the rehab gym regularly . they have trained therapists there for knees and shoulder activity . been over 6 years now , no issues . seriously , you should be on a rehab schedule , they will keep your range of movement active , pete 3 Share this post Link to post Share on other sites
squonk 48,141 #3 Posted March 26, 2022 You got a lot more hardware than me. All I got was a wrap on my knee. I had a sizable meniscus tear 2 years ago. Along with a plica tear. Workman's comp. Had to thru all the Crap as the MRI showed nothing so therapy, gel shot braces. My job required me to be low to the ground a lot I.E. working on kitchen equipment , roof top ac units ect. I couldn't kneel and they wouldn't disable me with out proof that there was a problem. Took 6 month's until the surgeon filed the paper work saying he must do exploratory surgery. 2 month's on WC disability. Then the doctor said He was taking me off disability and putting me on light duty. But my employer would not let me come back on LD so 4 month's of unemployment. Still can't kneel so I had to retire at 62. Going on 2 1/2 years and I still can't put weight on my knee when kneeling more the 10 minutes. Hop you have a better out come. I had my other knee done 10 years ago. Same thing but it turned out fine. but I think I have another tear in that one know too 1 4 Share this post Link to post Share on other sites
JoeM 10,294 #4 Posted March 26, 2022 Get well soon and stay out of the ice box! 1 1 2 Share this post Link to post Share on other sites
squonk 48,141 #5 Posted March 26, 2022 I had a walker left over from my back surgery the year before. i made good use of it. Hate crutches! 2 Share this post Link to post Share on other sites
prondzy 3,890 #6 Posted March 26, 2022 3 hours ago, peter lena said: @ proendzy , having had both of mine done , first thing I can recommend is to get off your butt and get to a rehab gym. usually a dr,s prescription will help in the cost . did they replace the entire knee? had mine done 6 months apart , dr I went to was the first to use the Mako robotic laser assist , and was very in your face about rehab , if you don't establish movement and use , thats what causes problems . found a hardwood floor and a roller Stoll was my go to at home , making you balance , and pull / push on the knee. went to the rehab gym regularly . they have trained therapists there for knees and shoulder activity . been over 6 years now , no issues . seriously , you should be on a rehab schedule , they will keep your range of movement active , pete Peter, rehab starts monday. It was a repair in the knee not a replacement. Leg brace is locked straight til the doc says otherwise, they dont want me tearing what they just stitched together. Cant put any pressure on that knee for a couple weeks for sure. Beleive me i want to get off my butt and cant wait for physical therapy to start. 3 1 Share this post Link to post Share on other sites
prondzy 3,890 #7 Posted March 26, 2022 3 hours ago, squonk said: You got a lot more hardware than me. All I got was a wrap on my knee. I had a sizable meniscus tear 2 years ago. Along with a plica tear. Workman's comp. Had to thru all the Crap as the MRI showed nothing so therapy, gel shot braces. My job required me to be low to the ground a lot I.E. working on kitchen equipment , roof top ac units ect. I couldn't kneel and they wouldn't disable me with out proof that there was a problem. Took 6 month's until the surgeon filed the paper work saying he must do exploratory surgery. 2 month's on WC disability. Then the doctor said He was taking me off disability and putting me on light duty. But my employer would not let me come back on LD so 4 month's of unemployment. Still can't kneel so I had to retire at 62. Going on 2 1/2 years and I still can't put weight on my knee when kneeling more the 10 minutes. Hop you have a better out come. I had my other knee done 10 years ago. Same thing but it turned out fine. but I think I have another tear in that one know too Kinda the same scenario here too. They usually fix this large tear with 4 stitches. Doc said he had to put in 8 stitches to get the job done. Same boat though. Worked up til the last day. Havent been able to kneel/squat bend my knee @90degrees or tighter since it happened. Hoping for a good outcome no arguing with the doc for me, want the best outcome 2 1 Share this post Link to post Share on other sites
squonk 48,141 #8 Posted March 26, 2022 Most of the time they just trim the torn piece out. Most of the meniscus in my left knee is gone now. At night my knee feels like it's in a vise. I was told the meniscus is usually only repaired if ligament repair is also needed. 1 Share this post Link to post Share on other sites
peter lena 10,076 #9 Posted March 26, 2022 @prondzy not making light of it , but a meniscus is a cake walk compared to a total knee . had the trimming , and the gel shots . also had the very dark grey xray shots , both were shot , had the first one done , kicked butt on that , 3 days in hospital to verify stability and zero infection . then a rehab facility for a week , then home . did the same thing again 6 months later , on the other knee, so I could bring them back just about together. you learn a lot in rehab , even then , I regularly asked , when the hell is this going to kick in ? you also learn how to stretch and hold your gain . glad your rehab starts soon , you can do it . get better , pete 1 Share this post Link to post Share on other sites
peter lena 10,076 #10 Posted March 26, 2022 @prondzy glad you mentioned kneeling , what you want to kneel on , YOU CAN DO THIS , get some boat seat foam cushion , its very dense , it totally supports your knee . the first time i used it , my pain fear was gone . check at a local boat supply house , they usually have bins of foam for seat make ups . once you try it , the total comfort support just feels wonderful. kick butt, pete 2 Share this post Link to post Share on other sites
prondzy 3,890 #11 Posted March 26, 2022 35 minutes ago, squonk said: Most of the time they just trim the torn piece out. Most of the meniscus in my left knee is gone now. At night my knee feels like it's in a vise. I was told the meniscus is usually only repaired if ligament repair is also needed. Doc said they used to cut it out and send you in your way they've figured out that causes Arthritis in that knee. They look at age and quality of life. And at 34 years old i need to get the most out of it i can. So repair it is. 3 Share this post Link to post Share on other sites
Pullstart 71,292 #12 Posted March 26, 2022 What did you do to tear it Mike? I’ve been spending quite a bit of time bending into engine compartments lately and the hyper extension on my left knee has been bugging me. 1 Share this post Link to post Share on other sites
squonk 48,141 #13 Posted March 26, 2022 My knee popped while kneeling on a 2" pad while wearing gel knee pads. Sounded like a gun going off. 1 1 Share this post Link to post Share on other sites
prondzy 3,890 #14 Posted March 27, 2022 39 minutes ago, Pullstart said: What did you do to tear it Mike? I’ve been spending quite a bit of time bending into engine compartments lately and the hyper extension on my left knee has been bugging me. 23 minutes ago, squonk said: My knee popped while kneeling on a 2" pad while wearing gel knee pads. Sounded like a gun going off. Was sitting side saddle on the floor working under the dash of a car. Shifted my weight to the left and stood in one motion from a fetal position. Same as sqounk. Biggest pop/snap I've ever heard in my life come out of the human body. In my right knee . Couldnt squat or kneel on it from that point forward. Had to bend over at the waist or lay on the floor do get work done down low. 1 1 Share this post Link to post Share on other sites
Pullstart 71,292 #15 Posted March 27, 2022 I got up from under the bumper of the last truck, with a twist and a side load on my left knee. It gave me a quick pop I wasn’t used too too. No more goofy loads on it. Until next weekend at least! I just booked a weekend skiing and snowboarding with my girls up north. Gotta keep ‘em moving! 1 Share this post Link to post Share on other sites
Achto 32,792 #16 Posted March 27, 2022 Take care of your self & listen to the doc Mike. Really hope it all heals up well. 1 1 Share this post Link to post Share on other sites
squonk 48,141 #17 Posted March 27, 2022 My doc told me I have the knee of a 20 yr old. I told him to give it back to him. I think he was trying to cover his butt. 2 Share this post Link to post Share on other sites
oliver2-44 11,758 #18 Posted March 27, 2022 Wishing you a fast recovery. Seems like a lot of us working guys have had knee issues. I tore my right meniscus when I was 20 crawling into a horizontal Clearwell tank hatch during power plant construction days.. Half in had to roll over to get on a ladder and it popped. It swelled up but went down and seemed OK for a year. Six weeks before my wedding It locked up and wouldn't bend. My wife just knew I would be going down the isle on crutches, but I rehabbed and got rid of them just in time. Dr went in with scope and cut it out, he was the lead Knee Dr for the UT football team. 1981 was early days of orthoscopic surgery. Thankfully not a huge tear. 2 Share this post Link to post Share on other sites
lynnmor 9,042 #19 Posted March 27, 2022 Two years ago I had both knees replaced six weeks apart, no fun. While you had a different surgery, it is important to closely follow the rehab instructions. The issue is that scar tissue builds up limiting range of motion, if that isn't pushed back the range will be limited. I hate taking pain killing dope, but if that is what it takes to keep the rehab going just make it happen. I wish you the best. 1 1 Share this post Link to post Share on other sites
WHX?? 58,198 #20 Posted March 27, 2022 Well the bright side Mike should be good to go for show season. Thing that would kill me is just sittin around and not being able to get out in the shop. 2 Share this post Link to post Share on other sites
peter lena 10,076 #21 Posted March 27, 2022 @prondzy , my latest rehab is on ROTATOR CUFFS , can't do the heavier angular stuff any more , installed screw in pull areas , in my sheds to use a gear chain pull assist . makes things much easier . the rotator rehab , is very precise and direct on the range of the shoulder joint area . basically heating , and reversing the pull point , with holding leverage . since I started , shoulders feel much better , and regularly use pull cord rollers and stretch straps , at direct angle areas. maybe some grease fittings and lucas grease ? only kidding . pete 1 Share this post Link to post Share on other sites
dclarke 4,274 #22 Posted March 27, 2022 Hate to hear this, Mike. Hang in there and keep us updated on your progress. 1 Share this post Link to post Share on other sites
Pullstart 71,292 #23 Posted March 27, 2022 1 hour ago, peter lena said: @prondzy , my latest rehab is on ROTATOR CUFFS , can't do the heavier angular stuff any more , installed screw in pull areas , in my sheds to use a gear chain pull assist . makes things much easier . the rotator rehab , is very precise and direct on the range of the shoulder joint area . basically heating , and reversing the pull point , with holding leverage . since I started , shoulders feel much better , and regularly use pull cord rollers and stretch straps , at direct angle areas. maybe some grease fittings and lucas grease ? only kidding . pete keep it greasy 2 Share this post Link to post Share on other sites
Terry M-(Moderator) 2,327 #24 Posted March 27, 2022 Hey Mike, I hope you heal up well and quickly! And like WHX kind of said… it’s better to be out of action now than during tractor show season. Take Care!! 1 Share this post Link to post Share on other sites
Tractorhead 9,217 #25 Posted March 27, 2022 23 hours ago, prondzy said: Well im 1 week in on my knee surgery. And bored out of my mind. Doc says at least 7 more weeks before i can return to work. I tore my Meniscus back at the end of January finally got in and stitched it up on Monday the 21st. Everythimg went well in surgery, Im glad to be headed in the right direction of healing now. Long slow painful process. Crutches, and driving restricitions and pain killers keep me planted in my chair most of the day. It‘s a long way to heal completeley, stepson has a knee surgery 2 years ago. killed his meniscus while soccer playing. it needs 3 months until he can use it as before. Prayers sent to you for a quick convalescents 1 Share this post Link to post Share on other sites
