ebinmaine 80,765 #1 Posted March 1, 2022 I put this in Non Tractor Related because it's really for a truck. Gas engine though so it could apply to Horses to some extent. Just wondering what high temp coatings you've used? Recommend? Do NOT recommend? I'm thinking of using a VHT High heat red. Rust-Oleum also makes one. Thoughts comments questions suggestions opinions... 1 Share this post Link to post Share on other sites
rmaynard 17,585 #2 Posted March 1, 2022 My opinion only...for oddball things like high heat paint, vinyl dyes, etc., VHT is the best. 3 2 1 Share this post Link to post Share on other sites
AMC RULES 37,259 #3 Posted March 1, 2022 Never been impressed with that VHT header paint. Have had good results with the Rustoleum black BBQ paint though. 5 Share this post Link to post Share on other sites
8ntruck 9,307 #4 Posted March 1, 2022 The high zoot high temp coating are the ceramics. Of course, those are not applyable at home. You might wander through the Jeggs speed supply catalog and see what they offer. 3 Share this post Link to post Share on other sites
ebinmaine 80,765 #5 Posted March 1, 2022 10 minutes ago, AMC RULES said: Never been impressed with that VHT header paint. Have had good results with the Rustoleum black BBQ paint though. We've used the Rust-Oleum flat black barbecue paint on several things and I agree that it seems to work well. The only real complaint I can find with the VHT FLAME PROOF online is kind of a big one. Surface preparation must be 100% perfect or it will peel flake burn fall off whatever... This particular usage is aimed at my exhaust manifolds on a straight six which are three cylinders each so they should fairly easily fit into my kitchen oven but unfortunately I don't think that's going to get hot enough to properly cure. Share this post Link to post Share on other sites
8ntruck 9,307 #6 Posted March 1, 2022 19 minutes ago, ebinmaine said: We've used the Rust-Oleum flat black barbecue paint on several things and I agree that it seems to work well. The only real complaint I can find with the VHT FLAME PROOF online is kind of a big one. Surface preparation must be 100% perfect or it will peel flake burn fall off whatever... This particular usage is aimed at my exhaust manifolds on a straight six which are three cylinders each so they should fairly easily fit into my kitchen oven but unfortunately I don't think that's going to get hot enough to properly cure. Look through the Eastwood catalog too. They offer several high temp exhaust manifold finishes. 1 1 Share this post Link to post Share on other sites
JCM 11,417 #7 Posted March 1, 2022 Maybe the newer formula or something has changed. From 1977- 1999 I used VHT on the factory 396/402 cast iron manifolds and then on a new set of Hooker headers for years and never had a problem. Don't remember how I prepped either. 3 1 Share this post Link to post Share on other sites
ebinmaine 80,765 #8 Posted March 1, 2022 8 minutes ago, JCM said: cast iron manifolds headers . Don't remember how I prepped either. If the car beast was running it's likely you followed the "on engine" directions. The VHT is fairly easy to heat cure on a running engine. I might not have that advantage in this case depending on what stage the project is in. 1 Share this post Link to post Share on other sites
953 nut 69,551 #9 Posted March 2, 2022 I have had great results with the Rust-Oleum 2000 degree paint. Sand blasted a rusty muffler and gave it two coats, next day I put it on the and ran it for twenty minutes like the label said. That was three years ago and it looks as good today as it did then. https://www.walmart.com/ip/Black-Rust-Oleum-Automotive-High-Heat-Protective-Enamel-Flat-Spray-Paint-12-Oz/17203457?wmlspartner=wlpa&selectedSellerId=0&&adid=22222222227000000000&wl0=&wl1=g&wl2=c&wl3=42423897272&wl4=pla-51320962143&wl5=9020677&wl6=&wl7=&wl8=&wl9=pla&wl10=8175035&wl11=online&wl12=17203457&veh=sem&gclid=CjwKCAiApfeQBhAUEiwA7K_UH45is8ubH2-sSHFtSWT8VMA23XFQmDXup0Ca_k1-eLCCP2lxbia-NhoC34MQAvD_BwE&gclsrc=aw.ds 2 1 Share this post Link to post Share on other sites
Moparfanforever 938 #10 Posted March 5, 2022 I painted these three mufflers with VHT cast iron paint. A little goes along way and I have had a single can for quite awhile. It does darken the more you use the tractor. 3 Share this post Link to post Share on other sites
Ifixoldjunk 778 #11 Posted March 6, 2022 I used rust oleum high heat grill/stove paint. Multiple thin coats seems the way to do it. Scratches very easily even while dry but holds up to heat well. 1 Share this post Link to post Share on other sites
