Snoopy11 5,731 #26 Posted January 19, 2022 1 minute ago, TJ Salyers said: I looked at the Firestone tires bout died Yes, and that is "per tire" Don 1 Share this post Link to post Share on other sites
TJ5208 1,841 #27 Posted January 19, 2022 They look like good tires 2 Share this post Link to post Share on other sites
TJ5208 1,841 #28 Posted January 19, 2022 @Achto can you jump in and give us you opinion about your ags. Share this post Link to post Share on other sites
TJ5208 1,841 #29 Posted January 19, 2022 And also i love my new avatar Share this post Link to post Share on other sites
Snoopy11 5,731 #30 Posted January 19, 2022 3 minutes ago, TJ Salyers said: They look like good tires Yes, but unless you feel the need to buy something that expensive... it really isn't necessary... 169$ for set... Here are some from Greater Cleveland Tire https://www.ebay.com/itm/393744356165?hash=item5bacfe1345:g:~DgAAOSwmAxhpO1v And finally: https://www.ebay.com/itm/303362340510?epid=27007204101&hash=item46a1cdf69e:g:4b4AAOSwKhpd6bva Don 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #31 Posted January 19, 2022 1 minute ago, TJ Salyers said: @Achto can you jump in and give us you opinion about your ags. And @Maxwell-8... @ebinmaine... @Pullstart... and... ...I guess...@Jeff-C175... Don 1 1 Share this post Link to post Share on other sites
Roger R 473 #32 Posted January 19, 2022 23-10.50-12, Front weight is essential for steering control, the roller chain works great, but can damage pavement. It is hard enough to scratch concrete. 6 Share this post Link to post Share on other sites
Snoopy11 5,731 #33 Posted January 19, 2022 2 minutes ago, Roger R said: 23-10.50-12 Looks pretty there @Roger R Don 1 Share this post Link to post Share on other sites
TJ5208 1,841 #34 Posted January 19, 2022 Here were i would buy mine i wanna go thin because more traction then if I go wide I can stick more weight in them opinions. Share this post Link to post Share on other sites
TJ5208 1,841 #35 Posted January 19, 2022 And then the tri ribs 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #36 Posted January 19, 2022 (edited) 2 minutes ago, TJ Salyers said: tri ribs I will give my opinion on those. NOT ENOUGH BITE. I tried some from Tractor supply... and ended-up taking them back... Front end slides around a bit too much for my taste. Just my opinion, others can disagree. I think, for the purposes you want to use this tractor for, and in our terrain in Indiana, you will not like tri ribs at all... Don Edited January 19, 2022 by Snoopy11 typo 1 Share this post Link to post Share on other sites
TJ5208 1,841 #37 Posted January 19, 2022 Well i am planning on getting four fourty pound suitcase weights on the front @Snoopy11 what tires do you recommend 1 Share this post Link to post Share on other sites
TJ5208 1,841 #38 Posted January 19, 2022 I'm also gonna fill the tool box under the seat with weights Share this post Link to post Share on other sites
TJ5208 1,841 #39 Posted January 19, 2022 Im hoping the guy will get back to me on the Raider 12 this is what I was planning on doing Share this post Link to post Share on other sites
Snoopy11 5,731 #40 Posted January 19, 2022 1 minute ago, TJ Salyers said: Well i am planning on getting four fourty pound suitcase weights on the front @Snoopy11 what tires do you recommend What size are you needing for the front? 4.80x4.00-8...? Don 1 Share this post Link to post Share on other sites
TJ5208 1,841 #41 Posted January 19, 2022 Yep im not going wide my 800 had 16 6 50 8 tire up front wouldn't steer in mud or snow I played with the air pressure still wouldn't steer 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #42 Posted January 19, 2022 3 minutes ago, TJ Salyers said: Yep im not going wide my 800 had 16 6 50 8 tire up front wouldn't steer in mud or snow I played with the air pressure still wouldn't steer If you want it to steer... then go with something like this: https://www.ebay.com/itm/Two-New-4-00-8-Deestone-D402-Lug-Heavy-Duty-Tiller-Tires-Garden-Tractor-Tires-/252199642770 Don 1 Share this post Link to post Share on other sites
Achto 32,095 #43 Posted January 19, 2022 9 hours ago, Mickwhitt said: I was going to buy a pair of new rims and tyres to ballast and fit for snow work. Thought's anyone? I have these on the front of my snow pusher. They seem to do a great job. https://www.amazon.com/Carlisle-Trac-ATV-Bias-Tire/dp/B001THCJDO 1 Share this post Link to post Share on other sites
Achto 32,095 #44 Posted January 19, 2022 34 minutes ago, TJ Salyers said: can you jump in and give us you opinion about your ags. Best gripping tires are going to be the 23degree tread on the Firestone's. Carlisle True Power's running second. The DeeStones are the best bang for the buck but they tend to run small. A 10.50 wide DeeStone is more on the lines of a 9.50. 2 1 Share this post Link to post Share on other sites
sjoemie himself 3,117 #45 Posted January 19, 2022 44 minutes ago, TJ Salyers said: bout died 😂 Yeah that.. they are nice but also cost an arm and a leg. 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #46 Posted January 19, 2022 Just now, Achto said: I have these on the front of my snow pusher. They seem to do a great job. https://www.amazon.com/Carlisle-Trac-ATV-Bias-Tire/dp/B001THCJDO Yeah, I think the tri-ribs are for different terrain than Indiana... for sure. For cost purposes, you could go with something like this... but expect... no traction... Don Share this post Link to post Share on other sites
Maxwell-8 4,371 #47 Posted January 19, 2022 (edited) Deestone run very small. But those in 10.5 would fit perfect on a stock 7" wide rim I would say go for the Charlsie thru power! @Achto beat me to it haha Edited January 19, 2022 by Maxwell-8 2 Share this post Link to post Share on other sites
Snoopy11 5,731 #48 Posted January 19, 2022 3 minutes ago, Maxwell-8 said: 0.5 would fit perfect on a stock 7" wide rim The problem I have found is that... with every size you go up... you pay considerably more... I was going to go up in size on my recent project... but when I saw that I would have to pay $75+ more... I decided to stay with stock size... Don Share this post Link to post Share on other sites
ebinmaine 79,685 #49 Posted January 19, 2022 6 minutes ago, Achto said: Best gripping tires are going to be the 23degree tread on the Firestone's. Carlisle True Power's running second. The DeeStones are the best bang for the buck but they tend to run small. A 10.50 wide DeeStone is more on the lines of a 9.50. I'll second this. I don't have direct experience with the Firestones because I'm too cheap. 😂 I do have Carlisle Tru Power with the Carlisle Rim Guard (two words). It's a rim edge protector lip built in to the tire. I do NOT recommend the Deestones at the rear unless you seriously overcompensate for the VERY SMALL size. I also will throw in another vote for the front tires getting the roller chains. 2 Share this post Link to post Share on other sites
Jeff-C175 7,209 #50 Posted January 19, 2022 46 minutes ago, Snoopy11 said: ...I guess...@Je Hain't got no Ags! Tri-ribs on the front of the 125, but Turfs everywhere else. 2 Share this post Link to post Share on other sites
