ebinmaine 72,503 #26 Posted December 23, 2021 1 minute ago, Retierd Wrencher said: Eric. Do they look like this less the rubber bushing set up? These are for the next generation of tanks. The plastic tanks. Share this post Link to post Share on other sites
ebinmaine 72,503 #27 Posted December 23, 2021 11 minutes ago, Retierd Wrencher said: Yes but I thought they were out of stock. Non rubber bushing type. Can you send a picture of it? This is what was original I keep these in stock: I like the single lever quarter turn action much much better. 1 Share this post Link to post Share on other sites
Retired Wrencher 5,770 #28 Posted December 23, 2021 27 minutes ago, ebinmaine said: These are for the next generation of tanks. The plastic tanks. Yes Eric but they look just like this less the rubber set up. I have had many Start Gen in the past. Far as I can see they do not make them anymore. Share this post Link to post Share on other sites
ebinmaine 72,503 #29 Posted December 23, 2021 1 minute ago, Retierd Wrencher said: Yes Eric but they look just like this less the rubber set up. I have had many Start Gen in the past. Far as I can see they do not make them anymore. 30 minutes ago, ebinmaine said: This is what was original I keep these in stock: I like the single lever quarter turn action much much better. They're still readily available Gary. Lots of machines take them. They're what's known as a Standard Part. Share this post Link to post Share on other sites
ebinmaine 72,503 #30 Posted December 23, 2021 My apologies for the double post back there. My phone is being a bit tad little cranky today and I wanted to make sure it went through.. Share this post Link to post Share on other sites
squonk 43,759 #31 Posted December 23, 2021 12 minutes ago, ebinmaine said: My apologies for the double post back there. My phone is being a bit tad little cranky today and I wanted to make sure it went through.. You've probably worn it out! 3 Share this post Link to post Share on other sites
ebinmaine 72,503 #32 Posted December 23, 2021 4 minutes ago, squonk said: You've probably worn it out! This is a legit possibility Share this post Link to post Share on other sites
Retired Wrencher 5,770 #33 Posted December 23, 2021 37 minutes ago, ebinmaine said: They're still readily available Gary. Lots of machines take them. They're what's known as a Standard Part. Nice debate going on here Eric. But what I have seen in the past it was the other type. The 65`s and earlier where the clear bowl type. What a pain in the but those where install under the dash. Share this post Link to post Share on other sites
ebinmaine 72,503 #34 Posted December 23, 2021 3 minutes ago, Retierd Wrencher said: clear bowl type Oh oh oh oh oh oh oh. Okay. I thought you were just talking about the valve itself. Sediment bowls are available for farm tractors and they were the same type. They too, are on the internet.... Just have to know what inlet and outlet configuration you need. Share this post Link to post Share on other sites
D_Mac 9,302 #35 Posted December 23, 2021 I just recently bought a new sediment bowl set up. Then I came to my senses and decided not to use it. I ordered a 90 degree elbow and was going to use a shut off before the filter. Where do you order those @ebinmaine? I'd like to get a couple. 2 Share this post Link to post Share on other sites
Retired Wrencher 5,770 #36 Posted December 23, 2021 9 minutes ago, ebinmaine said: Oh oh oh oh oh oh oh. Okay. I thought you were just talking about the valve itself. Sediment bowls are available for farm tractors and they were the same type. They too, are on the internet.... Just have to know what inlet and outlet configuration you need. I was. From I understand it look like the bushing type with a screw in with filter attached. I have had original rusted set ups that had this shut off. Share this post Link to post Share on other sites
Retired Wrencher 5,770 #37 Posted December 23, 2021 1 minute ago, D_Mac said: I just recently bought a new sediment bowl set up. Then I came to my senses and decided not to use it. I ordered a 90 degree elbow and was going to use a shut off before the filter. Where do you order those @ebinmaine? I'd like to get a couple. Most auto part stores carry them. But I think there cheaper than what Eric has. I tried two and they all leaked. Share this post Link to post Share on other sites
ebinmaine 72,503 #38 Posted December 23, 2021 3 minutes ago, D_Mac said: I just recently bought a new sediment bowl set up. Then I came to my senses and decided not to use it. I ordered a 90 degree elbow and was going to use a shut off before the filter. Where do you order those @ebinmaine? I'd like to get a couple. I'll send you a link to the eBay listing via pm. @squonk may have a source as well. Share this post Link to post Share on other sites
ebinmaine 72,503 #39 Posted December 23, 2021 2 minutes ago, Retierd Wrencher said: Most auto part stores carry them. But I think there cheaper than what Eric has. I tried two and they all leaked. I ordered some online that were like the first picture I showed and I had to tighten up the nut on all of them. They weren't properly secured. Gary, try Steiner tractor for that sediment bowl. 1 Share this post Link to post Share on other sites
squonk 43,759 #40 Posted December 23, 2021 You can get sediment bowls at any farm store or even Napa. They look cool but sediment bowls are French for GAS LEAK! Share this post Link to post Share on other sites
D_Mac 9,302 #41 Posted December 23, 2021 (edited) Thanks Eric. Just put my order in. Might have to paint the tank now that I have to remove it. So it could be a spring project. Any recommendations on gas tank paint? Edited December 23, 2021 by D_Mac Share this post Link to post Share on other sites
rjg854 12,175 #43 Posted December 23, 2021 2 minutes ago, squonk said: Red. Rustoleum Share this post Link to post Share on other sites
Retired Wrencher 5,770 #44 Posted December 23, 2021 2 hours ago, Retierd Wrencher said: Eric. Do they look like this less the rubber bushing set up? Share this post Link to post Share on other sites
Retired Wrencher 5,770 #45 Posted December 23, 2021 Just now, Retierd Wrencher said: Eric this is what looked like originally from the 68 parts manual. Share this post Link to post Share on other sites
Retired Wrencher 5,770 #46 Posted December 23, 2021 Just now, Retierd Wrencher said: Eric this is what looked like originally from the 68 parts manual. As you can see it looks a lot like the bushing type. Share this post Link to post Share on other sites
ebinmaine 72,503 #47 Posted December 23, 2021 3 hours ago, Retierd Wrencher said: Eric this is what looked like originally from the 68 parts manual. Yessir. That's this one: Only difference is the shape of the knob. The round knob is available. Share this post Link to post Share on other sites
Jeff-C175 7,206 #48 Posted December 23, 2021 4 hours ago, squonk said: Red. 4 hours ago, rjg854 said: Rustoleum Regal. 1 Share this post Link to post Share on other sites
WHX?? 51,729 #49 Posted December 23, 2021 Rotary one here Wrencher real original and can't beat the price. https://www.ebay.com/itm/373118387419 Truth be told & I wasn't such an original fruitcake I like your setup better. Just so much easier to operate than me getting my big clubs under the tank. 1 Share this post Link to post Share on other sites
ebinmaine 72,503 #50 Posted December 23, 2021 5 minutes ago, WHX?? said: Rotary one here Wrencher real original and can't beat the price. https://www.ebay.com/itm/373118387419 Truth be told & I wasn't such an original fruitcake I like your setup better. Just so much easier to operate than me getting my big clubs under the tank. Absolutely agreed. Not the easiest place to stuff my big meat hands. 1 Share this post Link to post Share on other sites
