hounddoghundzsa
Redline Trailer brake controller questions
hounddoghundzsa
I'm hoping someone can help me out with this before the show, or I might have to leave the horses at home. :thumbs2: I just installed a redline trailer brake controller (model TA-1000) on my 01 Ford Ranger. It had for wires: 1 trailer wire 2 brake light switch 3 hot lead 4 ground. I spent extra time soldering all connections and tested the hot wire going to the controller (which does have juice) but it isn't illuminating the "function light" or actuating the trailer brakes. Could the unit be faulty? Or, is there some other way to trouble shoot? The manual says that if the trailer is not hooked up the light will either glow red or not come at all. But with the trailer hooked up, the manual slide won't even do anything. By the way, I have a 3500# dexter axle if that makes a difference or not.
Thanks!
hounddoghundzsa
I just watched an install video on youtube for a podigy brake contoller and they're saying that the wire coming up from the plug needs to go to the positive post on the battery, If that's the case, than what hooks up to the blue wire (trailer brakes) on the contoller?
Nick
The blue wire runs from the controller all the way back to the trailer plug.
Did you wire the controller like the manual states? Should ran the hot lead through a circuit breaker to the positive side of battery, the ground works best run all the way to the battery negative, the brake light wire normally goes to the side of the brake switch that has power when the brake pedal is pressed.
http://redline-parts.com/WiringDiagram.pdf
Nick
This might be silly question but does your trailer have brakes? Most single axle trailers with 3,500 pound axles dont have brakes unless its an added option or a higher end trailer.
HorseFixer
Nick gave you a good diagram. mine has a Single Dexter Axel also and has brakes I have a Tekonsha Prodigy here is a 7 prong plug by bargman.
hounddoghundzsa
Yes, I wired it up exactly how the instructions said to. The only thing I did different was I put an inline fuse on the hot wire. As for the axle - I just put the axle on. I bought it new because I bent two of the cheap ones hauling firewood. I decided to get one with brakes because I haul it with a Ranger.
Is there a way to bypass the controller to see if there is a problem with the brakes?
hounddoghundzsa
Yes, it is a higher end trailer - quality built in my driveway in Brady Lake, Ohio! :thumbs2:
Nick
I use an old battery or jumper box to test the brakes on my trailer. Just ground it to the trailer frame and then touch the brake wire to the battery, you should hear the brake magnet engage. Did you check the fuse you put in the controllers power line, maybe it blew?
Built or rebuilt several trailers in the driveway myself. :thumbs2:
hounddoghundzsa
I'll give it a try tonite, thanks nick!
HorseFixer
So howd ya turn out? :thumbs2: Get the prob solved? :thumbs:
hounddoghundzsa
The brakes on the trailer work fine, the controller is junk. I took it to the show anyhow, and needless to say I had the front brakes smoking a couple of times. :thumbs2: I was going to go back to the place I bought it from today, but they're closed for the weekend.
Nick
Sorry to hear your controller didnt work out but sounds like you still had a good show. :ychain:
The one year I hauled stuff to the show my trailer brakes were smoking in Maryland. Found out the brakes were installed wrong so I mentioned it to the dealer next time I saw him, just got a blank look back at me. :thumbs: When I had picked up that trailer he sent a kid out to be sure the breakaway wire was connected. Got home and found the battery box was empty so lot of good the breakaway was. :thumbs2:
HorseFixer
Sorry to hear that Scott! :thumbs2: Try A Tekonsha Prodigy!
Duke
hounddoghundzsa
Wanted to stick with an American company. If the replacement gives me a hassle, I might have to resort to other measures :thumbs2: .......
HorseFixer
TEKONSHA is a company based out of Tekonsha Mich. All There Brake Conrollers are made in the USA! :thumbs:
About the company
Tekonsha Engineering opened its doors in 1963 and at that time manufactured wooden steps for the Mobile Home Industry. In the mid 1960
hounddoghundzsa
TEKONSHA is a company based out of Tekonsha Mich. All There Brake Conrollers are made in the USA! :thumbs2:
The name sounded like a made in japen comany to me - I'll be sure to check them out.
Thanks
HorseFixer
Thanks
Scott ME TOO! I didn't know it until today when I researched it! Im sure they get some components from flim flong outfits but all and all from what I have heard and who I have talked to they are the best! The company is just east of me about 75 miles. Anyway I have two of them both Prodigy 3's and you cant beat them for all they do! I am very happy so far I have logged over 6k miles on em
Des Moines Iowa round trip 1200 miles
Marquette Mich round trip 1400 miles
2 trips to Big Show PA 2500 miles
A Bunch of Misc Short Trips 1000 miles
Total Miles On Horse Hauler With Tekonsha P-3 Controller 6100 miles Thats not a huge amount but I think thats a pretty good amount to try a product!! I have one on the 2001 chevy stabbin cabin RV and one on a 1998 Jeep Grand Cherokee.
Good Luck!
Duke
Duff
Just a wild azz guess here, but I'll bet Tekonsha is derived from a Native American language somewhere in the past..... :thumbs:
Duff :thumbs2:
Nick
I hadnt given it any thought but good Guess Duff. It is an Indian name.
"The area, which had long been the home of the Potawatomi Native American tribe, was given it's name, to commerate a honored Potawatomi Indian Chief, Tekonquasha"
