whtractors24 3,571 #1 Posted December 19, 2021 (edited) Original machines can be brought back to have a nice look . Over the years I’ve been known to have nos machines & over restored units .(They say wine is better with age ) well took me years to appreciate the patina look . With a lot of trial and error I’ve come up with a solution . I’m against putting mystery oil , motor oil , wd40 ,linseed oil as the chances of ever doing anything with the metal down the road is nearly impossible. I found a lubricant that preserves the metal and brings the color out that is body shop safe. I do try to leave them natural in most cases but if color is a bit dull I then use the lubricant . These pictures posted aren’t done just (still in progress ) . No sandpaper or wire brush used . lastly : How you get the tractor out if you want to buy it bad enough. From the second story of the barn. 😆 IMG_3044.MOV Edited December 19, 2021 by whtractors24 1 6 4 Share this post Link to post Share on other sites
Moparfanforever 938 #2 Posted December 19, 2021 Just gonna leave us hangin' , what lubricant do you use ?? Share this post Link to post Share on other sites
whtractors24 3,571 #3 Posted December 19, 2021 4 minutes ago, Moparfanforever said: Just gonna leave us hangin' , what lubricant do you use ?? that’s the last step 😉 . Have to do some rubbing first 1 Share this post Link to post Share on other sites
953 nut 69,159 #4 Posted December 20, 2021 Took nearly sixty years to get this much character, not about to mess it up! 4 2 1 2 Share this post Link to post Share on other sites
whtractors24 3,571 #5 Posted December 20, 2021 2 minutes ago, 953 nut said: Took nearly sixty years to get this much character, not about to mess it up! Don’t have to mess it up . There is a lot of red under that rust 😉 Share this post Link to post Share on other sites
953 nut 69,159 #6 Posted December 20, 2021 2 minutes ago, whtractors24 said: a lot of red under that rust Kohler used better paint than Wheel Horse. Have some paint on the engine tins. 2 Share this post Link to post Share on other sites
Moparfanforever 938 #7 Posted December 20, 2021 20 minutes ago, whtractors24 said: that’s the last step 😉 . Have to do some rubbing first LOL !!!! Share this post Link to post Share on other sites
8ntruck 9,296 #8 Posted December 20, 2021 How to get a tractor out of the 2nd story? Verrrry carefully. If there is enough structure over the tractor, you could use a come along or rope and block & tackle to lower it. If you were @Pullstart, you would pack your handy dandy fork lift along. You could build cribbing up to the 2nd floor, roll the tractor onto it, then very carefully, jack the tractor up slightly, remove a layer of cribbing, lower the tractor. Repeat until it is on the ground. Ramps, if you can find boards long enough to make a reasonable slope. Share this post Link to post Share on other sites
whtractors24 3,571 #9 Posted December 20, 2021 4 minutes ago, 8ntruck said: How to get a tractor out of the 2nd story? Verrrry carefully. If there is enough structure over the tractor, you could use a come along or rope and block & tackle to lower it. If you were @Pullstart, you would pack your handy dandy fork lift along. You could build cribbing up to the 2nd floor, roll the tractor onto it, then very carefully, jack the tractor up slightly, remove a layer of cribbing, lower the tractor. Repeat until it is on the ground. Ramps, if you can find boards long enough to make a reasonable slope. Carried it as there was no room then fork lifted it down 😆 1 Share this post Link to post Share on other sites
Pullstart 71,215 #10 Posted December 20, 2021 Ride it cowboy. 1 Share this post Link to post Share on other sites
Maxwell-8 4,371 #11 Posted December 20, 2021 Took me a while, as well to appreciate the patina look. the previous owner put oil on my raider before he got it stuck in a mudhole. 2 Share this post Link to post Share on other sites
peter lena 10,047 #12 Posted December 20, 2021 @whtractors24 while at the last ZAGREY FARM SHOW , was looking in amazement a ford son tracked / tractor , talked to the owner , I was asking about the incredible patinaed state if was in , very simply he said , rub it down with KEROSENE , no rust , lubricated finish , just looks like a time capsule , used a small hand pump gun to touch up tight spots . being a lubrication nut , could not have agreed more , pete 3 Share this post Link to post Share on other sites
Wheelhorse#1 1,996 #13 Posted December 20, 2021 15 hours ago, Moparfanforever said: Just gonna leave us hangin' , what lubricant do you use ?? Yea, what’s the big secret.Bet someone here has already thought of it. Boiled linseed oil works great too. I like my tractors just like my woman …ole natural!! 😆 3 Share this post Link to post Share on other sites
Raposo 532 #14 Posted December 20, 2021 Looks great Jason Share this post Link to post Share on other sites
D_Mac 9,339 #15 Posted December 20, 2021 I always just power wash them with some degreaser. Then after I clean every nook and cranny with a toothbrush I rub it all down with boiled linseed oil. On the 500 Special I only painted the wheels and the plow. Changed the seat.. The rest of it is all elbow grease. People think the paint won't come back but it will with some work. 4 4 Share this post Link to post Share on other sites
wh315-8 632 #16 Posted December 21, 2021 Talk about tough spots to get tractors from, how about this RJ35? So sad it is the model they used as advertising. 2 Share this post Link to post Share on other sites
Retired Wrencher 6,979 #17 Posted December 21, 2021 Jayson check out my post I just did only Marvel so far. Easy peasey color back no rubbing /buffing /sanding. Share this post Link to post Share on other sites
whtractors24 3,571 #18 Posted December 21, 2021 2 hours ago, wh315-8 said: Talk about tough spots to get tractors from, how about this RJ35? So sad it is the model they used as advertising. Contacted them long ago . Won’t take it down lol. 1 Share this post Link to post Share on other sites
slim67 2,825 #19 Posted December 21, 2021 On 12/20/2021 at 8:57 AM, peter lena said: @whtractors24 while at the last ZAGREY FARM SHOW , was looking in amazement a ford son tracked / tractor , talked to the owner , I was asking about the incredible patinaed state if was in , very simply he said , rub it down with KEROSENE , no rust , lubricated finish , just looks like a time capsule , used a small hand pump gun to touch up tight spots . being a lubrication nut , could not have agreed more , pete I remember my dad telling me that people used to add a little kerosene to the soap and water when washing a car. Then dry it to a nice shine. 1 1 Share this post Link to post Share on other sites
peter lena 10,047 #20 Posted December 22, 2021 @slim67 that would have made sense for the era , my fathers idea of a car wash was to , rub it down after it rained ! don't think I ever saw him actually soap and water wash it down, used to cover the hood in blankets in a shed in cold weather. good old days, pete 1 Share this post Link to post Share on other sites
peter lena 10,047 #21 Posted December 22, 2021 @D-MAC , think your example of an oil lubrication paint save is obvious , no matter what I have picked up , if you want to make it look alive and show it some love , a lubrication rub down is the way to go , go oily , pete 1 Share this post Link to post Share on other sites
