ri702bill 9,379 #1 Posted December 19, 2021 (edited) A tip of the WH hat to @peter lena for mentioning this in an earlier reply to a posting - this works well - what a difference. I noticed I had a LOT of lost motion - almost an inch - in the linkage when moving the pedal - almost 60 years of use and the metal - on - metal joint where the rod goes thru the cast iron pedal was pretty worn out. The 3/8 hole in the casting was egg shaped and the end of the rod was about 1/3 gone. I could have welded up the rod and machined it - but why? The same thing will happen again. Bought a 3 foot length of zinc coated steel rod, a 3/8 Heim Joint, and a 3/8" bronze flange bushing. Threaded the rod and bent it into shape; reamed the pedal pivot hole for a press fit with the bushing. Installed it using Pete's favorite green grease on the trunion threads and the pedal pivot bore. A machining note - cutting the 3/8-24 fine thread with a die for the rod end was not easy . I usually just chamfer the end as I would with a coarse thread, but the fine thread would not bite into the rod to get the first thread started. Had to use a trick I learned years ago - undercut the rod by about .020 diameter for the first 1/4" or so, leaving a chamfer at both ends - this acts like a pilot for the die - keeps it aligned square to the rod. Thread it to the length desired and cut off the pilot. Once assembled, I noticed the 3/8 oversized jamnut I chose hit the oil drain cap - back downstairs to open up a 5/16" hexnut in the lathe and rethread it to 3/8-16 - no more clearance issue. The best part of this is that an original rod still fits - if I could find a NOS one. Bill Edited December 20, 2021 by ri702bill 1 7 Share this post Link to post Share on other sites
ebinmaine 72,504 #2 Posted December 19, 2021 Excellent work there Sir. Gives me an idea of how to tighten up the directional rod on my plow.... Share this post Link to post Share on other sites
ri702bill 9,379 #3 Posted December 19, 2021 @ebinmaine Thanks - I may do just the same thing with my 48" angling rod in the spring - it is a true PIA to reattach the rod to the quadrant - not much room at all to get the cotter pin in and bent - might just weld up the hole and retap it or weld a nut plate inside .... would do a new zinc plated rod and 2 rod ends. Bill Share this post Link to post Share on other sites
ebinmaine 72,504 #4 Posted December 19, 2021 11 minutes ago, ri702bill said: @ebinmaine Thanks - I may do just the same thing with my 48" angling rod in the spring - it is a true PIA to reattach the rod to the quadrant - not much room at all to get the cotter pin in and bent - might just weld up the hole and retap it or weld a nut plate inside .... would do a new zinc plated rod and 2 rod ends. Bill I've been wanting to refresh my own quadrant and add the 2 middle range angle holes. While it is apart would be a great time to set up this modification. Share this post Link to post Share on other sites
ri702bill 9,379 #5 Posted December 19, 2021 Take your time adding the 2 mid position holes - it can be done with a hand drill with the quadrant in the vise - I did mine in the milling machine to assure the centerline height of the new holes matched the existing - and add a small chamfer lead-in to all the holes - makes for easier pin engagement. Bill 2 2 Share this post Link to post Share on other sites
peter lena 9,251 #6 Posted December 19, 2021 @ri702bill , nice job on that ! thought I was looking at my own work ! changed over to HEIM JOINTS years ago , just made sense ,to eliminate and rethread. Another thing I do is to , fine cutting nut over a course thread, for a HEIM CHANGE . end of pto lever rod , makes lever solid /smooth . also, have HEIMS om my dozer blade quadrant to lever control arm . try to find my picture . that quadrant lubrication detailing is vital for easy use. done that on my 2 blades , also set them up on milk crates , to check function and correct what ever else would enhance easy operation . glad to see that you have crossed over to the DARK SIDE to correct a problem area , have to warn you , that corrective mind set of " what if " ? will have you looking at a problem differently , like making that problem go away . stay at it , good work , pete 1 Share this post Link to post Share on other sites
peter lena 9,251 #7 Posted December 19, 2021 @ri702bill , snow blower chute knob, just made sense to me , grind taper start , die nut , pete Share this post Link to post Share on other sites
ebinmaine 72,504 #8 Posted December 19, 2021 56 minutes ago, ri702bill said: Take your time adding the 2 mid position holes - it can be done with a hand drill with the quadrant in the vise - I did mine in the milling machine to assure the centerline height of the new holes matched the existing - and add a small chamfer lead-in to all the holes - makes for easier pin engagement. Bill Excellent advice. Thank you. I like the chamfer idea. I'll ad that to the list. 2 Share this post Link to post Share on other sites
peter lena 9,251 #9 Posted December 19, 2021 @ebinmaine like that small chamfer enhancement to holes, as you know that quadrant area , is seldom looked at , loaded with rust and sloppy everything . thats what had me turn to , OPERATIONAL FUNCTION DETAIL , with raised plow and frame off floor on crates . roller stooling around and looking for issues , lead me to small firming up and lubrication detail . love the fact that when finished , your off the floor look at quadrant / lever ease / action , is exactly what you are putting on your tractor , road testing it before use , make it work with ease, from smooth easy lever release squeeze to effortless blade swing . realize this freaks out many , but thats what I do to correct a problem . go lucas, pete 1 Share this post Link to post Share on other sites
peter lena 9,251 #10 Posted December 19, 2021 @ri702bill improve pto lever action , bill , note top photo , washers to pto lever start point, obvious heim joints, battery tender plug in , makes it easy , and last , note cable going to engine corner / frame ? cable connects battery ground bolt on upper ground rail , for improved starting grounding , don,t get me started , pete 1 Share this post Link to post Share on other sites
