Wheelhorse#1 1,976 #1 Posted December 17, 2021 (edited) Anyone have any idea what these rubber bumpers are called ? They sit under the rear fender pan for vibration and cushion ,I recon. I need to replace them.Thx pic Edited December 17, 2021 by Wheelhorse#1 1 Share this post Link to post Share on other sites
Achto 32,510 #2 Posted December 17, 2021 Wheel horse part #5667 One source for them. https://wheelhorsepartsandmore.com/product/5667-toro-wheel-horse-grommet/ 5 1 Share this post Link to post Share on other sites
roadapples 6,987 #3 Posted December 17, 2021 They also go under the hood next to the hinge... 3 Share this post Link to post Share on other sites
ebinmaine 80,462 #4 Posted December 17, 2021 6 hours ago, roadapples said: They also go under the hood next to the hinge... On what models Mr Apples? Share this post Link to post Share on other sites
roadapples 6,987 #5 Posted December 17, 2021 Not sure all models, but there on my 74 C160... 1 1 Share this post Link to post Share on other sites
ebinmaine 80,462 #6 Posted December 17, 2021 4 minutes ago, roadapples said: Not sure all models, but there on my 74 C160... Don't think mine has any. Probably were worn right off before I got it. I'll have to check that out.... 2 Share this post Link to post Share on other sites
Wheelhorse#1 1,976 #7 Posted December 17, 2021 10 hours ago, Achto said: Wheel horse part #5667 One source for them. https://wheelhorsepartsandmore.com/product/5667-toro-wheel-horse-grommet/ Thank you ,much appreciated! 2 Share this post Link to post Share on other sites
peter lena 10,030 #8 Posted December 17, 2021 @Wheelhorse#1 put a smear of DIELECRTIC GREASE on that contact area , make things work easier , thats a super lube rated lubricant . good stuff, pete Share this post Link to post Share on other sites
kpinnc 18,916 #9 Posted December 17, 2021 1 hour ago, ebinmaine said: Don't think mine has any. Probably were worn right off before I got it. I'll have to check that out.... I think my 867 uses 2 of those on the fender. Sure makes it close smoother too! Share this post Link to post Share on other sites
Achto 32,510 #10 Posted December 17, 2021 11 minutes ago, kpinnc said: I think my 867 uses 2 of those on the fender It should have 4 of them on the rear fender. 2 where it sets on the center counsel and 2 on each side where it slides over the counsel. Number 101 on the diagram 2 1 Share this post Link to post Share on other sites
squonk 47,990 #11 Posted December 17, 2021 (edited) 2 hours ago, peter lena said: @Wheelhorse#1 put a smear of DIELECRTIC GREASE on that contact area , make things work easier , thats a super lube rated lubricant . good stuff, pete Since dielectric grease is a silicone grease, it should not be used on silicone-based rubbers or plastics, as it will break them down over time. The grease does not conduct electricity, so it shouldn't be applied directly to the mating surfaces (pins and sockets) of an electrical connection. Plus on the fender mounts it may end up on your pants! Edited December 17, 2021 by squonk 1 Share this post Link to post Share on other sites
stevasaurus 23,816 #12 Posted December 17, 2021 They are called "Do-Hicky's". 1 3 Share this post Link to post Share on other sites
ebinmaine 80,462 #13 Posted December 17, 2021 7 minutes ago, stevasaurus said: They are called "Do-Hicky's". I've called 'em "Rubber baby buggy bumpers" for many years. 2 Share this post Link to post Share on other sites
peter lena 10,030 #14 Posted December 17, 2021 @squonk so terribly sorry for suggesting anything , looking for a sword to throw my self on , probably put some grease on it to make the initial entry , easier , pete 2 Share this post Link to post Share on other sites
squonk 47,990 #15 Posted December 17, 2021 Just wanted to let folks know that that grease can damage certain rubbers. I used to use Vaseline to install pump seals. Made them slide into the bore easily. Until I found out that it broke down the rubber compound after a short time. 3 1 Share this post Link to post Share on other sites
peter lena 10,030 #16 Posted December 17, 2021 @squonk rebuilt hundreds of pumps , durco, goulds , boston gear , swiss lewa , never used vaseline on any of those seals , more like synthetic , hi temp anti sling , steam jacket rated , lubricant , also food grade rated , for production work. pete 1 Share this post Link to post Share on other sites
