ebinmaine 80,278 #1 Posted December 13, 2021 On Trina's 867 short frame tractor we've been using a plow and rear axle bracket that was originally on a long frame, 74 c160. I now have a plow frame for a short frame tractor and I'd like to use it on her 867. That would free up her existing frame for usage on one of my other long frame tractors. I understand that the early snow plows which were all short frames had a rear axle bracket that faced forward, not down, as the later models do. Will a short plow frame mount on a short frame tractor with a down-facing bracket? Or do I need to acquire/make a forward-facing bracket which will move the plow frame forward a couple inches? Share this post Link to post Share on other sites
Maxwell-8 4,371 #2 Posted December 13, 2021 I have sold 3 lf brackets, only once seen a snow plow, and its was a short frame. The mounting on the plow itself looked different. But I am not the expert so... Share this post Link to post Share on other sites
squonk 47,887 #3 Posted December 13, 2021 1 hour ago, ebinmaine said: On Trina's 867 short frame tractor we've been using a plow and rear axle bracket that was originally on a long frame, 74 c160. I now have a plow frame for a short frame tractor and I'd like to use it on her 867. That would free up her existing frame for usage on one of my other long frame tractors. I understand that the early snow plows which were all short frames had a rear axle bracket that faced forward, not down, as the later models do. Will a short plow frame mount on a short frame tractor with a down-facing bracket? Or do I need to acquire/make a forward-facing bracket which will move the plow frame forward a couple inches? It will but the angle handle will be in a different spot and the plow blade will be closer to the front tires. Take the bracket off and put it on the front of the transmission. No need to get another bracket. 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,138 #4 Posted December 13, 2021 I ran my C105 with this old short frame bracket for years. The mounting bolts run parallel to the ground…obviously blade not hooked to bracket in these old photos… Previous owner had rigged up and modified blade as well. Worked fine. Same blade also works with the correct bracket as well…which is what I use now… Share this post Link to post Share on other sites
ebinmaine 80,278 #5 Posted December 13, 2021 3 minutes ago, SylvanLakeWH said: short frame bracket Now ya see that's more like what I have on the C160. I built that though. I did it to be able to use a trailer hitch that's bolts the same direction. Is a stock WH made short frame bracket that low to the ground? I thought they were closer to axle centerline which is my concern... I figured the plow would be too close to the tractor frame. Share this post Link to post Share on other sites
SylvanLakeWH 32,138 #6 Posted December 13, 2021 It looks “stock” but who knows… it’s older than dirt and pretty rough… still works though… 1 Share this post Link to post Share on other sites
ri702bill 12,808 #7 Posted December 13, 2021 Eric: Yup, the angle iron crossbar hangs down just as shown. Same setup on Dad's 702 (retired from yardwork, but a great backup tractor). For what it is worth - you can swap out a 48" plow moldboard and angling rod with a 42", using the early 42" frame. Did that on the 854. 2 Share this post Link to post Share on other sites
ri702bill 12,808 #8 Posted December 13, 2021 @ebinmaine One more item - check your plow quadrant to see if it has either 3 (early style) or 5 holes (later style) - I added the 2 mid position pull pin holes to my early 3 hole unit - they are handy to have when you wish to push and have a bit of angle to roll snow off to the side.... Bill 1 Share this post Link to post Share on other sites
ri702bill 12,808 #9 Posted December 13, 2021 Here is a shot of the back of the 702 with its early plow mount... Share this post Link to post Share on other sites
ebinmaine 80,278 #10 Posted December 13, 2021 40 minutes ago, ri702bill said: @ebinmaine One more item - check your plow quadrant to see if it has either 3 (early style) or 5 holes (later style) - I added the 2 mid position pull pin holes to my early 3 hole unit - they are handy to have when you wish to push and have a bit of angle to roll snow off to the side.... Bill We have three or four of those plow quadrants laying around. All of ours are the early three hole style. One of the upgrades I want to do sometime soon is drill out that mid position hole. I agree it would be very handy. Share this post Link to post Share on other sites
squonk 47,887 #11 Posted December 13, 2021 The distance between the hooks on the older SF bracket is 11" The distance on the newer LF bracket is around 17". I have the 17" bracket on my 953 and 857. I have a LF plow on the 953 and a SF plow on the 857. The same 17" bracket will work on both plows. The LF bracket will attach the SF plow on the outside. The bar in back of the plow is the same length. 1 Share this post Link to post Share on other sites
