ebinmaine 79,297 #1 Posted December 1, 2021 Anybody use tiny brushes to clean the main jet bore on carbs? Can you recommend a set? Share this post Link to post Share on other sites
ZXT 2,402 #2 Posted December 1, 2021 Never used brushes but i've often wondered about it. Wonder if gun cleaning brushes would work? Would obviously want something that isn't too abrasive. Share this post Link to post Share on other sites
953 nut 66,861 #3 Posted December 1, 2021 All I've ever used is compressed air or an aerosol carb cleaner. 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #4 Posted December 1, 2021 I've got these... which I have about a dozen of... which I need because I never know where I put them... which leads me to buy more... which... has nothing to do with your topic... ANYHOO... From the jungle. Hifrom is the brand... Don 1 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #5 Posted December 1, 2021 Heck, might as well give a link... https://www.amazon.com/HIFROM-Carburetor-Cleaner-cleaning-Motorcycle/dp/B06XXSVGBW?th=1 Don 1 Share this post Link to post Share on other sites
953 nut 66,861 #6 Posted December 1, 2021 I don't think I would use torch tip cleaners on a soft brass jet bore, they may enlarge the bore. Don't care if someone on the jungle site calls them carb cleaners, they are tip cleaners and too abrasive to be used on a carb. 2 Share this post Link to post Share on other sites
ebinmaine 79,297 #7 Posted December 1, 2021 11 minutes ago, 953 nut said: All I've ever used is compressed air or an aerosol carb cleaner. Same here. I've had a couple carbs recently that needed to be cleaned more than once. I know that just .. happens. On both the main jet bore had some sh.. stuff that needed a little extra time to break free. I'm wondering if the effects of ethanol are becoming more prevalent or I just got lucky and found 2 super gunky carbs... Share this post Link to post Share on other sites
ebinmaine 79,297 #8 Posted December 1, 2021 1 minute ago, 953 nut said: I don't think I would use torch tip cleaners on a soft brass jet bore, they may enlarge the bore. Don't care if someone on the jungle site calls them carb cleaners, they are tip cleaners and too abrasive to be used on a carb. Maybe brass or nylon brushes? Share this post Link to post Share on other sites
WHX?? 57,047 #9 Posted December 1, 2021 I got round brushes we use for cleaning refrigeration fittings wonder if they would work. Squonky knows the one I'm talking about. They come in a bunch of different sizes but I would guess 1" and 1 1/4 sizes is what would be needed if your talking about cleaning the main bore. I can toss some in them that carb box you is gonna get some day. 1 1 Share this post Link to post Share on other sites
ebinmaine 79,297 #10 Posted December 1, 2021 2 minutes ago, WHX?? said: main bore. Jet bore Jimbo. Itty bitty. 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #11 Posted December 1, 2021 6 minutes ago, 953 nut said: I don't think I would use torch tip cleaners on a soft brass jet bore, they may enlarge the bore. Don't care if someone on the jungle site calls them carb cleaners, they are tip cleaners and too abrasive to be used on a carb. I would agree if you are going to dig around in the jet like Mr. Hyde giving a prostate examn... Don 1 Share this post Link to post Share on other sites
ZXT 2,402 #12 Posted December 1, 2021 13 minutes ago, 953 nut said: I don't think I would use torch tip cleaners on a soft brass jet bore, they may enlarge the bore. Don't care if someone on the jungle site calls them carb cleaners, they are tip cleaners and too abrasive to be used on a carb. Only time I use them is if there's something in there solid that I can't get out otherwise. If I do use it, I push it in and clear the blockage, and pull it out. Then use carb cleaner to clear out any other debris. 1 2 Share this post Link to post Share on other sites
Snoopy11 5,731 #13 Posted December 1, 2021 Just now, ZXT said: Only time I use them is if there's something in there solid that I can't get out otherwise. If I do use it, I push it in and clear the blockage, and pull it out. Then use carb cleaner to clear out any other debris. One the money there Jonah. Exactly! Don 1 1 Share this post Link to post Share on other sites
Handy Don 16,784 #14 Posted December 1, 2021 I've used a set that I got ages ago--can't remember where, but maybe it came with a rebuild kit? Obviously they don't go through the tiny jet orifaces for the idle feed and the pressure sensing channels, only the channel leading to them. Exception is the Tecumseh main jet which I can brush out completely. It has been helpful on seriously gunked carbs where I could get access (as evidenced by the gunk coming out on the brush) but I still rely on a small collection number sized wires for poking out the actual jet "pinholes". (I have a set of abrasive ones, too, for torches but those never see carbs). 2 Share this post Link to post Share on other sites
Brockport Bill 2,389 #15 Posted December 1, 2021 I'm new to the carb cleaning and repair or replace world - just a newbie, but i did recentlyorder a carb kit - and inside carton included a set of brushes ( see photo ) - have not used them. However, like others here - thus far I have just used cleaner spray or air - so curious to learn here about the brushes and how and when to use or not use? 2 Share this post Link to post Share on other sites
wallfish 20,092 #16 Posted December 1, 2021 53 minutes ago, Snoopy11 said: which I need because I never know where I put them. Yeah, those things hide like 10 mm sockets and the socks from the dryer. Good thing they're cheap! LoL I have a bunch of those for the same reason Never used any brushes either. Sometimes a tiny copper wire for the main jet needle holes. I need to get one of those ultra sonic cleaners 5 2 Share this post Link to post Share on other sites
ebinmaine 79,297 #17 Posted December 1, 2021 9 minutes ago, Brockport Bill said: curious to learn here about the brushes and how and when to use or not use? My own thought is to run a soft brush down the hole where the main jet is on the Kohler carbs I rebuild. I haven't tackled a Tecumseh carburetor as has @Handy Don. 1 Share this post Link to post Share on other sites
ebinmaine 79,297 #18 Posted December 1, 2021 3 minutes ago, wallfish said: socks Just quit wearing socks John. 2 Share this post Link to post Share on other sites
midpack 1,147 #19 Posted December 1, 2021 I haven't had any complaints with my sonic cleaner 2 Share this post Link to post Share on other sites
WHX?? 57,047 #20 Posted December 1, 2021 (edited) Buddy of mine and @Achto has got one of those ultrasonic thingamabobs from HF and likes it . Me thinks you are gonna be the next carb queen here EB! Edited December 1, 2021 by WHX?? 3 3 Share this post Link to post Share on other sites
ZXT 2,402 #21 Posted December 1, 2021 1 minute ago, WHX?? said: Buddy of mine and @Achto has got one of those ultrasonic thingamabobs from HF and likes it . Me thinks you are gonna be the next carb queen here EB! Use my HF Ultrasonic cleaner on carbs all the time! Love it. 4 Share this post Link to post Share on other sites
ebinmaine 79,297 #22 Posted December 1, 2021 6 minutes ago, ZXT said: HF Ultrasonic cleaner May haffta order one up .. Share this post Link to post Share on other sites
WHX?? 57,047 #23 Posted December 1, 2021 What do you use in it for solvent @ZXT? Share this post Link to post Share on other sites
ZXT 2,402 #24 Posted December 1, 2021 8 minutes ago, WHX?? said: What do you use in it for solvent @ZXT? Have used simple green, hot water/soap, evaporust.. all seem to work well. Evaporust is good if there's a lot of rust/stuck throttle shafts, but the simple green mixture seems to work well on standard cleaning jobs. I always make sure to use the heater though.. Heat does wonders for breaking stuff loose. 4 1 Share this post Link to post Share on other sites
oliver2-44 11,563 #25 Posted December 1, 2021 (edited) 1 hour ago, wallfish said: I need to get one of those ultra sonic cleaners Santa brought me an ultra sonic cleaner last Christmas. (I got caught with small carb parts in Mrs Santa’s jewelry cleaner, that she never uses). A nice larger 3liter one that Walmart Carrie’s online. It’s amazing how much gunk is in the bottom of it after putting a carb that I had previously “cleaned” in it. I’ve been using it for all kinds of things. Edited December 1, 2021 by oliver2-44 6 1 Share this post Link to post Share on other sites
