ebinmaine 80,113 #26 Posted November 25, 2021 7 hours ago, 8ntruck said: I suspect it has ingested some crud into the carb Agreed 7 hours ago, 8ntruck said: we ended up skidding the logs off of the trail with a come along and levering them about with a shovel That's more fun anyway. Heck with the chainsaw. Share this post Link to post Share on other sites
8ntruck 9,184 #27 Posted November 27, 2021 Took another pass at the saw today. Different fuel, same results. The choke linkage went weird, so I took the top cover off of the saw to see what is going on. Immediately saw what the carb ingested - the foam air filter element was disintegrating. I was holding it with two fingers at one edge. The weight of the element made it break, leaving a pinched off piece between my fingers. Share this post Link to post Share on other sites
ebinmaine 80,113 #28 Posted November 27, 2021 1 hour ago, 8ntruck said: Took another pass at the saw today. Different fuel, same results. The choke linkage went weird, so I took the top cover off of the saw to see what is going on. Immediately saw what the carb ingested - the foam air filter element was disintegrating. I was holding it with two fingers at one edge. The weight of the element made it break, leaving a pinched off piece between my fingers. PITA but an easy solve. Share this post Link to post Share on other sites
