Rick Ferrucci 17 #1 Posted November 12, 2021 Hello Red Square, I’m probably not the first person who’s been looking for 15” AG lug tires, that can fit in the fenders of a GT14. I think I may have seen some pictures on some, but I don’t know what size tires they are. If anyone had found any, please let me know what size can fit the stock rims. Thank you for your time and help. Rick Share this post Link to post Share on other sites
oliver2-44 11,065 #2 Posted November 12, 2021 Following along Share this post Link to post Share on other sites
520HC 208 #3 Posted November 12, 2021 millertire.com has 15" lug tires. 2 Share this post Link to post Share on other sites
ebinmaine 75,777 #4 Posted November 12, 2021 American Farmer has some. I have a set of 7.60-15 for my Colossus build. They were purchased off the 'Bay. 1 Share this post Link to post Share on other sites
Achto 30,206 #5 Posted November 12, 2021 https://www.millertire.com/7-60-15-american-farmer-traction-implement-4-ply/ 1 Share this post Link to post Share on other sites
ebinmaine 75,777 #6 Posted November 12, 2021 @Achto Them's the ones! Nice work Sir. I got the idea from @PeacemakerJack originally. His Dad I think?? Runs these. 1 Share this post Link to post Share on other sites
pacer 3,177 #7 Posted November 12, 2021 Yeah, that American Farmer Is the one I have on my one "D" that has the 15"s. Been on it for some 7-8yrs and still look like new. I kinda like the look of the 15s as opposed to the 12s..... 2 Share this post Link to post Share on other sites
ebinmaine 75,777 #8 Posted November 12, 2021 1 minute ago, pacer said: . I kinda like the look of the 15s as opposed to the 12s..... Absolutely agreed Share this post Link to post Share on other sites
Rick Ferrucci 17 #9 Posted November 12, 2021 Thank you everyone for your response. I’ll check them out. I want to get them liquid filled, and studded before the snow flies. Share this post Link to post Share on other sites
ebinmaine 75,777 #10 Posted November 12, 2021 2 minutes ago, Rick Ferrucci said: Thank you everyone for your response. I’ll check them out. I want to get them liquid filled, and studded before the snow flies. Liquid-filled I absolutely recommend but those are not a studdable tire unless you're going to do a self installation. I'd highly recommend investing in a decent set of chains instead. That way they would be removable for non ice / snow usage. Share this post Link to post Share on other sites
Rick Ferrucci 17 #11 Posted November 12, 2021 Currently my GT14 has turf tires and chains. The reason I was thinking of studs was because, the new AG tires might not have room for chains between the tires and fenders. Why can’t these tire be studded by a tire dealer? I think they put the studs in with a pneumatic gun. I think they’re like an inverted mushroom. I didn’t want to screw in studs, because I didn’t want one to fall off the tire, and find its way into my car tire. Has anyone else studded their tires, or had it done? Share this post Link to post Share on other sites
ebinmaine 75,777 #12 Posted November 12, 2021 Tires can only be studded into a hole originally made for the studs. What size tire do you have clearance for? I can check the actual diameter of mine if it helps. Share this post Link to post Share on other sites
pacer 3,177 #13 Posted November 12, 2021 IIRC, they are 32" .... the first set I got was for a 1054 and was concerned about the clearance, but they worked out, had about 2-3" Plenty of room on the D. Share this post Link to post Share on other sites
ebinmaine 75,777 #14 Posted November 12, 2021 5 minutes ago, pacer said: IIRC, they are 32" Mine measure 29.5 and 30. Note*** Mine are fluid filled and have no air pressure. 1 Share this post Link to post Share on other sites
pfrederi 19,276 #15 Posted November 12, 2021 If you go with chains regular chains will fall into the tread between the bars and not do you much good. You will need Double ring Chains (Pic 1 ) or duo link pic 2 Share this post Link to post Share on other sites
ebinmaine 75,777 #16 Posted November 12, 2021 37 minutes ago, pfrederi said: regular chains will fall into the tread between the bars I'd agree with that. I have 2 link heavy duty ice chains on my V bar tires. They do have some effect but obviously not as much because some of the links are in between the bars. Also, they can be quite challenging to install for the first time every year because they just do not want to line up. Share this post Link to post Share on other sites
Rick Ferrucci 17 #17 Posted November 12, 2021 Right now the tractor has dry-rotted, stock, (original ’69) 27x9.5x15 turf tread tires. The chains take up another 3/4” clearance to the fenders. I mean, it’s like adding another 1 1/2” to the overall tire. I realize, probably turf tires with chains, is the best traction on snowy/ icy pavement. How are AG lug tires in snow? Do they still need chains? 1 Share this post Link to post Share on other sites
ebinmaine 75,777 #18 Posted November 12, 2021 10 minutes ago, Rick Ferrucci said: How are AG lug tires in snow? Do they still need chains? If they're VERY heavy and you have flat ground you may do ok. Our main yard is a little slanted especially near the edges. My tractor is close to useless without chains.... Share this post Link to post Share on other sites
squonk 44,870 #19 Posted November 13, 2021 If you get any ice, you need chains. 1 Share this post Link to post Share on other sites
Pullstart 68,529 #20 Posted November 15, 2021 I have a couple 953 flavors I’ve converted to 5 lug hubs and 12” wheels… 2 Share this post Link to post Share on other sites
Rick Ferrucci 17 #21 Posted November 16, 2021 I thought about going the12” tire/rim route, but I didn’t know if I’d run into any issues with the rims I use, such as are there differences with the offsets, or are all Wheel Horse 12” rims, the same? I also see that the hubs are shorter. This video also answered another question I had. I guess you can’t slide the hub in closer, to get the tracking in line. Share this post Link to post Share on other sites
