Rucan 5 #1 Posted November 11, 2021 I left my wheelhorse 414-8 in the garage for a year. Came back and got it started but plow wont raise now. Any ideas? Share this post Link to post Share on other sites
SylvanLakeWH 31,404 #2 Posted November 11, 2021 Bit more information…? What is not happening that should? Maybe a couple pics? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,234 #3 Posted November 11, 2021 Share this post Link to post Share on other sites
953 nut 66,068 #4 Posted November 11, 2021 Do you have an electric lift or the manual lift on your 414-8? Share this post Link to post Share on other sites
Handy Don 16,602 #6 Posted November 11, 2021 Welcome to the Forum. I'm sure the fine folks here will help you track down the issue and get you going. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,234 #7 Posted November 11, 2021 Probably is an electric lift since this is posted in electrical. Did not notice that. Share this post Link to post Share on other sites
Pullstart 69,958 #8 Posted November 11, 2021 Michigander! Share this post Link to post Share on other sites
Rucan 5 #9 Posted November 13, 2021 On 11/11/2021 at 7:19 AM, 953 nut said: Do you have an electric lift or the manual lift on your 414-8? I have electric lift. Share this post Link to post Share on other sites
Rucan 5 #10 Posted November 13, 2021 On 11/11/2021 at 9:57 AM, gwest_ca said: Probably is an electric lift since this is posted in electrical. Did not notice that. Thanks Share this post Link to post Share on other sites
953 nut 66,068 #11 Posted November 13, 2021 9 hours ago, Rucan said: I have electric lift. Take a look at the wiring drawing Garry @gwest_ca provided. Check all of those electrical connections to be sure they are tight and free of corrosion. Is your hour meter working? the relay for the lift uses the same power source as the hour meter. With the ignition off can you hear the relay close when the key is moved to the run position? Hope this helps. Share this post Link to post Share on other sites
Rucan 5 #12 Posted November 13, 2021 14 minutes ago, 953 nut said: Take a look at the wiring drawing Garry @gwest_ca provided. Check all of those electrical connections to be sure they are tight and free of corrosion. Is your hour meter working? the relay for the lift uses the same power source as the hour meter. With the ignition off can you hear the relay close when the key is moved to the run position? Hope this helps. I will check thanks 1 Share this post Link to post Share on other sites
