Jeff-C175 7,211 #51 Posted November 13, 2021 Didn't go through the whole thread but I think it's a good idea to replace the fuel tank grommet. I had one leak and deposit a rather large puddle of tractor pee on the floor. Could have been disastrous! Share this post Link to post Share on other sites
ebinmaine 80,814 #52 Posted November 13, 2021 1 hour ago, Jeff-C175 said: fuel tank grommet Excellent suggestion. I added that and fuel outlet. Outlet is one of the filters and should absolutely be replaced. 1 Share this post Link to post Share on other sites
ebinmaine 80,814 #53 Posted November 13, 2021 Folks, any suggestions for the Cosmetics? Share this post Link to post Share on other sites
SylvanLakeWH 32,658 #54 Posted November 13, 2021 12 minutes ago, ebinmaine said: Folks, any suggestions for the Cosmetics? Uhm… Red? 4 Share this post Link to post Share on other sites
Maxwell-8 4,371 #55 Posted November 13, 2021 Good to see you also added the magnetic drain plug. I tend to always have tranny problems and so I have to open them. But the metal flakes I always find... People don't know how to shift strait cut gears. Worked on this Bolens today, metal flakes everywere. eventhough the oil was just replaced! This was just from sticking this magnet deep in the tranny when their was still oil in it. 1 Share this post Link to post Share on other sites
AHS 1,701 #56 Posted November 13, 2021 13 hours ago, ebinmaine said: Excellent suggestion. I added that and fuel outlet. Outlet is one of the filters and should absolutely be replaced. Yup… I always do that. Fuel tank grommet and petcock w/filter. It’s just for peace of mind. 2 Share this post Link to post Share on other sites
Sailman 1,307 #57 Posted November 20, 2021 (edited) Suggestions for the cosmetics...Just got an original paint, stored inside, C-160. Lots of elbow grease and 3M rubbing compound followed by Flynns Cherry Wet wax. Amazed at how well the paint still looks! Not perfect but darn nice for an almost 50 year old tractor. Will be posting pictures tomorrow. Edited November 20, 2021 by Sailman add pictures 7 Share this post Link to post Share on other sites
Lee1977 7,786 #58 Posted May 15, 2022 (edited) You left out broken tab on axle pivot since a lot of them are broken. On 300, 400 and 500 series the front attachment at fender and gas tank a lot are broken or cracked. not a real deal braker ,but will require structural repai, welding and additional metal for a solid repair. All 520 Onan remove engine covers and clean cooling fins as the oil filter bracket will hold some oil if not cleaned when changing . This with dust and grass will fill the rear cooling fins up solid. I believe that is the reason for valve seat problem. Edited May 15, 2022 by Lee1977 1 1 Share this post Link to post Share on other sites
BBQVultureWings 160 #59 Posted March 13, 2024 On 11/10/2021 at 10:14 AM, Snoopy11 said: You forgot me... @ebinmaine... I have a diverse herd... DISASSEMBLE!!! ...and REASSEMBLE...! Don Sometimes just because.... buying some nice new white bed sheets to start this process Share this post Link to post Share on other sites
ebinmaine 80,814 #60 Posted March 13, 2024 2 hours ago, BBQVultureWings said: Sometimes just because.... buying some nice new white bed sheets to start this process What are you going to be tearing into? 1 Share this post Link to post Share on other sites
peter lena 10,080 #61 Posted November 8, 2025 @Snoopy11 personal experience with fuel related issues . has made me go at it one way , CHANGE OUT EVERY BIT OF THE EXISTING LINE ? rubber fuel hose , breaks down in tiny incremental bits , also long sitting fuel in an almost empty tank is the perfect place , to completely load up your tractor with debris . have a fiter close to tank and carb . personally use stabil in all my fuel to ELIMINATE , HOSE BREAK DOWN , 1 Share this post Link to post Share on other sites
peter lena 10,080 #62 Posted November 8, 2025 @Snoopy11 personal experience with fuel related issues . has made me go at it one way , CHANGE OUT EVERY BIT OF THE EXISTING LINE ? rubber fuel hose , breaks down in tiny incremental bits , also long sitting fuel in an almost empty tank is the perfect place , to completely load up your tractor with debris . have a fiter close to tank and carb . personally use STABIL in all my fuel to ELIMINATE , HOSE BREAK DOWN , how do I know its working ? cleaned out entire tank to carb , new hoses , steel brake line , for longest run , new tank valve , no fuel line break down anywhere , did the same to my generator . carb bowls are clean/ clear , instant starts . REPEDITIVE PROBLEMS are showing what DOES NOT WORK , you want to keep doing this ???, realise my suggestion to stop / eliminate issues , is not in the book , when I see a failure , experiment with what works , pretty simple , pete Share this post Link to post Share on other sites
