953 nut 69,149 #26 Posted November 11, 2021 11 hours ago, fullchoke said: points ignition. They might need some cleaning up. Just remove the cover over the points and slide a dollar bill back and forth between the contacts. I have had good luck with Seafoam fuel additive to help clean up a dialect system that has been sitting unused. 1 Share this post Link to post Share on other sites
Pullstart 71,213 #27 Posted November 11, 2021 A GT14 is sure a worker! It’s rare to have a tiller… or even the tiller pulley on the rear drive pulley! a couple things. If you use the “at” symbol, you can tag someone. @fullchoke just type the “at” then start typing a name. By the way, are you a bird hunter? I agree with Richard, polish the points instead of scratching them. If you must use Emory paper, use the back side of it… like fold it closed. Good luck getting it going! 1 Share this post Link to post Share on other sites
fullchoke 22 #28 Posted November 11, 2021 Oldskool, whatever I decide, I'm sure parts are missing. Possibly mower deck pulleys are re-purposed on the sickle bar. I'm going to try to figure out what the mower deck should look look like, and how it is attached. I can't find a ID plate on the deck with blades. More pictures will be coming. I'm sure I will need help. Pullstart, Fullchoke is kind of a play on words. Choking is something nobody wants to do, actually or figuratively, or on a cold engine you give it full choke. Many times when I start something, I go in cold, so to speak, like this GT14. Before I saw it I had never heard of a GT14. You also need a fullchoke for those long shots when bird hunting. This mower project is turning into a longshot of sorts too. Thanks guys for all the help, it's fun to run into a bunch of guys that are enthused and dedicated to their machines. 2 Share this post Link to post Share on other sites
ebinmaine 80,642 #29 Posted November 11, 2021 8 minutes ago, fullchoke said: Thanks guys for all the help, it's fun to run into a bunch of guys that are enthused and dedicated to their machines Many of us are just a tad n a half nuts too. So we got that goin' for us... 1 1 2 Share this post Link to post Share on other sites
Oldskool 6,678 #30 Posted November 11, 2021 48 minutes ago, fullchoke said: Before I saw it I had never heard of a GT14. I hadn't either. When I found mine I didn't know what I found. It was a basket case. Engine was shot, all for wheels had rot. The tires were so far gone when trying to dismount them the sidewalls tore apart. The wiring was a rodents nest. Electric clutch didn't work. I'm sure there was more I'm forgetting. Hang with it. You won't regret it Share this post Link to post Share on other sites
fullchoke 22 #31 Posted November 11, 2021 I wasn't looking for a project when I bought this one. I was looking for something I can use (make life easier) and if it took to much time and effort I would sell it. Once I saw it in person(it was listed online), I could tell it was quality built. Some older machines are built with too much quality, and they can't compete with the low priced, low quality stuff. I felt the GT14 had that high quality build to it and the existence of this site, validates that. The downside is parts can be hard to find, and finding out the main following is midwest and east, makes it even more difficult out here in Oregon. I would like to find a basket case, but my son, who helps me with these things, thinks I already have too many projects, and he is definitely correct. I hope this one doesn't become too involved, or I will get pressure to sell it. 1 Share this post Link to post Share on other sites
953 nut 69,149 #32 Posted November 12, 2021 20 hours ago, fullchoke said: I'm going to try to figure out what the mower deck should look look like, and how it is attached. Your mower deck should have this type of attachment on top. An attachment like this on your frame. And it will look like this when mounted 1 Share this post Link to post Share on other sites
peter lena 10,047 #33 Posted November 12, 2021 @fullchoke make up a small cord with a clip , for that key , my tractor keys are all clipped to the throttle lever , like a braided fishing line , don.t ask me how or why i do this , pete 1 1 1 Share this post Link to post Share on other sites
fullchoke 22 #34 Posted November 13, 2021 Thanks 953. I see many pieces missing for the mower deck too. Basically the parts that mount the mower deck that are on the tractor, and the bracket with the pulleys that send the power to the mower deck. It looks like he removed the mower deck, belt and attaching parts and put that with the decks. Then moved the tractor to where he was doing the sickle bar mod, and removed everything that was bolted to the tractor for the mower deck, and that went somewhere else. I'm sure it was all there, but the scrapper came through before the sale, so it's all gone now. I have determined about when it was last used because the Napa filter for the hydraulics has 2018, and 822 hours written on it. The hour meter now has 826 hours. 2 Share this post Link to post Share on other sites
953 nut 69,149 #35 Posted November 13, 2021 (edited) 12 hours ago, fullchoke said: I see many pieces missing for the mower deck too. Basically the parts that mount the mower deck that are on the tractor, and the bracket with the pulleys that send the power to the mower deck. It looks like he removed the mower deck, belt and attaching parts The parts you need are not just for the GT-14, they were used from '67 to 1972 on all long frame @Ed Kennell has probably got he parts you need, he saves all these parts to help get other's back on the turf. If he can't help then an ad in our classified section should do the trick. https://www.wheelhorseforum.com/classifieds/wanted/ Edited November 13, 2021 by 953 nut Share this post Link to post Share on other sites
Ed Kennell 47,268 #36 Posted November 13, 2021 to the Full choke. Like Richard mentioned above, I probably have the deck drive parts you need. If you are interested, please send me a PM. 1 Share this post Link to post Share on other sites
peter lena 10,047 #37 Posted November 14, 2021 @fullchoke make up a small cord with a clip , for that key , my tractor keys are all clipped to the throttle lever , like a braided fishing line , don.t ask me how or why i do this , pete Share this post Link to post Share on other sites
peter lena 10,047 #38 Posted November 14, 2021 @fullchoke used an I / D BADGE SPRING CLIP , https://www.specialistid.com/products/id-badge-strap-clips-industry-standard-clip?gclid=Cj0KCQiA4b2MBhD2ARIsAIrcB-RM_t8iu3NoEVR74xjEZ0ORP1KYqVzunTDDR4mtoPp4UPTER4TsaP0aAhy_EALw_wcB had some left over from work , simple handy , pete Share this post Link to post Share on other sites
fullchoke 22 #39 Posted November 14, 2021 Thanks Pete. I ordered the new key at my local lawn and garden center, and they told me it was back ordered, and it would take another week. So i really don't want to loose that key, once I get it. Share this post Link to post Share on other sites
fullchoke 22 #40 Posted November 14, 2021 More pictures of the mower decks etc. That one picture is just one of a loose tensioner pulley that I didn't know where it goes. I have some more on my sons phone. I'll get those up to. 1 Share this post Link to post Share on other sites
fullchoke 22 #46 Posted November 14, 2021 Sorry some of the pictures are duplicates. The mower deck with the rubber on it is the one with the blades in it. It is highly modified, and has been repaired. The other one, has no blades, but could be the nicest one to use if the mounting parts and blades can be found. Thanks Share this post Link to post Share on other sites
Ed Kennell 47,268 #47 Posted November 14, 2021 A couple comments after studying the pictures. I would check the electric PTO cluch early in the redo. If it is not working, they are expensive to replace if you can even find one. Many owners replace them with a manual system. I am not familiar with the GT series to know if these changes are possible, but since you do not have a PTO/ deck drive system, you may also want to consider adding a front attach-a-matic and a front mule drive instead of the older swing arm side drive system. I do have the front mule drives and attach-a-matics and the older side drive parts and a support carriage for the deck that you want to use. 2 Share this post Link to post Share on other sites
peter lena 10,047 #48 Posted November 14, 2021 @fullchoke just my opinion , but take advantage of @Ed Kennell offer on those attach -a- matic and pto drive parts and convert it . much more up to date for parts and running , parts and pieces are much easier with the new type deck set up . worth a contact , pete Share this post Link to post Share on other sites
SylvanLakeWH 32,461 #49 Posted November 14, 2021 On 11/11/2021 at 11:46 AM, ebinmaine said: Many of us are just a tad n a half nuts too. So we got that goin' for us... Who you callin’ half nuts? 2 Share this post Link to post Share on other sites
953 nut 69,149 #50 Posted November 15, 2021 4 hours ago, Ed Kennell said: Many owners replace them with a manual system. For the GT-14 you have a couple of good mechanical PTO options. The PTO from a 953/1054 would be the easiest. Another option would be the drive pulley and manual PTO from a 12 HP (1.125" crankshaft) on any pre 1973 Hydro like a charger, 1276 etc. Share this post Link to post Share on other sites
