squonk 44,615 #1 Posted October 8, 2021 For @ebinmaine. Heard lots of complaints about a "hard to work throttle" "Idle or fast nothing in between" ect on the short frame small block tractors. I had the same issue on HHHOOOWWWAAARRRDDD!!!. I've messed with it and messed with it some more. Couldn't come up with an answer. Cable was free. Throttle wheel was free. I bought a pair genuine Toro 102118 throttle cables at the show. These cost close to $30! But I have had trouble with the crimps coming loose or the knobs falling off of the aftermarket ones. I came up with the idea if maybe I made the cable a little extra long, it would " Give" a little when pulled and maybe work smoother. Picture of the new cable compared to the one that was on the tractor. New cable was 45" OA length. I installed the entire cable on and then played with the length of the conduit in the clamp to where the cable didn't stick out too far when the hood was closed.I wanted the conduit a bit longer than the old one. I cut 10 1/2" off. So the new cable will be approx. 4" longer than the old one. I installed the cable with 3/4" of conduit on the throttle side of the clamp. With the knob pushed in the cable extends out of the conduit 1 3/4" 4 2 Share this post Link to post Share on other sites
pfrederi 18,969 #2 Posted October 8, 2021 Having that arm on the throttle disc must help. Unfortunately mine do not have that arm the wire goes right into a hole in the disc....I am going to add an arm this winter... 4 Share this post Link to post Share on other sites
ebinmaine 74,546 #3 Posted April 1, 2023 @squonk Thanks for posting this. I've been saving a link to this thread in my email since 10/21 and forgot to reply. 1 Share this post Link to post Share on other sites
ebinmaine 74,546 #4 Posted March 2, 2024 On 10/8/2021 at 12:47 PM, squonk said: For @ebinmaine. Heard lots of complaints about a "hard to work throttle" "Idle or fast nothing in between" ect on the short frame small block tractors. I had the same issue Thanks again for making this thread. I used it again today. 2 Share this post Link to post Share on other sites
Retired Wrencher 6,058 #5 Posted March 1 On 3/2/2024 at 5:58 PM, ebinmaine said: Thanks again for making this thread. I used it again today. Thanks for the tread. I have to do this week on the 856 this week. 2 Share this post Link to post Share on other sites
squonk 44,615 #6 Posted March 1 Another thing I found is the angle of the pull. The lever or disc is going to move in a semi circle. If you have the angle of the cable at one extreme or the other it will fight the assembly moving smooth. You want the angle of the cable pull to be some where in the middle that the cable hole arc will travel 1 Share this post Link to post Share on other sites
ebinmaine 74,546 #7 Posted March 1 10 minutes ago, squonk said: Another thing I found is the angle of the pull. The lever or disc is going to move in a semi circle. If you have the angle of the cable at one extreme or the other it will fight the assembly moving smooth. You want the angle of the cable pull to be some where in the middle that the cable hole arc will travel Agreed. The right zone is very different. Share this post Link to post Share on other sites
Retired Wrencher 6,058 #8 Posted March 2 Thanks again for the info! Share this post Link to post Share on other sites
