Horse Newbie 7,404 #576 Posted January 21, 2022 (edited) 18 minutes ago, Jeff-C175 said: I think you should have jam nuts at both ends of the tie rods. If you don't you'll end up wearing out the threads. Dag-nab it ! Edited January 21, 2022 by Horse Newbie 2 Share this post Link to post Share on other sites
kpinnc 18,111 #577 Posted January 21, 2022 2 minutes ago, Horse Newbie said: Anybody used these for headlights ? Not specifically. How much are they? If the Lumens rating is correct, they'll be bright. Share this post Link to post Share on other sites
Jeff-C175 7,207 #578 Posted January 21, 2022 Think about putting dust caps on the spindles too... You can get these in black also. 1 1 Share this post Link to post Share on other sites
Horse Newbie 7,404 #579 Posted January 21, 2022 8 minutes ago, kpinnc said: Not specifically. How much are they? If the Lumens rating is correct, they'll be bright. 8 minutes ago, kpinnc said: Not specifically. How much are they? If the Lumens rating is correct, they'll be bright. $17.53… 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #580 Posted January 21, 2022 (edited) 20 minutes ago, Horse Newbie said: Anybody used these Different name on mine, but I'm sure the dame samn thing. Mine are 6000K which means a little bit 'whiter', perhaps almost 'blue-ish', than the 5000K. I figure if I'm going LED I'm gonna get 'em as white as possible, but 5000K is good too. I wouldn't go any lower than that because they start to turn yellow. Edited January 21, 2022 by Jeff-C175 2 Share this post Link to post Share on other sites
Horse Newbie 7,404 #581 Posted January 21, 2022 7 minutes ago, Jeff-C175 said: Think about putting dust caps on the spindles too... You can get these in black also. Looks like your washer is up higher than mine… Share this post Link to post Share on other sites
Horse Newbie 7,404 #582 Posted January 21, 2022 1 minute ago, Jeff-C175 said: I wouldn't go any lower than that because they start to turn yellow Does your look like that on the front ?… seems I have seen them on here that doesn’t have the yellow circles/ look almost like halogens . Share this post Link to post Share on other sites
Jeff-C175 7,207 #583 Posted January 21, 2022 (edited) 57 minutes ago, Horse Newbie said: Looks like your washer is up higher than mine… I don't believe there's a washer on mine at all. I think the 'hump' you see in the cover is the top of the spindle. Mine have C-clips and not split cotters. You might have to flatten that cotter head with a hammer. Edited January 21, 2022 by Jeff-C175 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #584 Posted January 21, 2022 (edited) 9 minutes ago, Horse Newbie said: Does your look like that on the front ? Not as 'shiny' as an incandescent sealed beam though, which I like the look of better, but I guess you can't have your cake and eat it too. Edited January 21, 2022 by Jeff-C175 1 Share this post Link to post Share on other sites
Horse Newbie 7,404 #585 Posted January 21, 2022 6 minutes ago, Jeff-C175 said: Not as 'shiny' as an incandescent sealed beam though: I don’t mind if they aren’t as shiny… and I could live with being able to see the “yellow” Light Emitting Diodes, I’d just rather not. Share this post Link to post Share on other sites
Jeff-C175 7,207 #586 Posted January 21, 2022 Just now, Horse Newbie said: being able to see the “yellow” Light Emitting Diodes, If you look real close in person you can just see the diodes inside, but the glass on these is sorta frosted. Not obvious at all. 1 Share this post Link to post Share on other sites
Horse Newbie 7,404 #587 Posted January 21, 2022 If I hammer that cotter pin head down flat, those black dust cover caps will slid over the top of the end of the axle where the spindle shaft comes up through right ? Share this post Link to post Share on other sites
kpinnc 18,111 #588 Posted January 21, 2022 22 minutes ago, Horse Newbie said: $17.53 That is about right. The last set I bought were $18 each. 1 Share this post Link to post Share on other sites
kpinnc 18,111 #589 Posted January 21, 2022 8 minutes ago, Horse Newbie said: If I hammer that cotter pin head down flat, those black dust cover caps will slid over the top of the end of the axle where the spindle shaft comes up through right Yep, they work great! Got them on the Bronco, and I should get a set for a couple others too. 1 Share this post Link to post Share on other sites
Horse Newbie 7,404 #590 Posted January 21, 2022 On 1/19/2022 at 11:20 PM, Jeff-C175 said: I took a look see at my LED head lamps and they are labeled AC/DC so they will work on either, but the flicker would still be a problem with the limited output of the stator on your engine, and the RPMs will change the FREQUENCY of the flicker. MANY of the ones I see on Amazon are also AC/DC. @Jeff-C175 are these the ones you have ? @kpinnc look 6000K ! Share this post Link to post Share on other sites
Horse Newbie 7,404 #591 Posted January 21, 2022 27 minutes ago, Jeff-C175 said: If you look real close in person you can just see the diodes inside, but the glass on these is sorta frosted. Not obvious at all. So yours ARE glass fronts, and not plastic ? Share this post Link to post Share on other sites
Jeff-C175 7,207 #592 Posted January 21, 2022 25 minutes ago, Horse Newbie said: If I hammer that cotter pin head down flat, those black dust cover caps will slid over the top of the end of the axle where the spindle shaft comes up through right ? Correct. 1 Share this post Link to post Share on other sites
Horse Newbie 7,404 #593 Posted January 21, 2022 14 minutes ago, kpinnc said: Yep, they work great Did you get from @wheelhorseman ? Share this post Link to post Share on other sites
Jeff-C175 7,207 #594 Posted January 21, 2022 (edited) 10 minutes ago, Horse Newbie said: are these the ones you have ? Looks like it. These were already in the machine when I got it a few months ago. But yeah, that is probably them. Those ones you showed were higher Lumens though... but these are pretty bright too. I imagine side by side 800 versus 2000 would be huge though. Edited January 21, 2022 by Jeff-C175 Share this post Link to post Share on other sites
kpinnc 18,111 #595 Posted January 21, 2022 6000K will look bluish. Mine are 4500K and look snow white. I got my dust caps at the big show years back. But I will definitely get some from Lowell if he has them. 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #596 Posted January 21, 2022 (edited) I 4 minutes ago, kpinnc said: got my dust caps ... on Amazon https://www.amazon.com/gp/product/B07TBRTR2Z/ They're a little more Orange than Red though. Edited January 21, 2022 by Jeff-C175 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #597 Posted January 21, 2022 5 minutes ago, kpinnc said: 6000K will look bluish I don't really notice the bluish with these. They look pretty white. In the SNOW, yes, they do have a slight blue tint. 1 Share this post Link to post Share on other sites
kpinnc 18,111 #598 Posted January 21, 2022 2 minutes ago, Jeff-C175 said: don't really notice the bluish with these. They look pretty white. In the SNOW, yes, they do have a slight blue tint. I think the ratings are much like lumens. There is no standard, or the standard gets regularly ignored. The actual range puts white in the 4500-5500 range. 2 Share this post Link to post Share on other sites
Horse Newbie 7,404 #599 Posted January 21, 2022 9 minutes ago, kpinnc said: 6000K will look bluish. Mine are 4500K and look snow white I’ll get 4500 or 6000… I want bright white, but if they’re a little blue, it won’t make me blue. 2 Share this post Link to post Share on other sites
Horse Newbie 7,404 #600 Posted January 21, 2022 Alright then… show me some LED taillights that are the same size as the rear reflectors on the Work Horse. Share this post Link to post Share on other sites
