slim67 2,825 #76 Posted November 7, 2021 1 minute ago, Pullstart said: Musta’ been! I was on the phone with my buddy when he went by, at 11:37am 953/1054 might just be the best modern WH plow machine, in stock form! That’s what I’m thinking. Where were you exactly when you saw him? Share this post Link to post Share on other sites
slim67 2,825 #77 Posted November 7, 2021 4 minutes ago, Pullstart said: YUUUUUP! Then again, would the survivors be as special then? We have a Pond plow for or Senior, I’ll get it in a furrow sooner or later. It’s about a 6.5 hour drive for you but it’d be cool to see you there next year with whatever you bring. Share this post Link to post Share on other sites
ebinmaine 79,687 #78 Posted November 7, 2021 1 hour ago, slim67 said: Ford ABS ignition conversion on a Sears ST12 with a HH 120 That's a neat conversion. I e been reading/watching the work of @Ed Stoller on the subject. He uses GM LS2 components. I bought a kit from him I'll be retrofitting to a '74 C160 Tecumseh engine tractor at some point. Share this post Link to post Share on other sites
slim67 2,825 #79 Posted November 7, 2021 Just now, ebinmaine said: That's a neat conversion. I e been reading/watching the work of @Ed Stoller on the subject. He uses GM LS2 components. I bought a kit from him I'll be retrofitting to a '74 C160 Tecumseh engine tractor at some point. I’m not sure who came up with that idea but has I been more patient I may have kept the HH100 in my Raider. 1 Share this post Link to post Share on other sites
ebinmaine 79,687 #80 Posted November 7, 2021 2 hours ago, Pullstart said: contemplating tossing the LSD’s in our plow tractors, wondered how much of a difference they make? I can't comment on dirt plowing but I'll state this: My Cinnamon Horse C160 has open diff/no limited slip. It weighs about 1300 lbs in snowplow form with me on it. I rarely slip but it certainly does happen. Trina's Pigpen tractor 867 weighs maybe 950 lbs, give or take. It does have limited slip differential. I believe her traction is comparable or possibly better than mine. 2 Share this post Link to post Share on other sites
Pullstart 70,694 #81 Posted November 7, 2021 1 hour ago, slim67 said: That’s what I’m thinking. Where were you exactly when you saw him? East of Sandusky, OH and West of I-79 (?) at Pittsburgh Share this post Link to post Share on other sites
slim67 2,825 #82 Posted November 7, 2021 He was coming from vermilion which is by Sandusky. 1 Share this post Link to post Share on other sites
slim67 2,825 #83 Posted November 7, 2021 3 hours ago, ebinmaine said: I can't comment on dirt plowing but I'll state this: My Cinnamon Horse C160 has open diff/no limited slip. It weighs about 1300 lbs in snowplow form with me on it. I rarely slip but it certainly does happen. Trina's Pigpen tractor 867 weighs maybe 950 lbs, give or take. It does have limited slip differential. I believe her traction is comparable or possibly better than mine. When I went in October,the 5073 was still in it and it was cool seeing both tires grabbing for traction. I would love to fix that key way seat problem and put it back into service. Share this post Link to post Share on other sites
ebinmaine 79,687 #84 Posted November 7, 2021 19 minutes ago, slim67 said: fix that key way seat problem Forgive me if you already said... What's the issue? Bad axle? Share this post Link to post Share on other sites
slim67 2,825 #85 Posted November 7, 2021 2 minutes ago, ebinmaine said: Forgive me if you already said... What's the issue? Bad axle? The key way seats in the axle shaft ends are opened up too much which led to the right hub walking over to the axle housing. I might see if a machine shop can cut new ones in. I’m not a machinist but I believe the term is broaching? I think that at least pertains to the long keyway cutout on a shaft. These are the half circle shaped key ways. 1 Share this post Link to post Share on other sites
ebinmaine 79,687 #86 Posted November 7, 2021 1 minute ago, slim67 said: The key way seats in the axle shaft ends are opened up too much which led to the right hub walking over to the axle housing. I might see if a machine shop can cut new ones in. I’m not a machinist but I believe the term is broaching? I think that at least pertains to the long keyway cutout on a shaft. These are the half circle shaped key ways. Have someone cut a full sized keyway groove to match the hub keyway. Then you can use a longer key. There may be someone here on Redsquare that offers the service. Not sure. Share this post Link to post Share on other sites
oliver2-44 11,628 #87 Posted November 7, 2021 @slim67 I think @WHX?? can broach a new keyway in hubs, i don't think he can mill an axle. Share this post Link to post Share on other sites
slim67 2,825 #88 Posted November 7, 2021 1 hour ago, oliver2-44 said: @slim67 I think @WHX?? can broach a new keyway in hubs, i don't think he can mill an axle. Thanks for the tip Share this post Link to post Share on other sites
slim67 2,825 #89 Posted November 7, 2021 1 hour ago, ebinmaine said: Have someone cut a full sized keyway groove to match the hub keyway. Then you can use a longer key. There may be someone here on Redsquare that offers the service. Not sure. That’s a good idea Eric. 1 Share this post Link to post Share on other sites
ebinmaine 79,687 #90 Posted November 7, 2021 Just now, slim67 said: That’s a good idea Eric. Can't take credit for it. Stolen from some other tractor nut over the years. @Oldskool Mike has been known to cut an axle without a mill. Not sure if he can elaborate on how. 1 Share this post Link to post Share on other sites
Oldskool 6,678 #91 Posted November 7, 2021 15 minutes ago, ebinmaine said: Can't take credit for it. Stolen from some other tractor nut over the years. @Oldskool Mike has been known to cut an axle without a mill. Not sure if he can elaborate on how. Your talking for key stock correct? 1 Share this post Link to post Share on other sites
slim67 2,825 #92 Posted November 7, 2021 23 minutes ago, ebinmaine said: Can't take credit for it. Stolen from some other tractor nut over the years. @Oldskool Mike has been known to cut an axle without a mill. Not sure if he can elaborate on how. I ground a tapered shaft engine with a handgrinder down to 1 inch and cut in a 1/4 keyway seat. It actually worked. 3 Share this post Link to post Share on other sites
Oldskool 6,678 #93 Posted November 7, 2021 I cut my own on Project Snowdrift. They were full length. I used a 4.5" angle grinder. I stacked up Forney cut off wheels in conjunction with a Makita cut off wheel. They are different thicknesses. Before cutting the slot I do a pre cut on scrap steel to even up the diameters of the wheels. I drew a centered line on the axle and cut. Then clean it up with a single cut off wheel. It takes a steady hand and a can do attitude because if you mess up it's a MESS. I would suggest trying a full slot on some scrap first. Good luck 1 1 Share this post Link to post Share on other sites
WHX?? 57,388 #94 Posted November 7, 2021 2 hours ago, oliver2-44 said: @slim67 I think @WHX?? can broach a new keyway in hubs, i don't think he can mill an axle. Yes keyways in hubs but not axles at this time. 2 Share this post Link to post Share on other sites
