upstateyankee50 59 #26 Posted September 30, 2021 2 hours ago, Gregor said: I think it's time to bite the bullet, and remove the flywheel. CAREFULLY ! You have to check that key. IMO yep you are right but first I need to find away to remove the nut as not to damage the fly wheel ;as there is no way that I can stop the wheel from turning ;a nice impact would be great but that is one item I do not have tomorrow is another day ;thanks again Share this post Link to post Share on other sites
ebinmaine 72,609 #27 Posted September 30, 2021 1 hour ago, upstateyankee50 said: impact An impact wrench should NEVER touch a crankshaft. It's one of the best ways to break the crank. Share this post Link to post Share on other sites
upstateyankee50 59 #28 Posted September 30, 2021 2 hours ago, ebinmaine said: An impact wrench should NEVER touch a crankshaft. It's one of the best ways to break the crank. again this is the first for me to remove the fly wheel and I have tried so many ways to remove it but the darn thing turns and for sure I do not want to use a crow bar or any thing else that might cause damage to the fins ;if you have any thoughts as to how to do it I am sure open as this thing is really getting to me again it is so odd that it has always started up for the years that I have had it before this all started ; even having the carb rebuilt plus buying a new carb for a 100 bucks from a wheel horse dealer which did not help as the same issue but once I was able to get it to run once I engaged the blades the motor would die out which is odd as the belts are new and under it is clean as each time I mow I always wash it out ;now reading the Manuel I did check the trigger pins where the long pin is suppose to be set at 006 the short pin at 010 so really it should had started even using a emery board to clean both pins ;so trying to prime it and the carb bowel has fuel with the choke and the throttle opened it still will not start ;sad that I have done every thing plus more but still nothing 'there is spark off the plug and that black wire with a test light it lights up so again there is power to the plug and the plug is new so again I have compression and spark 'so really where do I go from here use it for parts Share this post Link to post Share on other sites
ebinmaine 72,609 #29 Posted September 30, 2021 2 hours ago, upstateyankee50 said: really where do I go from here use it for parts All of us have limitations on everything we do. Your tractor CAN be fixed. It's just a matter of finding the person/shop that has the knowledge and tools to repair it. You state you aren't in a rush to fix it... Maybe YOU are that person. You can set it aside. Take a class. Learn more. Read up.. Watch some videos. Buy the right tools. Maybe you'll find the person that can help. Could go either way. On the other hand using one Horse so others can be revived and live on is perfectly respectable. It's your herd. Your tractor. Your decision. And it's ok either way. 1 1 Share this post Link to post Share on other sites
Gregor 4,847 #30 Posted September 30, 2021 I understand you thinking Eric, and you are correct in everything you say, but having a tractor sitting around that didn't run, would drive me up the wall. Parting out this tratcor though would be a complete waste, IMO. 8 hours ago, upstateyankee50 said: ;a nice impact would be great An impact may not be ideal, but desperate times call for desperate measures. Removing the nut with a impact should not be a problem. Putting the nut back on, is where caution needs to be taken. Ideally a torque wrench should be used, but I'm guessing he doesn't have one of those either, and the problem with holding the flywheel arises again. The bottom line is, the nut and flywheel have to be removed, and re-installed. Sometimes a guys gotta do what a guys gotta do, but if you don't have a puller, and can't beg. borrow, steal, or buy one, removing the nut becomes a mute point. Your local Auto Zone store may have an adequate puller and torque wrench in their loaner tool program.I caution though against using a jaw type puller. Pulling on the ring gear is a really bad idea I think. Breaking off cooling fins is equally bad. An impact is how I remove an install flywheels. Yes I have paid the price a couple of times when working on my small 2 cycle engines, but I have never had a problem with a 4 stroke. Just my 1 Share this post Link to post Share on other sites
pfrederi 18,664 #31 Posted September 30, 2021 Strap wrench 1 Share this post Link to post Share on other sites
Gregor 4,847 #32 Posted September 30, 2021 Is that a Rigid? Share this post Link to post Share on other sites
pfrederi 18,664 #33 Posted September 30, 2021 OTC 7206 Made in USA Share this post Link to post Share on other sites
Gregor 4,847 #34 Posted September 30, 2021 Ordered one. Share this post Link to post Share on other sites
Ed Stoller 19 #35 Posted September 30, 2021 Background on trigger pins. The Tecumseh OEM ignition was really a Capacitance Discharge Ignition, CDI , not a magneto. With a CDI, a capacitor is charged up to several hundred volts and when this voltage is connected across the primary of a transformer, Pulse Transformer PT, a very high voltage is produced across the secondary to make the spark across the plug. The timing for the connection of the capacitor to the PT is controlled by an electronic switch, silicon controled rectifier SCR. The SCR is normally open, but it has a gate witch when it receives a small voltage, slams the SCR into conduction in a millionth of a second. This trigger voltage pulse for the gate is generated by a trigger coil with a built in magnet. Normally there is no trigger voltage as the magnetic field is constant, not changing, but when the trigger pin goes by the trigger coil , the magnetic field increases and there is a voltage generated, the trigger or timing pulse which results in a spark. More on the replacement ignition later, but you do not need to remove the flywheel to install it and it only costs $60. I would be glad to help you. EdStoller@earthlink.net, enginesandmagnets.com New Replacement Ignition, General Information General GM LS2 General.mp4 https://youtu.be/0p35PJwJ04o Trigger Pins GM LS2 Trigger Pins.mp4 , https://youtu.be/eMvB0-DIFEo Installations Kohler 161 Installation GM LS2 PC2short1.mp4 https://youtu.be/-2jHuThQHz4 GM LS2 PC2shortP2.mp4 https://youtu.be/XvkX2KbZClg ONAN NB Installation https://www.youtube.com/watch?v=b5CXlirfTqc Tecumseh HH120 Installation, Tecumseh.mp4 https://youtu.be/WsMY5D-q6pQ Kohler Command Ignition https://youtu.be/zXz-Q1z7A-s 3 2 Share this post Link to post Share on other sites
ebinmaine 72,609 #36 Posted September 30, 2021 39 minutes ago, Ed Stoller said: Background on trigger pins Well how about that. Ed is THE MAN on these things. Some impressive videos on YouTube showing us how to keep these engines running long after many others have given up on them. 1 Share this post Link to post Share on other sites
upstateyankee50 59 #37 Posted September 30, 2021 10 hours ago, ebinmaine said: All of us have limitations on everything we do. Your tractor CAN be fixed. It's just a matter of finding the person/shop that has the knowledge and tools to repair it. You state you aren't in a rush to fix it... Maybe YOU are that person. You can set it aside. Take a class. Learn more. Read up.. Watch some videos. Buy the right tools. Maybe you'll find the person that can help. Could go either way. On the other hand using one Horse so others can be revived and live on is perfectly respectable. It's your herd. Your tractor. Your decision. And it's ok either way. thanks and really it would be great to get it to run ;in time and no I will not part it out as one day I will figure out the issue ;again most shops here which are 3 - a few has closed down due to the virus the other wants 85 an hour but they are backed up for 8 weeks or more ;being stubborn and bull headed I am not a quitter ;again I have 3 other horses if needed so I have all of the time in the world to tinker with it ;thanks for your thoughts Share this post Link to post Share on other sites
upstateyankee50 59 #38 Posted September 30, 2021 22 minutes ago, ebinmaine said: Well how about that. Ed is THE MAN on these things. Some impressive videos on YouTube showing us how to keep these engines running long after many others have given up on them. yep I have been watching the video's on you tube and some do help ;in time I will get it to run as really it can't be that serious ; thanks again Share this post Link to post Share on other sites
upstateyankee50 59 #39 Posted September 30, 2021 1 hour ago, Ed Stoller said: Background on trigger pins. The Tecumseh OEM ignition was really a Capacitance Discharge Ignition, CDI , not a magneto. With a CDI, a capacitor is charged up to several hundred volts and when this voltage is connected across the primary of a transformer, Pulse Transformer PT, a very high voltage is produced across the secondary to make the spark across the plug. The timing for the connection of the capacitor to the PT is controlled by an electronic switch, silicon controled rectifier SCR. The SCR is normally open, but it has a gate witch when it receives a small voltage, slams the SCR into conduction in a millionth of a second. This trigger voltage pulse for the gate is generated by a trigger coil with a built in magnet. Normally there is no trigger voltage as the magnetic field is constant, not changing, but when the trigger pin goes by the trigger coil , the magnetic field increases and there is a voltage generated, the trigger or timing pulse which results in a spark. More on the replacement ignition later, but you do not need to remove the flywheel to install it and it only costs $60. I would be glad to help you. EdStoller@earthlink.net, enginesandmagnets.com New Replacement Ignition, General Information General GM LS2 General.mp4 https://youtu.be/0p35PJwJ04o Trigger Pins GM LS2 Trigger Pins.mp4 , https://youtu.be/eMvB0-DIFEo Installations Kohler 161 Installation GM LS2 PC2short1.mp4 https://youtu.be/-2jHuThQHz4 GM LS2 PC2shortP2.mp4 https://youtu.be/XvkX2KbZClg ONAN NB Installation https://www.youtube.com/watch?v=b5CXlirfTqc Tecumseh HH120 Installation, Tecumseh.mp4 https://youtu.be/WsMY5D-q6pQ Kohler Command Ignition https://youtu.be/zXz-Q1z7A-s thanks so much for the information and the video's ;they are a big help Share this post Link to post Share on other sites
ebinmaine 72,609 #40 Posted November 20, 2021 @Gregor Did you satisfy your mental curiosity about the ignition system? Share this post Link to post Share on other sites
Gregor 4,847 #41 Posted November 20, 2021 1 hour ago, ebinmaine said: @Gregor Did you satisfy your mental curiosity about the ignition system? To a point. I'm still on the hunt for a Tecky with this type of ignition system. 1 Share this post Link to post Share on other sites
ebinmaine 72,609 #42 Posted November 20, 2021 4 minutes ago, Gregor said: To a point. I'm still on the hunt for a Tecky with this type of ignition system. If shipping was less expensive I'd send ya one. 1 Share this post Link to post Share on other sites
formariz 12,041 #43 Posted November 20, 2021 On 9/30/2021 at 11:52 AM, Gregor said: Is that a Rigid? With that kind of artwork on wall it better be Rigid. 2 Share this post Link to post Share on other sites
SylvanLakeWH 28,392 #44 Posted November 20, 2021 (edited) 48 minutes ago, formariz said: With that kind of artwork on wall it better be Rigid. Again with the visuals… oh wait… those visuals… never mind… Edited November 20, 2021 by SylvanLakeWH 1 Share this post Link to post Share on other sites
ebinmaine 72,609 #45 Posted November 20, 2021 On 9/30/2021 at 12:33 PM, Gregor said: Ordered one. Yep me too. Thanks for that tool number @pfrederi Paul. 33 minutes ago, formariz said: With that kind of artwork on wall it better be Rigid. Share this post Link to post Share on other sites
Gregor 4,847 #46 Posted November 20, 2021 I'm just gonna leave this alone. Share this post Link to post Share on other sites
Snoopy11 5,718 #47 Posted November 20, 2021 On 9/29/2021 at 8:52 PM, upstateyankee50 said: yep you are right but first I need to find away to remove the nut as not to damage the fly wheel ;as there is no way that I can stop the wheel from turning ;a nice impact would be great but that is one item I do not have tomorrow is another day ;thanks again An old mechanic taught me this. Take a screwdriver, a nice long one, put a rubber plug on the end... such as one of these: And put the screwdriver down into the spark plug hole, rotating the engine over until the screwdriver stops piston movement. Then use a breaker bar to remove the flywheel nut. Boom... Don Share this post Link to post Share on other sites
Snoopy11 5,718 #48 Posted November 21, 2021 9 minutes ago, Gregor said: I'm just gonna leave this alone. Don Share this post Link to post Share on other sites
