John2189 573 #1 Posted September 8, 2021 Of the side and rear discharge mower deck? Share this post Link to post Share on other sites
Pullstart 68,981 #2 Posted September 8, 2021 Side discharge seems to disperse the clippings across the yard, rear discharge seems to disperse them along the transmission. With automatic rigs especially, the SD seems like the way to go. If you prefer to sweep your lawn though, the RD tosses the clippings right into the sweeper’s path. 3 Share this post Link to post Share on other sites
lynnmor 8,646 #3 Posted September 8, 2021 Wheel Horse made several different 42” rear discharge decks, some with partial baffles and some with the complete baffling that fully contains the clippings so they are recut many times. I have a completely open deck that leaves ugly windrows if not swept. I use it for fall cleanup with a sweeper. 1 Share this post Link to post Share on other sites
stevasaurus 23,627 #4 Posted September 8, 2021 They both have their pluses. I had a 42" side discharge on a Rader 10. It would throw the grass half way across the yard. You always want to have the discharge facing the mowed grass and not into the grass that is not cut yet. I did find that I had to usually mow the lawn a second time, running over the lines of cut grass to cut them again and spread out. My 36 rear discharge desks also do a nice job, but if I let the grass get too long, I find it best to back the tractor over the long grass and then mow it forward. If it is not long, I can just mow it and be done. One plus with the rear discharge, when the leaves first start to fall, I can back over the leaves and the deck will actually mulch the leaves and then go forward. 2 1 Share this post Link to post Share on other sites
WHX?? 55,257 #5 Posted September 8, 2021 I prefer the rears as they don't have a tendency to thrown rocks and pinecones at warp speeds causing any grief. Yes you can run with a deflector on SDs but then the wind rows... especially if the grass gets away on you abit. Almost have to bale it then! 2 1 Share this post Link to post Share on other sites
Achto 31,133 #6 Posted September 8, 2021 One advantage to a RD that I like is that you can mow close to objects on either side of the deck. 5 1 1 Share this post Link to post Share on other sites
peter lena 9,782 #7 Posted September 8, 2021 @lynnmor, all my r/d decks do not have baffling , removed in two of them , have no debris lines or any build up , don,t use a sweeper . always cut at highest setting , just me , pete 1 1 Share this post Link to post Share on other sites
peter lena 9,782 #8 Posted September 8, 2021 @Achto, agree with you that , have a series of property posts that are a non issue with the r/d decks , pete 1 Share this post Link to post Share on other sites
JoeM 9,650 #9 Posted September 8, 2021 2 hours ago, stevasaurus said: My 36 rear discharge desks also do a nice job, but if I let the grass get too long, I find it best to back the tractor over the long grass and then mow it forward. If it is not long, I can just mow it and be done. One plus with the rear discharge, when the leaves first start to fall, I can back over the leaves and the deck will actually mulch the leaves and then go forward. Mowed with one for several years same same. I have more now so went up to more bigger sidewinder. Share this post Link to post Share on other sites
roadapples 6,987 #10 Posted September 8, 2021 I've only ever used side discharge. My brother has a 36" rear discharge which throws everything at the left rear wheel. It's always black... Share this post Link to post Share on other sites
peter lena 9,782 #11 Posted September 8, 2021 @JoeM agree with the mowing backwards in the fall, added feature of that , is with dry leaves , it almost does a leaf blast on the deck cleaning . pete 2 Share this post Link to post Share on other sites
peter lena 9,782 #12 Posted September 8, 2021 @roadapples he can always add the back of deck rubber deflector , could be worth a try , pete 1 Share this post Link to post Share on other sites
daveoman1966 3,882 #13 Posted September 8, 2021 A rear discharge deck won't throw stones thru your brand new vinyl siding...don't ask how I know this. Share this post Link to post Share on other sites
varosd 1,185 #14 Posted September 8, 2021 Agree with all above had 36 RD and 42RD but loved my 48 SD… 1 Share this post Link to post Share on other sites
squonk 45,613 #15 Posted September 8, 2021 RD or go home. I have a rubber flap on the back that keeps the tires and hydro clean. 3 Share this post Link to post Share on other sites
Handy Don 16,018 #16 Posted September 8, 2021 42" RD with 4" flap. Mowing in a grove of trees it is SO much easier than its SD predecessor and we haven't noticed any particular accumulation of clippings anywhere on the tractor. 1 Share this post Link to post Share on other sites
