dkg520 528 #1 Posted August 29, 2021 Does anyone here know who sells a high back 520 seat replacement that has the correct bolt pattern? I’ve tried Tractor Supply Store and Agri Supply and have had no luck. Thanks. Share this post Link to post Share on other sites
cschannuth 3,821 #2 Posted August 29, 2021 @dclarke found one for his and he helped me find one for mine but for the life of me I can’t find where I ordered it. Knowing Denny, he’ll be able to tell us right away where we got our seats. I’m sure he’ll be along shortly to help you out. Share this post Link to post Share on other sites
peter lena 9,846 #3 Posted August 29, 2021 @dkg520 have 3 of these seats , bolt down w/h pattern , verify with seat bolt pattern on lower edge of page , https://www.agrisupply.com/universal-tractor-seat/p/14119/?sid=asf10&eid=Easf10&zmam=77232640&zmas=1&zmac=1&zmap=14119&eid=gl020116&sid=google&gclid=CjwKCAjw4KyJBhAbEiwAaAQbE74jbKPkZZY59phqKCpbjvkNyQJOflJl79uXF_O66YL8LOJWfBhuihoCJiIQAvD_BwE believe 7 1/2 x 7 , check your base mount set up . bolted right on , years now , no problems , pete Share this post Link to post Share on other sites
Lee1977 7,632 #4 Posted August 29, 2021 2 hours ago, peter lena said: @dkg520 have 3 of these seats , bolt down w/h pattern , verify with seat bolt pattern on lower edge of page , https://www.agrisupply.com/universal-tractor-seat/p/14119/?sid=asf10&eid=Easf10&zmam=77232640&zmas=1&zmac=1&zmap=14119&eid=gl020116&sid=google&gclid=CjwKCAjw4KyJBhAbEiwAaAQbE74jbKPkZZY59phqKCpbjvkNyQJOflJl79uXF_O66YL8LOJWfBhuihoCJiIQAvD_BwE believe 7 1/2 x 7 , check your base mount set up . bolted right on , years now , no problems , pete I think all the 500's have 7 1/2" wide by 8" deep bolt pattern. I know my 520 has that bolt pattern. I had a better set of seat tracks I was going to use but they would not fit. 2 Share this post Link to post Share on other sites
dclarke 4,117 #5 Posted August 29, 2021 4 hours ago, cschannuth said: @dclarke found one for his and he helped me find one for mine but for the life of me I can’t find where I ordered it. Knowing Denny, he’ll be able to tell us right away where we got our seats. I’m sure he’ll be along shortly to help you out. Craig, We got those seats from “turf seats.com”… I believe I used the “KM123” and you bought the “KM125”, which has a higher back….. I think. Lol….. dkg520, be sure to check the bolt pattern if you decide to order one of these but I’m pretty sure they are correct. Share this post Link to post Share on other sites
cschannuth 3,821 #7 Posted August 30, 2021 4 hours ago, Lee1977 said: 500's have 7 1/2" wide by 8" deep bolt pattern. I know my 520 has that bolt pattern. I had a better set of seat tracks I was going to use but they would not fit The 520’s are definitely an oddball bolt pattern. The seats Denny suggested have a pattern that matches. Share this post Link to post Share on other sites
dclarke 4,117 #8 Posted August 30, 2021 dkg, this will give you an idea of what that seat looks like on a 520. 1 1 Share this post Link to post Share on other sites
dkg520 528 #9 Posted August 30, 2021 Is that the low back seat? Share this post Link to post Share on other sites
dclarke 4,117 #10 Posted August 30, 2021 2 hours ago, dkg520 said: Is that the low back seat? Yes.. The KM123 Share this post Link to post Share on other sites
cschannuth 3,821 #11 Posted August 30, 2021 3 hours ago, dkg520 said: Is that the low back seat? Here’s the one Denny helped me find. Like he said, I think it’s the same seat with a little bit higher back. 1 Share this post Link to post Share on other sites
lynnmor 8,737 #13 Posted August 30, 2021 Did you see my post under “seat cover” ? Share this post Link to post Share on other sites
