Pullstart 71,160 #27 Posted September 14, 2021 Did you just cut and hand shape those fenders Jon? They look perfect! Share this post Link to post Share on other sites
giddyap 1,574 #28 Posted September 15, 2021 22 hours ago, pullstart said: Did you just cut and hand shape those fenders Jon? Thanks for asking but I'm no fabicator. I do believe in sharing, for what its worth here is a photo of what I did. I salvaged the sheet metal from a water heater. Its very flimsey and easy to cut but with a rivet every inch the fender became solid after installation. There are a number of ways to make the sides uniform 2 Share this post Link to post Share on other sites
Pullstart 71,160 #29 Posted September 15, 2021 My eyes must have been playing with me the other day. Now I see what you’re saying, they’re riveted to the tub. Fabricator or not, you’re making another cool custom! 1 Share this post Link to post Share on other sites
giddyap 1,574 #30 Posted September 17, 2021 First ride is in the books,...now burn the book After trying everything I know I could not stop or even slow the drive belt to get it in gear. I fiddled with differnt belt stops in diffent positions to no avail. The belt was very tight because I pulled the engine with a turnbuckle and now it is too loose. Since the engine tie down bolts are hard to reach. My next step is the remove the mounting plate with the engine bolted down and make slots in the plate. This will make adjusting the belt tension much easier. 3 Share this post Link to post Share on other sites
ebinmaine 80,461 #31 Posted September 17, 2021 2 hours ago, giddyap said: The belt was very tight because I pulled the engine with a turnbuckle and now it is too loose. Since the engine tie down bolts are hard to reach. My next step is the remove the mounting plate with the engine bolted down and make slots in the plate. This will make adjusting the belt tension much easier I like the sliding plate idea. I've found from past experience that there can be a VERY fine line when positioning an engine. 1 Share this post Link to post Share on other sites
giddyap 1,574 #32 Posted October 3, 2021 My custom is within 1% of being completed but I had to put it on hold. With the comming of fall, I realized I needed to complete many of my summer projects around the house. Then with my daughter's birthday close to Halloween I thought the grandkids would enjoy a haunted hayride and so I fitted the trailor I made last year with benches. The 314-8 is new to me and will be used to push snow. 3 2 Share this post Link to post Share on other sites
giddyap 1,574 #33 Posted December 3, 2021 (edited) Final pictures of my completed custom, my 4th. The 301 Hemi was nothing like the 212. The governor could not be overriden, it had to be completely removed. I had to reinvent the throttle linkage all because I did not know how to join a couple of 212s, but now I know how. (looking for a new home) Edited December 3, 2021 by giddyap addition 3 3 Share this post Link to post Share on other sites
953 nut 68,796 #34 Posted December 3, 2021 On 9/17/2021 at 8:13 AM, giddyap said: After trying everything I know I could not stop or even slow the drive belt to get it in gear. Sorry I wasn't keeping up with this thread. You nerd to mount a piece of angle iron under the full length of the drive belt, with the clutch pushed in the slack of the belt will fall onto the angle iron and stop. Same concept as the belt guard. 2 Share this post Link to post Share on other sites
ebinmaine 80,461 #35 Posted December 4, 2021 1 hour ago, giddyap said: completed custom, my 4th As usual. Beautiful machine. 1 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #36 Posted December 4, 2021 (edited) Don Edited December 20, 2021 by Snoopy11 Share this post Link to post Share on other sites
giddyap 1,574 #37 Posted December 4, 2021 55 minutes ago, 953 nut said: You nerd to mount a piece of angle iron under the full length of the drive belt, Here is a picture of the "stop belt" I used from "is this damper important" 2 Share this post Link to post Share on other sites
953 nut 68,796 #38 Posted December 4, 2021 10 hours ago, giddyap said: "is this damper important" It takes up some of the rapid movement of the spring when your foot comes off the clutch. As said previously, a piece of angle iron below the belt will solve your gear grinding problem. This photo is on a 953. Belt is slightly above angle iron when operating and slack is caught by it when the clutch is in. Share this post Link to post Share on other sites
Handy Don 17,382 #39 Posted December 4, 2021 (edited) 20 minutes ago, 953 nut said: This photo is on a 953. Please help my curiosity and tell me what is being driven but this belt and pulley?! Thanks. Edited December 4, 2021 by Handy Don Share this post Link to post Share on other sites
Maxwell-8 4,371 #40 Posted December 4, 2021 1 hour ago, Handy Don said: Please help my curiosity and tell me what is being driven but this belt and pulley?! Thanks. a hydraulic pump 1 1 1 Share this post Link to post Share on other sites
Maxwell-8 4,371 #41 Posted December 4, 2021 12 hours ago, giddyap said: "is this damper important" nope, and a pleasure to be rid off... 1 Share this post Link to post Share on other sites
giddyap 1,574 #42 Posted December 5, 2021 8 hours ago, Maxwell-8 said: nope, and a pleasure to be rid off After I removed the damper from the clutch pulley the unintentional wheel stands stopped. At that time I also replaced the 6" tranny pulley with a 4" and shorter belt for a slightly faster tractor. But the new belt was slightly long and created too much chatter. So, today it went under a 2 hour operation to replace the orginal parts except for the damper. My 314-8 2 2 Share this post Link to post Share on other sites
kpinnc 18,916 #43 Posted December 7, 2021 On 12/4/2021 at 9:43 AM, Maxwell-8 said: a hydraulic pump I love it! 1 Share this post Link to post Share on other sites
Handy Don 17,382 #44 Posted December 7, 2021 On 12/4/2021 at 9:43 AM, Maxwell-8 said: a hydraulic pump Ah! Downloaded the IPL to get more info and realized its one of the "self-contained" units like the HY options for other early WHs. Nifty bit of engineering, that. 2 Share this post Link to post Share on other sites
Snoopy11 5,731 #45 Posted December 19, 2021 (edited) Don Edited December 20, 2021 by Snoopy11 Share this post Link to post Share on other sites
giddyap 1,574 #46 Posted December 20, 2021 3 hours ago, Snoopy11 said: Good answer Giddy... Forgive me, I should have recognized your comment, but it is my constitutional right to remain silent. Sharing your bad experience to spare others is very noble and I really appreicate your warning. It is worth breaking my silence to mend any hard feelings I may have caused but then again I still did not answer your question. Now I must plead the 5th. I know my humor sucks, but my apology is sincere. 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #47 Posted December 20, 2021 19 minutes ago, giddyap said: Forgive me, I should have recognized your comment, but it is my constitutional right to remain silent. Sharing your bad experience to spare others is very noble and I really appreicate your warning. It is worth breaking my silence to mend any hard feelings I may have caused but then again I still did not answer your question. Now I must plead the 5th. I know my humor sucks, but my apology is sincere. Oh no sir! Not at all... I was using humor myself. I know... that... if you wanted to answer... you would have... (I get it...) Don 1 Share this post Link to post Share on other sites
Snoopy11 5,731 #48 Posted December 20, 2021 (edited) @giddyap Note... powertrain comment removed... (no issue here)... and don't want to cause one! Don Edited December 20, 2021 by Snoopy11 Share this post Link to post Share on other sites
