squonk 48,072 #51 Posted August 5, 2021 (edited) 1 hour ago, ebinmaine said: Here in New England we have a wicked crown in the road on everything but the largest of highways. To keep your tires wearing evenly you have to be able to switch them side to side. The shops I've worked with, and for, have always done a cross rotation on one axle and a straight fore and aft rotation on the other axle. When rotating you cross the non driving axle tires. On AWD vehicles: Left rear goes to right front. Right rear goes to the left front. Right front goes to left rear. Left front goes to the right rear Edited August 5, 2021 by squonk 2 Share this post Link to post Share on other sites
Gregor 4,848 #52 Posted August 5, 2021 (edited) I use to take my Nissan Titan to the dealership for oil changes. During one such visit, they told me they would rotate my tires free, as a courtesy service. I said fine. Years ago my grand daughter put a scratch in the right front wheel with her trike. Nothing terrible, but noticeable. When I got my truck back, that scratch was still on the right front wheel. I guess courtesy services are not what they use to be. On one such visit they said they checked the cabin air filter, and it was fine. It never had a filter in it when I bought it. I don't go there anymore. Edited August 5, 2021 by Gregor 2 2 Share this post Link to post Share on other sites
WHX?? 58,071 #53 Posted August 5, 2021 9 hours ago, Jeff-C175 said: NOT grease the lug nutz. Had some trailer wheels once that the nutz were brown welded on. When they went back on they got anti seized. Worked ok but sure did make a mess. Mighta got carried away with the silver stuff ...wadda ya know about that Kev??? 45 minutes ago, pullstart said: loud and clear Mike! I hear tell he sleeps vertical too! 2 Share this post Link to post Share on other sites
WHX?? 58,071 #54 Posted August 5, 2021 18 minutes ago, Gregor said: ot my truck back, that scratch was still on the right front wheel. Some folks actually mark the tires in a inconspicuous spot to see if it tires were rotated. Can't find good help these days. 1 1 Share this post Link to post Share on other sites
ebinmaine 80,641 #55 Posted August 5, 2021 1 minute ago, WHX?? said: folks actually mark the tires A good tech Will mark their own tires... 1 Share this post Link to post Share on other sites
WHX?? 58,071 #56 Posted August 5, 2021 9 minutes ago, ebinmaine said: A good tech What did I just say about the help!?!?! 2 Share this post Link to post Share on other sites
RandyLittrell 3,945 #57 Posted August 5, 2021 On 8/4/2021 at 8:44 AM, WHX?? said: I said that once too Pack till I had some come loose and ruin the rim. And new cars have such thin rotors, you can warp them by over torquing. Randy 4 Share this post Link to post Share on other sites
tom2p 2,396 #58 Posted August 5, 2021 (edited) my 'lug nut' story decades ago ... late 70's / early 80's I had a 70 SS Chevelle I was planning to sell a friend with a 70 SS Chevelle (pictured below) wanted to swap wheels / tires since my wheels and trim rings were in better shape ... so he swapped them on the way home from his garage in my 70 SS I was on an open stretch on the highway and opened it up and went through the gears - then all of the sudden the car began to knock and vibrate my heart sunk as I thought the worst ... oh no ... rod or crank bearing ... but then as I slowed to a stop pushed the clutch in and blipped the gas lightly - the knock did not increase and then stopped when the car came to a stop ok ... but wth pulled into an empty parking lot and discovered the front lug nuts were loose and backing off ... ughhh ! Edited August 5, 2021 by tom2p 2 Share this post Link to post Share on other sites
lynnmor 9,037 #59 Posted August 5, 2021 In PeeA, we have to endure an annual “safety” inspection, one example of numerous faulty work was my F250 lug nuts were torqued to 70 ft lbs instead of the required 140. Safety my XXX, these inspections can kill you. 3 Share this post Link to post Share on other sites
ebinmaine 80,641 #60 Posted August 5, 2021 46 minutes ago, tom2p said: lug nuts were loose I once worked as a parts tech at a then GM/formerly Subaru garage. The Scoobies were famous for having VERY stuck rims as mentioned earlier. One of the techs told me they would back every lug nut out about 2 turns and go drive around the dealer lot making corners until the rims let loose from the spindle/rotor/drum. 2 Share this post Link to post Share on other sites
WHX?? 58,071 #61 Posted August 5, 2021 40 minutes ago, lynnmor said: In PeeA, we have to endure an annual “safety” inspection, one example of numerous faulty work was my F250 lug nuts were torqued to 70 ft lbs instead of the required 140. Safety my XXX, these inspections can kill you. Holy crap they must think you PA boys run NASCAR! 1 Share this post Link to post Share on other sites
kpinnc 18,939 #62 Posted August 6, 2021 (edited) On 8/4/2021 at 9:35 AM, pfrederi said: I use German torque Gutten tight.... I'm one who does this too. There are 3 standard levels of torque: 1. Guudensnuggin- open end wrench tight. 2. Guudentite- 1/2 inch rachet tight. 3. Fuuchentorqen- impact driver tight. I do re-tap or chase the hub threads any time I remove a wheel and anti-sieze the crap out of the bolts. Same goes for the bolts if they need it. I've never had a wheel loosen, but I've never had to use a breaker bar to remove a lug either. Edited August 6, 2021 by kpinnc 3 Share this post Link to post Share on other sites
Horse Newbie 7,405 #63 Posted August 7, 2021 (edited) On 8/5/2021 at 6:49 AM, Gregor said: radial tires, I don't believe you change position side to side when rotating tires I heard, I believe, at Discount Tires, that DID apply to radials back in the day, but now they do switch sides with the modern radials. If you want to include your spare, they will include it in the rotation... Edited August 7, 2021 by Horse Newbie 1 Share this post Link to post Share on other sites
Horse Newbie 7,405 #64 Posted August 7, 2021 (edited) Can you believe 3 pages on the subject of lug nut torque ?... I just tighten mine... Edited August 7, 2021 by Horse Newbie 1 2 Share this post Link to post Share on other sites
roadapples 6,987 #65 Posted August 7, 2021 On 8/5/2021 at 12:32 PM, WHX?? said: Holy crap they must think you PA boys run NASCAR! My owners manual calls for 140 ft lbs on lug nuts... 1 1 Share this post Link to post Share on other sites
RandyLittrell 3,945 #66 Posted August 7, 2021 11 hours ago, Horse Newbie said: Can you believe 3 pages on the subject of lug nut torque ?... I just tighten mine... Just bring up the best oil to run and see how many pages you get!! Randy 2 Share this post Link to post Share on other sites
squonk 48,072 #67 Posted August 7, 2021 (edited) 14 hours ago, roadapples said: My owners manual calls for 140 ft lbs on lug nuts... 2 nuts don't take long to torque! My nuts get torqued every time @elcamino/wheelhorse mentions my name! Edited August 7, 2021 by squonk 2 3 Share this post Link to post Share on other sites
squonk 48,072 #68 Posted August 7, 2021 15 hours ago, Horse Newbie said: Can you believe 3 pages on the subject of lug nut torque ?... I just tighten mine... I came into here today to post this fact. You beat me too it! 1 1 Share this post Link to post Share on other sites
Horse Newbie 7,405 #69 Posted August 7, 2021 While I may sound cynical, I did read every post and put a high value on my Redsquare/ Wheel Horse edumacation ! 1 Share this post Link to post Share on other sites
kpinnc 18,939 #70 Posted August 7, 2021 (edited) 4 hours ago, squonk said: Can you believe 3 pages on the subject of lug nut torque ?... I just tighten mine... I can't speak for everyone, but for me at least- every old fart has an opinion that is important to share. I can spend an hour discussing the color of AIR. I'm a poet and I know it too. Edited August 7, 2021 by kpinnc 1 Share this post Link to post Share on other sites
ebinmaine 80,641 #71 Posted August 7, 2021 40 minutes ago, kpinnc said: discussing the color of AIR NOW YA DONE IT!!! Share this post Link to post Share on other sites
Gregor 4,848 #72 Posted August 7, 2021 1 hour ago, kpinnc said: I can spend an hour discussing the color of AIR. I hear it's not too good in Minnesota right now. Share this post Link to post Share on other sites
ebinmaine 80,641 #73 Posted August 7, 2021 5 minutes ago, Gregor said: I hear it's not too good in Minnesota right now. Maine either Share this post Link to post Share on other sites
kpinnc 18,939 #74 Posted August 7, 2021 Dear God I guess that qualifies as a hijack... Share this post Link to post Share on other sites
cschannuth 3,821 #75 Posted August 7, 2021 (edited) On 8/5/2021 at 5:49 AM, Gregor said: On radial tires, I don't believe you change position side to side when rotating tires. When radial tires first came out decades ago you were not supposed to switch them side to side but it’s perfectly fine now. The belts were prone to shifting back then I believe. Edited August 7, 2021 by cschannuth 1 Share this post Link to post Share on other sites
