gwest_ca-(File Mod) 11,838 #1 Posted July 31, 2021 Can someone tell me what color the NMIR override indicator lamp is? Found a cruise control switch with a green lens in it. Have never seen any of these newer models. Garry Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,838 #3 Posted August 1, 2021 Thank you Share this post Link to post Share on other sites
peter lena 9,552 #4 Posted August 1, 2021 @gwest_ca, what is the concept of having a no mow in reverse switch? I regularly cut in reverse on my lawn without a second thought , in tight areas . my decks are clean and the blades are sharp , no difference in finish cut , my horses are all 12 hp magnum powered , with R/D decks , just asking , pete Share this post Link to post Share on other sites
pfrederi 19,208 #5 Posted August 1, 2021 8 minutes ago, peter lena said: @gwest_ca, what is the concept of having a no mow in reverse switch? I regularly cut in reverse on my lawn without a second thought , in tight areas . my decks are clean and the blades are sharp , no difference in finish cut , my horses are all 12 hp magnum powered , with R/D decks , just asking , pete Safety you have to take some positive action if you want to mow backing up. So you don't run over your kids/pets following you. Only machine I have with it is a JD GT-235 real PITA. 1 Share this post Link to post Share on other sites
peter lena 9,552 #6 Posted August 1, 2021 @pfrederi just got thru cutting , kids are long gone , don't have any pets , only thing behind me was the spiker aerator that i tow , with birds following that on exposed worms' in the ground . also never cut mine the same way twice , at the highest setting. good day for it , pete 2 Share this post Link to post Share on other sites
