Chrishar 985 #1 Posted July 30, 2021 Had a wheel horse given to me it was sitting for about 10 years in a shed need to know what year and model it is and what fluid goes in the transmission looks to be in good shape the numbers I found are 17241 618706 and it has wheel horse wrote on the tires 7 3 Share this post Link to post Share on other sites
Achto 31,885 #2 Posted July 30, 2021 4 hours ago, Chrishar said: the numbers I found are 17241 618706 Model 1 7241 is a 1969 Charger 12 Nice find 3 Share this post Link to post Share on other sites
Retired Wrencher 6,693 #3 Posted July 30, 2021 Chris should be a good tractor when you have gone thru it. Just take your time. 1 Share this post Link to post Share on other sites
953 nut 66,392 #4 Posted July 30, 2021 The Charger has a Sundstrand that would have exited the factory with Dexron Automatic Transmission Fluid (ATF). At some point that may have been changed over to 10 W 30motor oil. Remove the dipstick from the transmission and use a white paper towel to see what color the fluid is. If it is pink you have ATF and if it is amber it is 10 W 30. If it is ATF buy some Valvoline Mercon which is a direct replacement for Dexron.. You will also want to replace the filter which is NAPA 1410 (Wix 51410) https://www.walmart.com/ip/Valvoline-Mercon-V-Conventional-Automatic-Transmission-Fluid-ATF-1-QT/197728252?wmlspartner=wlpa&selectedSellerId=0&&adid=22222222227000000000&wl0=&wl1=g&wl2=c&wl3=42423897272&wl4=aud-1396569494572:pla-51320962143&wl5=9032504&wl6=&wl7=9010285&wl8=&wl9=pla&wl10=8175035&wl11=online&wl12=197728252&veh=sem&gclid=CjwKCAjwxo6IBhBKEiwAXSYBs0fFqfK-YL_GONRDH2_ujdATk4Pu7-8a-i5-zQaTxkTxr5irWf7VdxoCBCIQAvD_BwE&gclsrc=aw.ds 2 3 Share this post Link to post Share on other sites
Ed Kennell 46,153 #5 Posted July 30, 2021 (edited) 5 hours ago, Chrishar said: what fluid goes in the transmission It could be ATF or motor oil. Do not mix the two. Oops, I see Richard has your answer. Edited July 30, 2021 by Ed Kennell 1 Share this post Link to post Share on other sites
Ed Kennell 46,153 #6 Posted July 30, 2021 Nice find. I always liked the early spring loaded front mule drive. And yours even has the belt guard. 1 Share this post Link to post Share on other sites
Chrishar 985 #7 Posted July 31, 2021 Thanks for the information hoping to get it to ran soon Share this post Link to post Share on other sites
Chrishar 985 #8 Posted August 1, 2021 (edited) That mule drive will be coming off and I will sell it Edited August 1, 2021 by Chrishar Share this post Link to post Share on other sites
AHS 1,675 #9 Posted August 1, 2021 Nice metal!! It hasn’t been used much! Also the coil looks to be original too!😀 Share this post Link to post Share on other sites
oliver2-44 11,503 #10 Posted August 1, 2021 Nice find @Chrishar You have the best luck finding old tractors around here. I might be interested in that mule drive @Ed Kennell Would that type mule drive work on my 1056 and with it could I run a newer type 36” or 42” deck Share this post Link to post Share on other sites
Chrishar 985 #11 Posted August 3, 2021 I was looking at the motor last night and found the governor is not hook up does anybody have picture how the throttle and chock cables and governor are hook up on the motor any information thanks Share this post Link to post Share on other sites
pfrederi 20,625 #12 Posted August 3, 2021 (edited) Wrong picture sorry Edited August 3, 2021 by pfrederi Share this post Link to post Share on other sites
pfrederi 20,625 #13 Posted August 3, 2021 Better pic Share this post Link to post Share on other sites
pfrederi 20,625 #14 Posted August 3, 2021 (edited) Throttle cable (yellow) comes under exhaust behind governor arm through the clip on the breather and to bottom end of rocker bar. Choke come up from under the air shroud Edited August 3, 2021 by pfrederi Share this post Link to post Share on other sites
Handy Don 16,710 #15 Posted August 4, 2021 5 hours ago, pfrederi said: Better pic A bit sloppy, but both look to be in the correct orientation. Share this post Link to post Share on other sites
Chrishar 985 #16 Posted August 4, 2021 Thank y'all for the pictures it was a good help for me I'll keep y'all posited on the progress im planning on using it to pull barrels rides round Share this post Link to post Share on other sites
pfrederi 20,625 #17 Posted August 4, 2021 11 hours ago, Handy Don said: A bit sloppy, but both look to be in the correct orientation. It was a before picture I took so I could remember what it was supposed to be. Second pic is same engine after overhaul. but it isn't installed yet. Share this post Link to post Share on other sites
Chrishar 985 #18 Posted August 5, 2021 So I'm looking for a part number for a ignition switch that i can used and I'm putting a solenoid on it so I just need a cheap one Share this post Link to post Share on other sites
Handy Don 16,710 #19 Posted August 5, 2021 On 8/4/2021 at 9:18 AM, pfrederi said: It was a before picture I took so I could remember what it was supposed to be. Second pic is same engine after overhaul. but it isn't installed yet. Makes sense. The "after" is looking good! Share this post Link to post Share on other sites
