ebinmaine
New-to-me Horse (and other stuff) Hauler!!
ebinmaine
kpinnc
You might wanna bungee that tank somewhere. :P
  • Haha 3
ebinmaine
:no:
I can't help if you ain't got no sense of adventure.
  • Haha 3
MainelyWheelhorse
Posted (edited)
Just kidding @ebinmaine You did want a HOT rod....:teasing-poke:
1 hour ago, ebinmaine said:
:no:
Edited by MainelyWheelhorse
  • Haha 4
ebinmaine
This evening we finished cleaning the cable ends. I built a new positive cable from solenoid to starter.
Degreased the starter and engine block where the cables attach.
Installed a NOS Cole Hersee solenoid from my parts department.  Added a new battery hold down.
Used a primer bulb to dump a little gasoline into the carburetor bowl through the upper vent.
At that point the ole beast started right up.... and the alternator started smoking. No worries there. I knew that was a high probability.
I have a new HD alternator set aside with a new wiring harness.
The truck is setting in the front yard waiting to be towed to the repair shop tomorrow.
  • Excellent 5
ebinmaine
Went to see Libby's Service Station where my truck is... Very positive so far.
He's using it as a spare time project in between other things, which is exactly what I hoped he would do.
Rick has laid out and organized all the parts, and has some of the initial assembly done. He says it all looks OK so far without having attempted actual installation.
I'm bringing them a full set of rear brake shoes, springs, and hardware Monday afternoon.
We both figured he might as well go right from wheel to wheel with ALL new parts.
ebinmaine
Today was another shining example that there are still decent people in this world.
While setting for lunch I got a phonecall from Rick Libby.
Rear axle done.
Truck ready to be picked up so I can install rear lamps and splash guards along with whatever other State Inspection work I find it needs.
I said, "Do you have the dollar amount?"
Now - let's go over what was done.
A BUNCH of cleaning and rust removal.
ALL NEW PARTS installed in the entire axle.
Center carrier. Change from open Ford to Auburn posi.
New bearings pressed in.
New ring and pinion.
All special tools and knowledge type work.
Also:
New brakes including all hardware.
New U joints.
Transfer case rear seal.
We have no actual information on how much time he put in.
I'm 99% sure it was at LEAST 8 to 10 hours over the 4 weeks he had the truck.
Honestly... could be double that. Easy!
I was seriously figuring on a minimum count of 20 hours.
He billed me for FOUR hours.
I had to ask twice if he was OK with that.
Turns out.... he was using my old Ford as therapy. Nostalgia. Enjoyment.
So it's scheduled to be towed back up here tomorrow morning.
Next steps will be rear lights and swapping the alternator type.
This diagram is for my own notes.
1262446041_Screenshot_20260624_192659_Chrome2.jpg.39815124ba468664cab41a4e89297a0b.jpg
  • Excellent 7
MainelyWheelhorse
Cool, @ebinmaine that’s great that worked out like that for you!
ebinmaine
Looking at the end of the rear frame it's basically a C channel. It measures just under 6" tall. Width is maybe 2 inches?
I want to extend the length approximately 13", 14".
I also want to make the steel wider top and bottom for better support of the trailer hitch.
I'm thinking something like this 4 x 6 box steel might work.
591463605_Screenshot_20260625_200409_Chrome2.jpg.02bf474030affa117a1cc2ccf6d50f26.jpg
I can tack it in but I'd have a professional welder do the final attachments.
Handy Don
I’m no expert, but don’t truck frames get specific treatment for hardness and ductility? I’d want to be sure an “extender” really knows the ins and outs.
ebinmaine
Heavy truck frames,  yes. They can NOT be welded.
This frame is not heat treated so welding is fine.
8ntruck
Idle thoughts on this subject:
This probably depends on where the weld is on the frame.  Welds are stress concentration features.  They create hard spots, notches, and divots.
If the weld is located in a low stress area of the frame, probably no problems.
Truck frames are subjected to unpridictable, varying, and cyclic loads - the sort of loading condition that fatigue cracks can grow in.  If the weld is located in a high stress area on the frame, it could provide a spot for a fatigue crack to start.  Grinding the weld smooth and/or shot peening it will reduce the chances of a crack initiation site.
I've never done any analysis work on frames, so I don't know where the high stress areas are.  I'll guess that they are at the attachment points for the suspension and maybe at the attachment points for the cross members.
A lot of long box pickup frames have been cut down into short box frames.  Maybe something to learn from this process?
ebinmaine
All good points and your guesses seem to align with other folks' information.
To weld two frames together there are of course, methods for grooving the weld by chamfering the edges combined with adding diamond shaped braces inside and out of the vertical parts of the frame. There can also be long thin braces added to the top and bottom of the frame.
I'd prefer to avoid the frame stretching.
I want to keep the bed build as simple as possible.
When I get time next week I'll take some tractor size measurements on the Herd.  I'm thinking I can put 3 of Trina's smaller tractors on the truck with an 8 foot long flat bed. That leaves room on the big trailer for six.
ebinmaine
I've decided to postpone the frame stretch for now.
The idea was to have the capability of hauling 3 C series tractors on the bed and I also really liked having the extra length of the 9 foot platform on my '99 F350.
Need?.... no not really.
I can make an 80" - 84" wide bed and still fit 2 C series tractors sideways or 3 of Trina's mid 1960s short frames.
On the trailer hitch, she and I were looking over the mounting surface yesterday evening. We knew there are a couple holed to be welded shut and moved.
I got to looking at the existing hitch a few weeks ago. It has a rating of
5000 lbs with no weight distribution,
7500 with.
That's actually under rated for the capabilities of the truck so I'm ordering a new Class V hitch.
ebinmaine
Several years ago I was given a set of new take-off rear lamps from an IHC tractor chassis that was being built into a dump truck.
These would have bolted to the frame (inside or outside of) depending on the customer's intentions of use.
The dump chassis specs didn't fit the usage so these were removed.
Today I used online search info to determine the most likely ground wire color and tested the units.  All good.
Notated the wires.
I'm hoping to keep the original Ford factory wiring harness in place.
This Tekonsha plug in adapter should get me the connections I need so I can splice the aftermarket lights in.
Also found a 7 way plug and trailer brake controller in the parts box. I need to confirm that the 7 way is the correct style.
MainelyWheelhorse
You have to be logged in to see it.@ebinmaine
ebinmaine
I'll put a couple of print screens in here later
wh500special
On 7/4/2026 at 4:14 PM, ebinmaine said:
Not to sound too critical or to be too eager to spend your money, but I'd suggest a proportional controller over that time-based unit.  Proportional controllers offer more natural and progressive braking and overall a much more pleasant driving experience with a braked trailer. They might be safer too since they can really squeeze the trailer brakes quickly and tighter in a panic stop rather than waiting for them to ramp up over time.
Steve
ebinmaine
Steve
That's good info and I'll definitely consider it. I'll see what I can find online. This is one that I've had for probably 20 years or more.
ebinmaine
Rear bumper is off. That won't go back on.
Rear crossmember is loose. That will be replaced because it's thin but I am leaving it in for now so that the frame spacing stays correct while I install the trailer hitch.
adsm08
I have been using this one in my Explorer for a few years and have been quite happy with it. So far the worst thing I have to say about it is the mounting tape doesn't hold up to summer very well.
https://www.easternmarine.com/insight-universal-brake-controller-47297
ebinmaine
Major changes coming in the engine compartment as well... over the next few months.
Yesterday I started sorting out the needed wires from the future usage.
Before - ish.
ALL of these wires and vacuum lines will be removed. There's one yellow and one black wire that'll be moved to going across the back of the firewall so they are NOT laying across the engine.
Same wires, different view. Also, this Air pump and all it's related hoses, pipes, sensors and wires are coming out.
This evaporation canister and air cleaner inlet were already dysfunctional so they're being removed.
This distributor is being changed to a GM HEI style. The coil in thebred circle will also be removed.
The fuel pump is just outside the red circle. I'm not sure if I'll leave that or swap to an electric pump yet. It works OK but they have a high failure rate.
ebinmaine
10 minutes ago, adsm08 said:
this one
Thanks. I do like the easy to read display.
