ebinmaine 77,561 #1 Posted June 8, 2021 I know there's been aftermarket kits available for folks building hot rods for quite some time now. Decades. I'm looking at purchasing an early '80s truck and many of them if built for the northern half of the country did not have air conditioning. Anyone ever used one of these kits? Any experiences or comments one way or the other? They seem to be quite popular. Share this post Link to post Share on other sites
squonk 45,634 #2 Posted June 8, 2021 (edited) As long as the shop installing it has experience doing it and has a good rep, they are fine. Since almost all cars come with AC now it may be difficult to find a shop. Might be easier to find a truck with AC on it! I remember prepping for delivery an 82 Chevy Malibu. It had just arrived from a shop 40 miles away that installed the AC. They forgot to put in the condensate drain hole and it was a hot muggy day. All of the condensate blew into my lap when I turned it on. I bought a brand new 88 S-10 and had AC installed. worked well. Here is a Co. that specializes with it: https://www.vintageair.com/ Edited June 8, 2021 by squonk 1 1 Share this post Link to post Share on other sites
Pullstart 68,988 #3 Posted June 8, 2021 Just make sure the windows crank good EB and you’ll be just fine 1 3 Share this post Link to post Share on other sites
953 nut 64,340 #4 Posted June 8, 2021 Here is the unit I had in my '48 Ford truck. They offer a variety of engine brackets for the compressor. https://www.southernrods.com/a-c-and-heat-components/mini-kooler-under-dash-unit-complete-kit.html 3 Share this post Link to post Share on other sites
WHX?? 55,281 #5 Posted June 8, 2021 Compressor went out on Blackie and I replaced it but now leaks R134a so I now have 360 AC...... roll down 3 windows and go 60! 1 1 3 Share this post Link to post Share on other sites
Pullstart 68,988 #6 Posted June 8, 2021 In all reality EB... make sure the vacuum pump is left on it long enough... that’s crucial. Mrs. P’s Suburban was recently leaking at the low pressure port. I figured I could quick change the valve core and simply recharge it. Well that worked for a day or two! I stuck the vacuum on it for a good amount of time and tossed a few cans in it until it said full and it works much better now that the oxygen is out of the system. 3 Share this post Link to post Share on other sites
squonk 45,634 #7 Posted June 8, 2021 4 minutes ago, pullstart said: In all reality EB... make sure the vacuum pump is left on it long enough... that’s crucial. Mrs. P’s Suburban was recently leaking at the low pressure port. I figured I could quick change the valve core and simply recharge it. Well that worked for a day or two! I stuck the vacuum on it for a good amount of time and tossed a few cans in it until it said full and it works much better now that the oxygen is out of the system. Actually Kevin, Not so much the o2 but the moisture trapped in the oil. When you run the pump, you are lowering the pressure (Obviously) which lowers the boiling point of the trapped moisture. So you run the pump to "boil" that moisture off. You will often see vapor coming out of the pump exhaust on a wet system. I run the pump at least 2 hours depending how long the system was open. I have fixed countless underperforming auto AC's that had come from shops than ran the pump for like 15 min. Water in the system will freeze the refer circuit at the point of expansion. My wife's Toyota van had a rear AC line rot out. The shop changed the line and recharged it. 2 days later no workie. I put my gauges on and the pressures were pegged! Took it back and asked, how long was the pump on? He says 20 min. I tell him to take out the refer and run the pump all day!! System works perfectly now. 1 1 Share this post Link to post Share on other sites
Achto 31,135 #8 Posted June 8, 2021 You could always take the easy route. 3 1 7 1 Share this post Link to post Share on other sites
squonk 45,634 #9 Posted June 8, 2021 25 minutes ago, Achto said: You could always take the easy route. Did Jim let you take that pic? I can't believe he did that to that new truck! 3 Share this post Link to post Share on other sites
seuadr 489 #10 Posted June 8, 2021 (edited) 2 hours ago, squonk said: My wife's Toyota van had a rear AC line rot out. The shop changed the line and recharged it. 2 days later no workie. I put my gauges on and the pressures were pegged! Took it back and asked, how long was the pump on? He says 20 min. I tell him to take out the refer and run the pump all day!! System works perfectly now. back when i did that sort of thing, i liked to take a micron gauge down to 500 and leave it for at least an hour that way - usually would take 8-10 hours to get down that far. more often than not -we'd just leave the pump to run overnight. I don't think people realize how much moisture messes with the cycle. Edited June 8, 2021 by seuadr 3 Share this post Link to post Share on other sites
Herder 2,355 #11 Posted June 8, 2021 2 hours ago, Achto said: You could always take the easy route. Let me get a YEEEEHAAAAA. Blows cold!!! 3 Share this post Link to post Share on other sites
WHX?? 55,281 #12 Posted June 8, 2021 4 hours ago, pullstart said: the oxygen is out of the system. 4 hours ago, squonk said: run the pump to "boil" that moisture off You school him Squonky.... I'm tired of it .....Although air is a non condensable so he is kinda right! You school him Kev ...I'm tired of it! 1 hour ago, seuadr said: take a micron gauge down to 500 and leave it for at least an hour that way - usually would take 8-10 hours to get down that far. more often than not -we'd just leave the pump to run overnight. I don't think people realize how much moisture messes with the cycle. That boy right there needs no schooling! The moisture does not play well with what is coined as hygroscopic oil... same as some brake fluids. 1 Share this post Link to post Share on other sites
squonk 45,634 #13 Posted June 8, 2021 Big systems, sometimes we'd run 2 pumps for a couple days. Gave us time to get a 400 hundred pounds of refrigerant upto the roof. 1 Share this post Link to post Share on other sites
ebinmaine 77,561 #14 Posted June 8, 2021 5 hours ago, Achto said: You could always take the easy route. I couldn't possibly be low balled into such primitive behavior. Duct tape??? Oh no no no no no The BBT and I have moved up to black Gorilla tape!!!!! Man... I hate to even write this but it's true: My Ole Man had a (Isuzu??) Cabover truck. 16 foot cargo box. AC worked but just couldn't keep up with that giant cab and window in the sun. He did. Literally. Install a small room AC connected to an inverter. Just. Like. Above. Right where there was a back window. Have to admit it worked some kinda better than the truck AC. 1 1 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #15 Posted June 8, 2021 Why you all making fun of the AC unit truck window. Redneck engineering , plus you don't have to clean the rear window. 3 1 1 Share this post Link to post Share on other sites
squonk 45,634 #16 Posted June 8, 2021 11 minutes ago, elcamino/wheelhorse said: Why you all making fun of the AC unit truck window. Redneck engineering , plus you don't have to clean the rear window. You silly goose! If he was to do it the right way, he would have installed a mini-split! 3 Share this post Link to post Share on other sites
ebinmaine 77,561 #17 Posted June 8, 2021 27 minutes ago, elcamino/wheelhorse said: Why you all making fun of the AC unit truck window. Redneck engineering , plus you don't have to clean the rear window. ^^^^^ ^^^^^ Have to admit the man has a point 1 Share this post Link to post Share on other sites
lynnmor 8,651 #18 Posted June 8, 2021 47 minutes ago, ebinmaine said: I couldn't possibly be low balled into such primitive behavior. That is actually a high end unit, apparently you haven't priced 2 x 10s lately. 3 1 Share this post Link to post Share on other sites
ebinmaine 77,561 #19 Posted June 8, 2021 26 minutes ago, lynnmor said: That is actually a high end unit, apparently you haven't priced 2 x 10s lately. Okay. Okay. You're right. I hadn't even given consideration to the price of the dimensional lumber involved. 1 Share this post Link to post Share on other sites
305 380 #20 Posted June 8, 2021 back when i was building hot rods professionally i always used Vintage Air and had very good luck 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,824 #21 Posted June 8, 2021 What do you AC experts do to keep the moisture outta yer vaccum service pumps(or to get the moisture out)? Figured the same principles will apply to the freeze dry system when I build it. Share this post Link to post Share on other sites
305 380 #22 Posted June 8, 2021 both of these cars i installed Vintage Air 1 4 Share this post Link to post Share on other sites
squonk 45,634 #23 Posted June 8, 2021 1 hour ago, Wheel Horse 3D said: What do you AC experts do to keep the moisture outta yer vaccum service pumps(or to get the moisture out)? Figured the same principles will apply to the freeze dry system when I build it. Some moisture leaves thru the pump exhaust. The rest is trapped in the vacuum pump oil and you are " supposed " to change the oil after each pull down. On big jobs sometimes the pump is shut off and the oil is changed them the pump restarted 1 Share this post Link to post Share on other sites
seuadr 489 #24 Posted June 9, 2021 5 hours ago, Wheel Horse 3D said: What do you AC experts do to keep the moisture outta yer vaccum service pumps(or to get the moisture out)? Figured the same principles will apply to the freeze dry system when I build it. Well, the pumps use oil so it doesn't really get entrained, but you do need to check/ replace the oil as it'll get other contamination and also a little atomizes during use so it uses a little that goes out with the vapor. But yeah, pulling a vac on food will definitely dehydrate it. I think the challenge you'll have trying to freeze dry is it needs to flash freeze and be exposed to a vac once frozen, my suspicion would be it needs to pull down to vac really quick to be effective, that can be a challenge with a typical portable pump. Share this post Link to post Share on other sites
Wheel Horse 3D 3,824 #25 Posted June 9, 2021 Lol dont wanna hijack the thread, but there will be a cold trap to capture as much moisture as possible before the pump. While "flash" frozen is used in commercial application, to better maintain the structure of the foods, for our purpose a good deep freeze will be just fine. As you apply vaccum the temp naturally decreases anyway, deeper the vaccum, colder it gets. If the food is too cold, it cant sublimate properly. The idea is to hang out at a temp and pressure that is just below the tripple point of water. At some point, you gotta add a little heat into the system to get the last of the water out. More info over here: "PPrepper knowledge! Alternative power and solutions - non tractor related discussion - RedSquare Wheel Horse Forum" https://www.wheelhorseforum.com/topic/93128-pprepper-knowledge-alternative-power-and-solutions/?page=2 Share this post Link to post Share on other sites
