Pullstart 71,561 #26 Posted June 3, 2021 I’ve got spark, I’ve got fuel, I’ve got a tiny puff out the muffler. It must be a points gap thing. I’ll play with the points some more and hear it run soon! But not tonight. 5 4 Share this post Link to post Share on other sites
tractornut86 622 #27 Posted June 3, 2021 The taper frame is the common frame used. The last ones made had a straight frame and a Wisconsin engine but earlier style like yours should be the ZZP. There was also 2 different styles of rear ends. The center section and drop boxes are little different. Yours has the late style. From the looks of it every peice of your tractor been welded on or modified but it's a good start. 1 1 Share this post Link to post Share on other sites
Pullstart 71,561 #28 Posted June 3, 2021 I got it running! I drove it 4 feet! There’s a noise when I press the clutch in, but I’ll figure that out tomorrow. 6 9 Share this post Link to post Share on other sites
D_Mac 9,339 #29 Posted June 3, 2021 When I had my hot rod it was the noise of when you let the clutch out that I loved 5 2 1 Share this post Link to post Share on other sites
Pullstart 71,561 #30 Posted June 3, 2021 8 hours ago, pullstart said: It must be a points gap thing. It was actually a not enough fuel thing. I kept toying with stuff until in popped to life! 4 Share this post Link to post Share on other sites
953 nut 70,656 #31 Posted June 3, 2021 8 hours ago, pullstart said: There’s a noise when I press the clutch in Throughout bearing? Share this post Link to post Share on other sites
Pullstart 71,561 #32 Posted June 3, 2021 14 minutes ago, 953 nut said: Throughout bearing? Possible, but he was pretty certain he knew what bolt it was. I just have to see if there are marks or metal shavings anywhere. We’ll get there 2 Share this post Link to post Share on other sites
Pullstart 71,561 #33 Posted June 3, 2021 Part one of my day to get Jackie running... 1 1 Share this post Link to post Share on other sites
Pullstart 71,561 #34 Posted June 3, 2021 A new D-16 spark plug will do you wonders on an old Wisconsin! Jackie Purrs! Time to get working on a hauler now... 4 Share this post Link to post Share on other sites
Pullstart 71,561 #35 Posted June 3, 2021 3 hours ago, 953 nut said: Throughout bearing? It’s part of the pressure plate fingers. I’m torn whether to grind the material away for clearance and risk the material tearing up the clutch disc, or just let it find it’s own way... but I suppose it will throw metal pieces that way too. 2 Share this post Link to post Share on other sites
19richie66 17,951 #36 Posted June 3, 2021 Take just a hair off and should be good. 2 1 Share this post Link to post Share on other sites
Pullstart 71,561 #37 Posted June 3, 2021 I don’t know if I posted this in the Senior thread, but this Wisconsin manual is a big help! https://www.m-and-d.com/pdfs/Wisconsin/AEN_AENL_AENS_instr_parts.pdf Share this post Link to post Share on other sites
Pullstart 71,561 #38 Posted June 3, 2021 Getting close... 1 Share this post Link to post Share on other sites
Pullstart 71,561 #39 Posted June 3, 2021 And finally, a video of it running and driving! 2 4 Share this post Link to post Share on other sites
D_Mac 9,339 #40 Posted June 3, 2021 The Whiskey's a Go-Go !!! Nice 1 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,827 #41 Posted June 3, 2021 Dude! Awesome! 1 Share this post Link to post Share on other sites
hcminis 1,818 #42 Posted June 4, 2021 That is freaking AWESOME!!! Great job and very cool videos 1 Share this post Link to post Share on other sites
Pullstart 71,561 #43 Posted June 4, 2021 9 minutes ago, hcminis said: That is freaking AWESOME!!! Great job and very cool videos 18 hours ago, Wheel Horse 3D said: Dude! Awesome! 18 hours ago, D_Mac said: The Whiskey's a Go-Go !!! Nice Thanks for all the compliments fellas! As for video quality... well it gets the point across I guess. There are monotonous and slow parts, but it shows my efforts and excitement in raw form. On 6/2/2021 at 11:11 PM, tractornut86 said: The taper frame is the common frame used. The last ones made had a straight frame and a Wisconsin engine but earlier style like yours should be the ZZP. There was also 2 different styles of rear ends. The center section and drop boxes are little different. Yours has the late style. From the looks of it every peice of your tractor been welded on or modified but it's a good start. Thanks for your insight! I see the imperfections, but also the efforts made to keep it in the field too. For now, I’ll clean it up and let it tell the story. Some day, maybe re-create some parts and keep what it came with on a shelf. 2 Share this post Link to post Share on other sites
Pullstart 71,561 #44 Posted June 4, 2021 I added a kill button to the magneto and ground the fingers and studs on the pressure plate. No noise in the bellhousing! I have some T-posts to drive today. I suppose I have a reason to drive Jackie around the property! Shucks! 2 Share this post Link to post Share on other sites
Achto 32,963 #45 Posted June 4, 2021 11 minutes ago, pullstart said: I added a kill button to the magneto On the magneto tractors that we have, I ran a wire from the mag to a switch that could be accessed from he seat. I know it's not original but I did this as a safety feature. If the need arises you can shut the tractor off without leaving the drivers seat. Thought it important, specially when driving around a crowd of people at a show. 1 4 Share this post Link to post Share on other sites
squonk 48,427 #46 Posted June 4, 2021 Glad you finally got that running. I was getting worn out just watching you pull that rope! 1 5 Share this post Link to post Share on other sites
Bow_Extreme 584 #47 Posted June 5, 2021 Very nice work, Kevin!! Cant wait to stop over and take a look! 1 1 Share this post Link to post Share on other sites
Pullstart 71,561 #48 Posted June 5, 2021 27 minutes ago, Bow_Extreme said: Very nice work, Kevin!! Cant wait to stop over and take a look! You know the rules Matt... No “looking” allowed. Riding, sure! 4 Share this post Link to post Share on other sites
peter lena 10,125 #49 Posted June 5, 2021 @pullstart , great pick up on that ! love that post war anything , there was no failure built into them , just the idea of bringing it back to use and life, is wonderful. enjoy your work and marvel at its bombproof common sense durability , what a concept , pete 1 1 Share this post Link to post Share on other sites
haydendavid380 759 #50 Posted June 5, 2021 Great find We've been enjoying the videos 1 Share this post Link to post Share on other sites
