TJ5208 1,835 #1 Posted May 27, 2021 @pullstart @Achto what kind of paint do you use for your horses if anyone else wants to chime in go ahead Share this post Link to post Share on other sites
oliver2-44 10,627 #2 Posted May 27, 2021 I use Rustoleum Regal Red and Majic Enamel Hardener thinned with lacquer thinner. I use a Harbor Freight spray gun. 1 Share this post Link to post Share on other sites
Maxwell-8 4,367 #3 Posted May 27, 2021 Here is a post about it Share this post Link to post Share on other sites
Gregor 4,847 #4 Posted May 27, 2021 (edited) I had been using Rustoleum "Chinese Red Lacquer" in a spray can, with Rustoleum self etching primer. Topping it off with Rustoleum Gloss clear lacquer. On my last tractor ( C-125) I switched to Rustoleum "Regal Red" with enamel primer. If I can find it, I am switching back to the lacquer with self etching primer. I believe it gives a more glossy finish, and dries harder, quicker. The lacquer is a little more work, and is not as forgiving as the enamel, but gives a better finish, IMO. As a side note; Summer is here. Humidity level is just as important as temperature. Painting in high humidity can result in less than stellar results. At least it seems to work that way for me. I always try to maintain the humidity at 60% or less. I should add that spraying from a can as I do, will NEVER give the high quality, high luster results as spraying form a gun, with automotive type finishes. Again, my opinion. Edited May 27, 2021 by Gregor 1 Share this post Link to post Share on other sites
Achto 29,336 #5 Posted May 27, 2021 I use VanSickle International Harvester Red and IH Off White acrylic enamel. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,339 #6 Posted May 27, 2021 Regal Red!!! 1 Share this post Link to post Share on other sites
Rusty Tinsnips 477 #7 Posted May 27, 2021 Krylon Cherry Red on the Raider 10 and Rustyoleum Regal Red on the Raider 14 1 Share this post Link to post Share on other sites
TJ5208 1,835 #8 Posted May 29, 2021 Do you guys use hardenerds Share this post Link to post Share on other sites
Achto 29,336 #9 Posted May 29, 2021 33 minutes ago, Tj salyers said: Do you guys use hardenerds I always do. Share this post Link to post Share on other sites
Achto 29,336 #11 Posted May 30, 2021 5 minutes ago, Tj salyers said: What kind When possible use the hardener that is made by the same manufacturer as the paint that you are using. This way you will know that the hardener is made for the paint. For example - I like to use VanSickle acrylic enamel, so I use their acrylic enamel hardener. At the very least make sure that you use a hardener designed for the type of paint that you are using. Example - VanSickle hardener made for acrylic enamel will not work with VanSickle oil based enamel. Different types of paint = different hardeners. 1 Share this post Link to post Share on other sites
kpinnc 14,414 #12 Posted May 31, 2021 I've used so many versions of paint that I can't remember them all, but most are some flavor of IH red. Valspar was decent if mixed with hardener, and had rattle cans to use for touch ups. Hard to find now. Used a couple automotive paints too, but some are brittle and can chip off with a little bump. Maybe I used too much hardener... Ace hardware has a decent IH red in rattle cans. Share this post Link to post Share on other sites
