kpinnc 19,105 #226 Posted January 12 13 hours ago, cleat said: Yes, the lift bellcrank is slightly shorter on the reduction steering models. I found that out the hard way also. Forgive the dumb question- what did you do to resolve it? Obviously my thinking is to trim it down and use the next hole on the tab. But I am curious if anyone has ever measured the difference between the standard vs. shorter versions. 2 Share this post Link to post Share on other sites
cleat 9,445 #227 Posted January 12 57 minutes ago, kpinnc said: Forgive the dumb question- what did you do to resolve it? Obviously my thinking is to trim it down and use the next hole on the tab. But I am curious if anyone has ever measured the difference between the standard vs. shorter versions. Here are the two. Shorter with reduction steering. Regular steering. 2 2 Share this post Link to post Share on other sites
kpinnc 19,105 #228 Posted January 12 18 minutes ago, cleat said: Here are the two. That is amazing as always sir! Looks like the second hole in the original is less than 1/4 inch different from the first of the special model. I'm not going to try and open this center console back up. It looks to me that trimming the original down and using the second hole is pretty close and should be all the lift I will need. Thank you @cleat!!! 1 Share this post Link to post Share on other sites
Handy Don 17,735 #229 Posted January 12 (edited) 2 hours ago, kpinnc said: Looks like the second hole in the original is less than 1/4 inch different from the first of the special model. I noticed on our 520 (and on my 854) that the full arc of the lift arm is pretty close to 60º. In effect, the center-to-center distance between a hole in the arm and the rock shaft equals the maximum range of the lift (= 2 x sin(30º) x C2C) Using the second arm hole provides one inch less movement (vs. the outermost hole on the 8-speed arm) to a link that is perpendicular to the arm at the midpoint of its arc. The full range of the outer hole is ~4.25” so you will have 3.25” or ~23.5% less range. Edited January 12 by Handy Don 2 Share this post Link to post Share on other sites
ebinmaine 81,278 #230 Posted January 12 17 minutes ago, Handy Don said: I noticed on our 520 (and on my 854) that the full arc of the lift arm is pretty close to 60º. In effect, the center-to-center distance between a hole in the arm and the rock shaft equals the maximum range of the lift (= 2 x sin(30º) x C2C) Using the second hole arm provides one inch less movement (vs. the outermost hole) to a link that is perpendicular to the arm at the midpoint of its arc. The full range of the outer hole is ~4.25” so you will have ~23.5% less range. I'd be concerned (perhaps unfounded) that if I used the second hole for something heavy like a snowblower it would be much more taxing on the lift mechanism as a whole. Thoughts? Share this post Link to post Share on other sites
Handy Don 17,735 #231 Posted January 12 1 minute ago, ebinmaine said: I'd be concerned (perhaps unfounded) that if I used the second hole for something heavy like a snowblower it would be much more taxing on the lift mechanism as a whole. Thoughts? Given that the lifted weight is the same (the blower), the closer hole is an easier to lift but yields less travel/movement/height and less torque on the rockshaft. But the forces on the rockshaft bushings will be the same. 1 1 Share this post Link to post Share on other sites
Handy Don 17,735 #232 Posted January 12 (edited) If having the max lift range matters (and to me it would), I’d seriously consider: - trimming the end of the arm - welding up the remains of the outermost hole - sistering the arm with some ⅛" sheet metal welded on both sides and rounding the end of the arm - drilling a new hole centered ½” from the end if the shortened arm Yes, a bit awkward with the rock shaft in the tractor. Edited January 12 by Handy Don 2 Share this post Link to post Share on other sites
ebinmaine 81,278 #233 Posted January 12 28 minutes ago, Handy Don said: If having the max lift range matters (and to me it would), I’d seriously consider: - trimming the end of the arm - welding up the remains of the outermost hole - sistering the arm with some ⅛" sheet metal welded on both sides and rounding the end of the arm - drilling a new hole centered ½” from the end if the shortened arm Yes, a bit awkward with the rock shaft in the tractor. I may move the steering gear itself forward a couple hairs. Redrill with 4 new holes instead of just the 2 forward ones. 2 Share this post Link to post Share on other sites
kpinnc 19,105 #234 Posted January 13 5 hours ago, ebinmaine said: may move the steering gear itself forward a couple hairs. Redrill with 4 new holes instead of just the 2 forward ones. This was actually something I had thought about. I only need about 1/4 inch for the lift to clear. Maybe less... The upper steering shaft is the only thing that would be of concern. The hole that it passes through is partially slotted already. Definitely got some work to do. 2 Share this post Link to post Share on other sites
19richie66 17,951 #235 Posted January 14 On 1/11/2026 at 10:11 PM, Lee1977 said: We talked about this bearing and bracket, though I would send the picture any way. Where might one find said bracket. I must have missed seeing it before Share this post Link to post Share on other sites
kpinnc 19,105 #236 Posted January 14 (edited) 31 minutes ago, 19richie66 said: Where might one find said bracket. I must have missed seeing it before The bracket is on all the 500 series "Classic" machines. The standard version just has a bushing but the one in the pic was modified to use a 3/4 flange wheel bearing. Edited January 14 by kpinnc Share this post Link to post Share on other sites
Lee1977 7,813 #237 Posted January 14 (edited) 34 minutes ago, 19richie66 said: Where might one find said bracket. I must have missed seeing it before Early 520's and 500's, my 89 520 has one. Later 520's they just modified the battery tray. Edited January 14 by Lee1977 Share this post Link to post Share on other sites
kpinnc 19,105 #238 Posted January 14 3 hours ago, Lee1977 said: Early 520's and 500's, my 89 520 has one. Later 520's they just modified the battery tray. All of my machines (518H, two 520H, and one 520-8) were 1987-1990 models, so I was unaware of the changes to the later model 520s. Thanks Don! I learn something new every day! Share this post Link to post Share on other sites
cleat 9,445 #239 Posted January 15 8 hours ago, Lee1977 said: Early 520's and 500's, my 89 520 has one. Later 520's they just modified the battery tray. Actually the later 520's moved the steering shaft bushing to up under the dash. The dash can be drilled to accept a wheel bearing as well. A couple of mine have been done this way. 2 Share this post Link to post Share on other sites
kpinnc 19,105 #240 Posted January 15 Well, I have a plan for the upper steering shaft on the 523-H, but it will be the weekend before I try it. I want to add a couple inches to the length to raise the steering wheel, so I'll definitely need some additional support. Hopefully it'll work out. 1 Share this post Link to post Share on other sites
19richie66 17,951 #241 Posted January 15 5 hours ago, kpinnc said: Well, I have a plan for the upper steering shaft on the 523-H, but it will be the weekend before I try it. I want to add a couple inches to the length to raise the steering wheel, so I'll definitely need some additional support. Hopefully it'll work out. After seeing what you can do, piece of cake. 1 Share this post Link to post Share on other sites
kpinnc 19,105 #242 Posted January 18 Got the lift cut down just a little. Split the top hole, welded it up and drilled another. Only lost about 3/8 length on the bellcrank. Gives 1/4 inch clearance now. Also installed the lower steering and aligned the wheels. Used 2 of the 3 shims underneath to get the best gear mesh. So far so good... 3 Share this post Link to post Share on other sites
cleat 9,445 #243 Posted January 18 13 minutes ago, kpinnc said: Got the lift cut down just a little. Split the top hole, welded it up and drilled another. Only lost about 3/8 length on the bellcrank. Gives 1/4 inch clearance now. Also installed the lower steering and aligned the wheels. Used 2 of the 3 shims underneath to get the best gear mesh. So far so good... Looks just like the late model bellcrank now. Great job ! 2 1 Share this post Link to post Share on other sites
kpinnc 19,105 #244 Posted January 18 (edited) I think I got the hydro pedal issue fixed. Long story short- building a tractor from several models can create small issues that have a bigger effect than you (meaning me) think. The DCL carrier parts (the whole center console) are from a 518H, the frame and tranny were from a 312H. Somehow, the linkages were more different between the two than I thought. The hydro was strong, but not very fast. For one, the link that connects the rear cam to the center DCL carrier was about 1/2 inch too long. I trimmed it down and that gave me full forward travel at the rear cam plate. Second, the vertical "return to center" and park brake cam stopped the follower way to early, so reverse cam travel with the shortened link was very little. I ground the bottom of the opening out about 1/4 inch. It doesn't touch anything normally, but this one did. The vertical cam was a new part when I assembled everything so maybe I had the wrong part? Regardless it no longer binds but still returns the DCL carrier to center and the park brake still works as it should. I didn't get pics of the bottom of the cam but it no longer stops the follower. So all of this now gives full travel at the rear hydro cam plate in forward and reverse. It stopped about 1/4 inch from the stops before so hopefully it's good now. Edited January 18 by kpinnc 1 Share this post Link to post Share on other sites
lynnmor 9,081 #245 Posted January 18 12 hours ago, kpinnc said: Got the lift cut down just a little. Split the top hole, welded it up and drilled another. Only lost about 3/8 length on the bellcrank. Gives 1/4 inch clearance now. Also installed the lower steering and aligned the wheels. Used 2 of the 3 shims underneath to get the best gear mesh. So far so good... You might want to add a washer or two behind the castle nut so the cotter pin is fully engaged in the castle nut. 3 Share this post Link to post Share on other sites
kpinnc 19,105 #246 Posted January 19 (edited) Well I finished the steering wheel mods today. Tomorrow will be reassembly- at least some of it. I raised the steering wheel about 2.5 inches. Might be too much but that's easily fixed if needed. So I decided to support the upper shaft with not one but two bearings. I welded a couple inches of 1 inch steel pipe on both sides of the factory bushing holder. I also placed a needle bearing in the bottom and a regular wheel bearing on top. The bearings are about 4 inches apart, which stiffens the whole column quite a bit. Not sure why the paint buggered up, but it looks good enough. Also added a grease fitting to keep those bearings slicked up. I cut the upper steering shaft and drilled it to accept an extension that was from a Toro Groundsmaster. Then I added the other half of the shaft with about 1.5 inches of separation. That raised the steering wheel the full 2.5 inches above what it was previously. Of course I needed to have a sleeve of some type to make the steering wheel and upper console match up. Luckily I had some aluminum stock left over so I turned a couple down on my lathe and added a setscrew to each. Not perfect, but looks decent. I also replaced the roll pin with a bolt with spacers. I bleeping hate roll pins! The steering is much tighter than it was before with almost no play. What little there is comes from the reduction unit, and it's as snug as I can get it without it binding. Huge improvement! Edited January 19 by kpinnc 1 5 Share this post Link to post Share on other sites
cleat 9,445 #247 Posted January 19 4 hours ago, kpinnc said: Well I finished the steering wheel mods today. Tomorrow will be reassembly- at least some of it. I raised the steering wheel about 2.5 inches. Might be too much but that's easily fixed if needed. So I decided to support the upper shaft with not one but two bearings. I welded a couple inches of 1 inch steel pipe on both sides of the factory bushing holder. I also placed a needle bearing in the bottom and a regular wheel bearing on top. The bearings are about 4 inches apart, which stiffens the whole column quite a bit. Not sure why the paint buggered up, but it looks good enough. Also added a grease fitting to keep those bearings slicked up. I cut the upper steering shaft and drilled it to accept an extension that was from a Toro Groundsmaster. Then I added the other half of the shaft with about 1.5 inches of separation. That raised the steering wheel the full 2.5 inches above what it was previously. Of course I needed to have a sleeve of some type to make the steering wheel and upper console match up. Luckily I had some aluminum stock left over so I turned a couple down on my lathe and added a setscrew to each. Not perfect, but looks decent. I also replaced the roll pin with a bolt with spacers. I bleeping hate roll pins! The steering is much tighter than it was before with almost no play. What little there is comes from the reduction unit, and it's as snug as I can get it without it binding. Huge improvement! Great job ! 1 Share this post Link to post Share on other sites
ebinmaine 81,278 #248 Posted January 19 3 hours ago, cleat said: Great job ! Nice work! Share this post Link to post Share on other sites
Lee1977 7,813 #249 Posted January 19 (edited) I had to measure mine it's only 1 7/8" additional height. I raised mine for a different reason, the steering wheel was so loose it could hit the top of the dash. We drilled it out and made the adapter out of 2" steel. Edited January 20 by Lee1977 1 Share this post Link to post Share on other sites
kpinnc 19,105 #250 Posted January 26 Being locked in was boring (not that I'm complaining) so I put this lady back together, and fired her up and readjusted the hydro cam. I didn't take it for a drive yet but I will in the next day or two. I absolutely love the new height of the steering wheel. I also can understand why Wheel Horse came out with reduction steering. Might be a pain to mow with, but I like it regardless. She needs a bath, but that can definitely wait... 1 2 Share this post Link to post Share on other sites
