Pullstart 70,101 #1 Posted April 13, 2021 Can anyone identify this drain system? @squonk? Is there a NAPA # for it? The oil everywhere under this constituted to a loose oil filter. It’s the 520Xi, but I doubt it is factory... Share this post Link to post Share on other sites
squonk 46,840 #2 Posted April 13, 2021 I have seen those before Kevin but never found out who makes it or where they came from. 1 Share this post Link to post Share on other sites
peter lena 9,899 #3 Posted April 13, 2021 pullstart, does that have a regular pipe thread start? if so there are a lot of options, similar to the fumoto spring valve . pete 1 Share this post Link to post Share on other sites
Pullstart 70,101 #4 Posted April 13, 2021 2 minutes ago, peter lena said: pullstart, does that have a regular pipe thread start? if so there are a lot of options, similar to the fumoto spring valve . pete it’s a pipe elbow above it. I suppose I could just as easily take the e-z drain do-hicky off an just use a pipe/plug. Share this post Link to post Share on other sites
peter lena 9,899 #5 Posted April 13, 2021 those threads make it easy , you could also use a ball valve just after the ,elbow , with a hose attached for easy drainage , pete 2 Share this post Link to post Share on other sites
Jake Kuhn 1,599 #6 Posted April 14, 2021 Stens 125-508 is that style, just make sure the threads are the same. 2 1 Share this post Link to post Share on other sites
Pullstart 70,101 #7 Posted April 14, 2021 1 minute ago, Jake Kuhn said: Stens 125-508 is that style, just make sure the threads are the same. Hi Jake! Lot’s changed since we last said hello! Portage, I think? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,275 #8 Posted April 14, 2021 Drain valve looks original. 1 Share this post Link to post Share on other sites
Pullstart 70,101 #9 Posted April 14, 2021 27 minutes ago, gwest_ca said: Drain valve looks original. wow, cool! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,275 #10 Posted April 15, 2021 This valve was first used on these models so been around a while 72042, 264-6 Yard Tractor, 1994 (SN 4900001-4999999) 72043, 264-H Yard Tractor, 1994 (SN 4900001-4999999) 72062, 264-6 Yard Tractor, 1994 (SN 4900001-4999999) 72063, 264-H Yard Tractor, 1994 (SN 4900001-4999999) 72083, 266-H Yard Tractor, 1994 (SN 4900001-4999999) 72103, 268-H Yard Tractor, 1994 (SN 4900001-4999999) Garry Share this post Link to post Share on other sites
Handy Don 16,751 #11 Posted April 15, 2021 On 4/14/2021 at 9:01 AM, gwest_ca said: Drain valve looks original. That's pretty neat. Does require enough clearance to get a grip on it, though. Share this post Link to post Share on other sites
Pullstart 70,101 #12 Posted April 15, 2021 1 hour ago, Handy Don said: That's pretty neat. Does require enough clearance to get a grip on it, though. I used a blue shop rag and my left hand. It wasn’t terrible once I saw the picture Garry posted. Share this post Link to post Share on other sites
WHX?? 56,846 #13 Posted April 15, 2021 Those get used on Z turns alot. My JD has one as well as Cubs that have come through the shop. Share this post Link to post Share on other sites
Jeff-C175 7,209 #14 Posted April 15, 2021 (edited) That fitting accepts a piece of 1/2" plastic tubing also. Comes in handy on some machines. I've got them on a couple machines. 3/8" pipe thread, Edited April 15, 2021 by Jeff-C175 2 Share this post Link to post Share on other sites
shallowwatersailor 3,221 #15 Posted April 17, 2021 The Kohler Command Twin used in the 518xi, 520xi, and 522xi use that drain as well. 1 Share this post Link to post Share on other sites
