Similar Content
By Rhondajoy79
Briggs 11 horse keeps going through coils-
Hello, I hope you all can help. We have a b-115. When we got the tractor we had to rewire it, and changed the stator, the point, condenser, and coil. He mowed the yard 2 times and then we put it up for the winter. We got it out to get it ready for this mowing season and it wouldn't start, Dad tested everything and said there was nothing at the coil. Ordered new coil, put it on it started and was fine. He mowed the yard twice and it is bad again. Dad checked everything and said he can't figure it out. If any body could help, as I don't know anything about them. He is 72 and very frustrated that he can't figure it out. I would appreciate any help to get this figured out for him. He has all the manuals available(thank you all by the way for that.) and he is just poking in the dark at this point. Thank you in advanced.
By BrianKoch
Gentlemen,
I am in need of help. While doing yard work with my K301 powered ‘68 Charger 12 it suddenly came to a stop and won’t start again.
My troubleshooting so far:
Fuel:
• stabil/87 and clean
• good flow before and after pump
• carb clean, recently rebuilt, float level correctly set
Compression:
•good? - blows finger off spark plug hole
•good turnover but doesn’t fire off
•piston and cylinders move freely
•valve lash set .008 intake .018 exhaust
•breather assembly correct and recently serviced with new gaskets and filter
•head gasket not broken, head bolts tight, some carbon on head
Spark:
•no spark
•all electrical/ignition components were replaced 1 year ago except voltage regulator
•no loose connections, no grounding connections
•inspected and applied graphite to starter shaft
•changed plug
•12v to coil good
•cleaned points, points wire has continuity
•condenser ground good
•swapped battery, points and wire, plug and wire, coil, and condenser from running K301 (‘69 Charger 12)
•points push rod does push out when turning engine over by hand, but unable to get points timed using multimeter method and timing mark on flywheel
What else should I check/do?
By Berco
I have an oil leak on my Kohler CH22 in my Toro 522XI (see video). I put in new head gaskets to remedy low compression. Then upon first start i had a large oil leak. It seemed to come from the aft oil seal. So i pulled the engine again and replace the seals. I re-installed the engine again today and the leak is still there. This is the leak now: https://youtu.be/pi382fXVXPQ What could cause it? I did blow out the air line from the fuel pump with compressed air into the crank case to clan out any debris. Could that have caused a leak this bad on the oil pan gasket? or another location? thank you all in advance!
By DarrellF
Just bought a D200 in great shape wanted to do some mods for cooling hydro and engine oils
Ive used sandwich adapters on motor home and to install transmission coolers and engine coolers
with new gauges, Seems to me would not be a problem to install on transmission of tractor from what I've read filters are 3/4 unf 16 thread
anyone ever done this before? Also easy way to install temp gauge,oil pressure gauges any gauge ya wanted plus external cooling.
