Similar Content
By drewd
Hi All, I have a 71 or 72 Model # 101006, Serial # 790336. Model number chart says 71 but the paper for the engine has a print code 72. The closest I could find was for models 1-3745 & 1-3741.
Two questions. I finally need to replace the drive belt. This manual list the belt as # 1576.
Two questions:
1) Does anyone know what size that translates to? I do have the old belt but the inside edge is falling apart so it will measure a little longer than it should.
2) This tractor has the electric clutch. What is the best way to remove the belt?
As always...Thanks!
By Mike Compton
Hi there, sorry if this is a repeat question. Anyone have a pic or diagram of how to reassemble the pulleys / tensioner, and how to route the belt? One more...what are the 4 holes for at the rear of the seat deck (above the logo decal)?
Cheers,
Mike
By ToroWheelHorseRookie
Please Help-- I inherited this work horse from my father in-law after being passed down from his father. I recently brought my wheel horse in for repairs and the service shop said they were unable to find the part; starter/solenoid. I did not want to give up on this beast as even the repair shop said this is a well made machine and is better than anything built today. I eventually found the part but because the shop left the part uninstalled I was unable to see how the starter was wired. Yesterday, I installed the new starter/solenoid but when I connected the battery terminals the tractor wanted to start on its own. I quickly disconnected the terminals and analyzed the electrical schematic map but I am baffled on the proper wiring. I only have a positive (red) battery terminal wire, another red wire, black (ground) wire, and a blue wire with a slot connection. I included pictures of the starter and the electrical schematic map. Any help would be much appreciated!! I l would like to fix this on my own as this seems to be a simple wiring issue. I can add pictures of the tractor itself, but at the moment its under a tarp in a shed at night. Thank you in advance, Matt
Electrical Guide.pdf
By midpack
I had a drive belt let go on a 1980 C-175 Sundstrand hydro. After searching the manuals it looks like either an 83" or an 85 1/2" belt is called for.
Anyone know the right length off the top of their head?
Thanks
By dambur
I need to change the Drive Belt on my Wheel Horse 208-4SB Model 42-08B401. I really need some step by step instructions or a service manual. I can't seem to find the procedure anywhere. PIctures would be great. My mower is slow going forward and It was suggested to me to change the drive belt.
Thanks
