AHS 1,594 #1 Posted April 5, 2021 Ok, so many questions! Do I have to remove the oil tube? I think I do. Is it just connected by the three screws on bottom? The starter; I have removed the two 9/16” head on bottom, the 7/16 head on back... is that all? I have a used Kohler starter, one that does have the bolt hole in the correct place.. I guess I will have to get another one. The key is a KOHLER starter... not a reman. Share this post Link to post Share on other sites
AHS 1,594 #2 Posted April 5, 2021 Also, do you have any ideas? I only want to do once! What is a durable starter? Share this post Link to post Share on other sites
ebinmaine 77,358 #3 Posted April 5, 2021 2 minutes ago, AHS said: durable starter I don't have any Magnum engine so I can't really help you with the removal of that one. As far as getting a durable replacement I'm much more prone to rebuilding an OE Kohler starter. So here's the question, what's wrong with that one? 1 Share this post Link to post Share on other sites
AHS 1,594 #4 Posted April 5, 2021 1 minute ago, ebinmaine said: I don't have any Magnum engine so I can't really help you with the removal of that one. As far as getting a durable replacement I'm much more prone to rebuilding an OE Kohler starter. So here's the question, what's wrong with that one? Is it an original one? It has an awful loud noise when the key is turned. And it needs a rebuild, a new starter gear and spring. I may just have that one rebuilt. 1 Share this post Link to post Share on other sites
ebinmaine 77,358 #5 Posted April 5, 2021 14 minutes ago, AHS said: Is it an original one? It has an awful loud noise when the key is turned. And it needs a rebuild, a new starter gear and spring. I may just have that one rebuilt. If it's still working electrically okay and just needs a mechanical rebuild you might be perfectly able to do it yourself. 2 Share this post Link to post Share on other sites
AHS 1,594 #6 Posted April 5, 2021 Yes, true. If it’s an original one... Share this post Link to post Share on other sites
oliver2-44 11,214 #7 Posted April 5, 2021 The electrical section of the Kohler overhaul manual has a good section on starter rebuild. it also shows how to make a simple sheet metal jib to hold the brushes with the spring in place to make installing them a lot easier. 3 Share this post Link to post Share on other sites
roadapples 6,987 #8 Posted April 5, 2021 May just need cleaned or blown out good. They accumulate a lot of dust... 2 Share this post Link to post Share on other sites
WHX?? 55,025 #9 Posted April 5, 2021 (edited) Good place for starters & parts. When you see the price of an original ...ya you'll want to rebuild yours. Kohler Starter Motors | Kohler Engine Starter | PSEP.biz Kohler Starter Rebuild Kit | Kohler Starter Solenoid | PSEP.biz Edited April 5, 2021 by WHX24 3 Share this post Link to post Share on other sites
AHS 1,594 #10 Posted April 5, 2021 Well, the brushes are burnt, one coming apart. And the magnets got one piece that is cracked. So time to buy another one. 1 1 Share this post Link to post Share on other sites
953 nut 64,127 #11 Posted April 5, 2021 @stevasaurus did a good post on starter rebuilding a couple years back. 1 Share this post Link to post Share on other sites
AHS 1,594 #12 Posted April 7, 2021 I know some of you may have bouts with DB electrical, but that’s who I got my starter from. With a 1 year warranty and $61.00 from DB...and a Kohler starter for $275.00. Hopefully that is the last one I will have to put in there!! I doubt it! The starter bolted right up, and is a lot quieter than the last one!😀 2 Share this post Link to post Share on other sites
