Joe Warren
Running 2 cycle fuel in a 4 cycle engine
Joe Warren
A guy I know runs all his 4 cycle power equipment engines on 2 cycle fuel. He claimed it reduced engine wear. Aside from the added cost of the 2 cycle oil, are there other downsides. Just curious what you all think.
Joe
And now for the rest of the story: I spoke to the guy again. He was a mechanic at a place where they operate a lot of outdoor power equipment; with both 2 and 4 cycle engines. To prevent employees from putting straight gas into their 2 cycle machines, all their fuel got 2 cycle oil mix with it. For them, it was more economical to spend money on oil, than on blown engines and downtime.
Thank for all the great posts. I found some to be very entertaining.
Edited by Joe Warren
Follow-up, added information.
DennisThornton
I'd suspect some smoke and early fouled plugs.  2 cycles have to get all their lube oil from the fuel, 4 cycles don't since they have a crankcase.  What would the 2 cycle oil lube in a 4 cycle?  That the crankcase oil doesn't?  My 1.5 cents.
stevasaurus
So, that is who is polluting the planet.  :confusion-confused:
  • Haha 6
SylvanLakeWH
Smoke is the only impact I  see from doing it... :confusion-confused:
:twocents-twocents:
Ed Kennell
When I winterize my boat motors, I drain and save  the mixed gas.    I save some for chain saws and string trimmers and the rest  I dump a gallon of the mixed in my vehicles when I fill the tanks.   The gas/oil ratio is then  1000/1.     No problems
  • Like 4
R Scheer
I've heard of people adding 2 cycle oil if they're starting the engine after sitting idle for a long time, but for normal use it sounds like a lot of smoke, fouled plugs, and carbon buildup in the cylinder head.
JMHO
Pullstart
Is this premixed from jugs, or two cycle out of a can fuel?  I imagine a hotter plug might take care of the excess oil.  After all, a 4 stroke with worn rings likely burns more than 40:1...
lynnmor
I needed to move my Dads tractor, with an Onan, after he passed but it was out of gas.  All that was there was an old mix for his chainsaw so I dumped that in, I expected to see a lot of smoke but their was none, it did run poorly though.
gwest_ca
We could not get Marvel Mystery oil in Canada for a couple of years because their labels did not meet requirements. I used 2-stroke oil instead and could not see any difference.
Garry
Gregor
Carburetor innards maybe? Upper rings? How do the valve guides get oil in a 4 stroke? IDK  I'm just throwing out ideas. I have seen what happens when you str8 gas a 2 cycle. You don't want to do that. :angry-nono:
gwest_ca
I use it to lube the valve stems. There is a bit of a skip in the exhaust without it and gone with it.
Garry
DennisThornton
Cylinder walls get splashed with oil so the rings run through that.  I assume the same for the valve guides.
TJ Salyers
If you like smoke go for it:auto-layrubber:
bc.gold
Ashless 2-Cycle Engine Oil
  • Excellent 1
Gregor
My dad was an airplane mechanic in the Air Force. He claimed MMO was the best thing that ever happened to an engine.
  • Heart 1
Skipper
I use Castrols fully synthetic 2 stroke oil at end of season on often used machines, and always in machines that just sit a long time between use. It stabilize the fuel very very well. I have not had a single carb issue since I started using it. Buy the right stuff, and there is zero smoke, smell or fouling. Only thing I can imagine it also does, is lube the engine a bit more. That newer was a bad thing though...........
But why don't you just buy some chemicals in a can and mix in instead? you might ask.
Well, I can use something that surely wont harm the engine in any way, perhaps even just help it a little instead, or I can try my luck with some jug of chemical miracles............. I know what I favor :-)
Just my :twocents-02cents: and experience, over the last 4 years and a lot of machines that get stored for many months before next fire up.
  • Like 4
ranger
I was always warned against adding extra oil to the ‘recommended’ ratio/mix in the older two stroke motor bikes, the reason given was, “More oil through the same size jet, means less petrol and a ‘weaker’ mix”. This was said to increase the risk of overheating, burned pistons and possible seizure! I shouldn’t think this would really apply to our horse’s power units under normal conditions, whatever they are? I suppose you can always adjust the mixture to suit? Add some Castrol ‘R’ to the tank, as we used to, to get the smell of the race track!
P.S. Might mess up your 🐈  🙀
Edited by ranger
JoeM
I figure the crankcase vent tube to the carburetor is plenty of oil vapor for the "top end"
Most two stroke oil would probably burn off. Don't forget the two stroker oil enters the crankcase on intake first.
I figure most of my engines are going to out last me just using non e fuel.
Gregor
Sort of on topic. Maybe someone can answer this. On old 2 stroke Lawn boy engines there are several types of course. A C-19 has a piston with 3 rings. No,what I would call an oil ring, like you would find in a Kohler, just 3 basic rings. A D-600 only has 2. Just basic rings. You can swap the 2 ring piston, for the 3 ring piston, if you change the rod. The jug remains the same. If you do swap, you are to use a 32-1 mix, instead of the 16-1 mix, required by the 3 ring piston. I have never understood the why of this.    ???????
bc.gold
Rings also act as scrapers with the 3 ring piston the richer 16:1 mix was required to leave sufficient lubricating film on the cylinder wall.
Edited by bcgold
Pullstart
Anyone ever heard of adding a splash of ATF to their fuel or oil?  I’ve mentioned this before but a high school auto shop teacher taught me.  ATF has a high level of detergents in addition to extra lubrication properties.  I am never afraid to run as much as a quart in a full tank of auto fuel.  A little less mixture to small engines, based in tank size of course.
Gregor
I have often wondered if MMO is ATF.
chucksterock
I mix my leftover race gas mix 50:50 with straight gas to burn up the old mixed fuel.  Smells really good mowing with more than a hint of race gas and no smoke.  I run Klotz super techniplate oil which is a mix of synthetic and castor.  Plus the wife likes the smell too.
  • Like 3
  • Excellent 1
tom2p
I will sometimes dump a little premix in the tank of the Wheel Horse tractors when I fill them ... just a small amount
on a Kohler powered 312 and an Onan powered 416
been doing this for over 20 years
have anyone compared a 2 stroke fuel system (carb, lines, tank) to a 4 stroke ... ? ... after sitting ?
a little oil goes a long way
Edited by tom2p
  • Similar Content
    • JoeM
      By JoeM
      The Ethanol Monster strikes again!
      Got out the pressure washer and went to start it, "no dice"
      Opened the carb and found those typical ethanol pearls, as I call them.
      I used an additive in my fuel last year, Ethanol Shield, did not seem to work very well.
      Not wanting to drive 30 miles for fuel, and still skeptical about if it is true ethanol free.
      Switched over to Lucas additive now.
      Will see.
      FYI
      Joe
    • RJ Hamner
      By RJ Hamner
      Let me first say that it ran when I brought it home.  Drove it around the guys yard, tried out the mower, drove it onto the trailer and drove it off the trailer and into the garage.
      I've done a "ground up" restore on the tractor (70 Charger 12).  Swapped out the breakerless for a battery ignition and swapped out the 10 amp for a 15 amp stator, flywheel and regulator.
      Pulled the head, looked pretty good, new head gasket and head bolts.new fuel pump, fuel lines,new switches and wiring, new aftermarket carb, new coil, coil wire, new points, new throttle and choke cables.
      Static timed (twice just to make sure) Have tried Autolite 216's and the hotter 437's. changed the condenser to the high dollar Kohler one.
      It will idle but when I give it some throttle it stumbles or will rev up a little then quits.
      I've gone thru the "trouble shooting " steps multiple time and to no avail
      Anyone got any ideas??  I am willing to try most anything at this point
      Bob
    • Team70R
      By Team70R
      I was mowing with my C165 today and it sputtered and stalled like it ran out of fuel. When I looked at the fuel line coming from the fuel pump to the carb, the fuel was boiling!! Do I need to change the exhaust route or ?
      IMG_2929.MOV
    • Team70R
      By Team70R
      Waiting on the eBay electric fuel pump to show up for the C165. Only thing I'm not sure about is what to do with the old mechanical one. Do I just leave it in place or do I need to make a cover plate with the a gasket and remove it?
    • Bigwatersig
      By Bigwatersig
      So I rebuilt carb and replaced fuel pump, thought fuel pump would fix my problems. No such luck! Still stalled out when she got hot. Took apart fuel tank shutoff, cleaned and lubed o ring, knocked some dirt out of vent tube with long wire, blew long fuel line, drained tank and tried some air pressure both ways, tank fuel outlet, and thru vent tube. Doesnt allow hardly any air flow either way? What is between tank and vent tube? A really small orifice, or some sort of pressure valve vent device? Put it back together and ran her with coffee filter banded over cap, NO PROBLEMS! Was so glad to move some dirt that I never tried putting cap back on! I think maybe there was blockage at tank shutoff, valve was very stiff and difficult to turn. Looks like a major ordeal to access fuel tank???
      I will try putting fuel cap on tomorrow, but I had ran her prieviously with cap loose so I think my problem is solved. Vent sure doesnt seem right though?
