Zeek 2,299 #1 Posted February 27, 2021 So my neighbor wants me to rewire her horse trailer for a trip out of state. That means from the plug in the front all the way back to the new tail lights. I do not need to wire the brakes, just two tail lights and the two front yellow side markers. Since it's enclosed I can run the wire down along the inside along the roof line as opposed to the underside. I can get the kit and all I need and I know how to do the actual wiring. My question is fastening (quickly) the wiring from front to rear which is 24'. The roof/sides are attached directly to the crossmembers with literally NO space to slide a ziptie through, nothing to loop around. I was considering this ziptie with self-tapping screws. Any other ideas from this resourceful bunch? 2 Share this post Link to post Share on other sites
SylvanLakeWH 31,133 #4 Posted February 27, 2021 Both of those should be good clean options... 1 Share this post Link to post Share on other sites
oldlineman 1,680 #5 Posted February 27, 2021 If you don't trust the sticky in Ed' s idea you could add a zip screw in the center. I have used these in electrical equipment many times, but not sure how they would hold up in a trailer. Bob 2 1 Share this post Link to post Share on other sites
Ed Kennell 45,813 #6 Posted February 27, 2021 I have used the peel and stick tie mounts in electrical cabinets for years where there is a lot of heat and they lasted forever. I don't remember the manufacturer and I am sure there are some el-cheapos that don't stick, but they worked for me. 2 Share this post Link to post Share on other sites
Zeek 2,299 #7 Posted February 27, 2021 2 hours ago, Ed Kennell said: I have used the peel and stick tie mounts in electrical cabinets for years where there is a lot of heat and they lasted forever. I don't remember the manufacturer and I am sure there are some el-cheapos that don't stick, but they worked for me. Thanks, I didn't think of that. I think I saw some on McMaster-Carr, but I'm sure Amazon has them as well. Share this post Link to post Share on other sites
R Scheer 512 #8 Posted February 27, 2021 I've used the Panduit sticky backs, they seemed to work well. The no names have become unsticky after a couple of years. I'd put zip screws in every so often, and where the wiring is changing direction, just to be safe. Ebmaines idea works well too. Gives the option of adding more wires later easily if necessary. I can see a request fot lights in the trailer the first time the horses are loaded, or unloaded at night. 3 Share this post Link to post Share on other sites
ranger 1,851 #9 Posted February 27, 2021 5 hours ago, ebinmaine said: I personally use this type of clip, or the plastic “P” clip, ( much cheaper). I’ve never had much luck with sticky clips unless they are in a clean environment and attached to a nice smooth surface away from any water / dirt/ vibration, not really possible on the underside of a trailer. Easy to fit too, using a cordless drill / screwdriver, especially when laying on your back, working overhead !!! 3 Share this post Link to post Share on other sites
