Wheel Horse 3D 3,825 #101 Posted May 12, 2021 Sooo if I can manage to bore the spindles I'll have less than $100 into the whole 1250lb setup! Share this post Link to post Share on other sites
Wheel Horse 3D 3,825 #102 Posted May 12, 2021 (edited) On 5/5/2021 at 6:57 PM, ebinmaine said: Yeah ya done good there. Any fab shops anywhere near you? Maybe they'd give you a decent deal? Cheapest quote thus far was 90 bucks plus. Still have an ear out for someone with a bit larger lathe I could borrow lol, Doing it on the mini will at LEAST require drilling a bit then changing to a longer bit or bar,(if at all possible) and repeating the process till i got to depth then finish the ID on the way out.With the shopsmith there may be a tiny bit off center, but that really wouldn't matter in this application. Dunno gonna have to get some roundstock and give it a shot at some point! Heck might be easier to get tubing with the 3/4 Id and machine the outer bearing surface. Edited May 12, 2021 by Wheel Horse 3D Share this post Link to post Share on other sites
wallfish 20,125 #103 Posted May 12, 2021 4 hours ago, Wheel Horse 3D said: Cheapest quote thus far was 90 bucks plus. Still have an ear out for someone with a bit larger lathe I could borrow lol, Doing it on the mini will at LEAST require drilling a bit then changing to a longer bit or bar,(if at all possible) and repeating the process till i got to depth then finish the ID on the way out.With the shopsmith there may be a tiny bit off center, but that really wouldn't matter in this application. Dunno gonna have to get some roundstock and give it a shot at some point! Heck might be easier to get tubing with the 3/4 Id and machine the outer bearing surface. I used 3/4 ID x 1" OD tube and then used a small piece of (I think ) 1" ID x 1 1/4 tube for the seal side. Much easier than boring out 1" spindles. If your 3/4 spindles don't have a threaded hole in the end you will need to drill and tap them to hold the bearings. Washer shims take up any slack for holding the bearings 2 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,825 #104 Posted May 12, 2021 7 minutes ago, wallfish said: I used 3/4 ID x 1" OD tube and then used a small piece of (I think ) 1" ID x 1 1/4 tube for the seal side. Much easier than boring out 1" spindles. If your 3/4 spindles don't have a threaded hole in the end you will need to drill and tap them to hold the bearings. Washer shims take up any slack for holding the bearings Was figuring as a weld on kit, so if i went the tube route id get 1 1/4 or 1.5 stock with .75 ID, machine down the 1" bearing surface, then tap the end for a crown nut to tighten down the bearings. Could do a slide on kit that way and have the crown nut cotter pin go through both the 1" and .75 axles at the outter end. Share this post Link to post Share on other sites
Charbs152 257 #105 Posted May 19, 2021 On 2/26/2021 at 11:21 AM, Wheel Horse 3D said: I HATE SHOVELS! Snow shovels, grain shovels, coal shovels, track shovels,flat, round, skinny(never mind I own at least one of every kind I can think of) I am an equal opportunity shovel hater! I don't mind rakes, hoes,or even the spud bar, but shovels....... every man has a few favorite hoes. 4 Share this post Link to post Share on other sites
MikMacMike 494 #106 Posted May 19, 2021 42 minutes ago, Charbs152 said: every man has a few favorite hoes. Hoe Hoe Hoe Merry Wheel Hoe to all, ops Horse to al hehehehehehe! 2 Share this post Link to post Share on other sites
Wheel Horse 3D 3,825 #107 Posted June 27, 2021 K Dug is finally officially Dig Dug! 4 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,825 #108 Posted June 27, 2021 Next steps! Front spindle upgrade Wide rear installation with spacers Steering upgrade?? (Some of the steering stifness is due to no weight currently in the box.) 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,825 #109 Posted June 27, 2021 New rear tires! 1 3 Share this post Link to post Share on other sites
Wheel Horse 3D 3,825 #110 Posted June 27, 2021 @ebinmaine missed yall and @OldWorkHorse the show! What were the details on the spacers you mentioned somewhere? Sticks in my mind for a ford ranger? 1 Share this post Link to post Share on other sites
ebinmaine 79,362 #111 Posted June 27, 2021 33 minutes ago, Wheel Horse 3D said: @ebinmaine missed yall and @OldWorkHorse the show! What were the details on the spacers you mentioned somewhere? Sticks in my mind for a ford ranger? I've got a list I keep in my notes I can send you. Links off the flea bay for products I used. 1 Share this post Link to post Share on other sites
ebinmaine 79,362 #112 Posted June 27, 2021 PM sent 1 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,825 #113 Posted June 28, 2021 Some other tweaks and mods... Replace shaker mounts with something non-shaker I had noticed a rub/buzz that happened at certain times especially when leaning to the right. It went away after @pullstart and I did a little modification to be sure the pump pulley cleared properly. I'm sure it was due to flex in the shaker mounts and I can see that flex when engaging the pump. Check and shim any play out of the steering system Do SOMETHING with the seat lol. 1 Share this post Link to post Share on other sites
Pullstart 70,286 #114 Posted June 28, 2021 I wouldn’t worry too much about the seat, unless you go full on dig/dug hoe turn table seat... Share this post Link to post Share on other sites
Wheel Horse 3D 3,825 #115 Posted June 28, 2021 Just now, pullstart said: I wouldn’t worry too much about the seat, unless you go full on dig/dug hoe turn table seat... Haven't decided turntable or flip over back. But the current one is still sticky from the flex seal attempt! Worked great at sealing the cracks, but everywhere else just didn't cure right. 1 Share this post Link to post Share on other sites
Pullstart 70,286 #116 Posted June 28, 2021 9 minutes ago, Wheel Horse 3D said: Haven't decided turntable or flip over back. But the current one is still sticky from the flex seal attempt! Worked great at sealing the cracks, but everywhere else just didn't cure right. Look at this guy... strong back and weak mind! Already forgot about that! What about another heavy coat of it to super flex seal it? Share this post Link to post Share on other sites
Wheel Horse 3D 3,825 #117 Posted June 28, 2021 Just now, pullstart said: What about another heavy coat of it to super flex seal it? That may work and would be an easy temp fix. Just gotta be sure to go thick all over i guess 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,825 #118 Posted June 28, 2021 Ooh and bucket pivot pin upgrades, thinking maybe ill upgrade all the pivots the same way. Grade 8s all the way around. 2 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,825 #119 Posted June 29, 2021 Dug and Dad gettin a little work done! 1 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,825 #120 Posted June 29, 2021 Got the bucket pivots replaced and those bolts worked perfectly! So now Im gonna replace the other pivots and add in washers wherever needed to remove a bit of wiggle in there. 2 1 Share this post Link to post Share on other sites
Pullstart 70,286 #121 Posted June 30, 2021 How many tons of dirt have you transported yet Grey? Share this post Link to post Share on other sites
Wheel Horse 3D 3,825 #122 Posted June 30, 2021 (edited) 20 minutes ago, pullstart said: How many tons of dirt have you transported yet Grey? Just a light bucket of gravel thus far. Mostly scraping and smoothing. There IS a big mound of clay in the dog yard I could push around a bit, and I've been meaning to bury some dog houses for the pack(55 gal plastic barrels) Mrs. Is already asking me to move flower beds and whatnot! Also gonna have to regrade my front yard entrance slope for Dug, that weight box doesn't allow me much angle.Something I'll take into consideration when I get around to the backhoe. Also gonna have to add me a lifting shackle, tons of stuff I can think of lifting with a strap. Edited June 30, 2021 by Wheel Horse 3D 1 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,825 #123 Posted June 30, 2021 I posted In the "What did ya do today" the fuel issue I had with Dug, but want to put it here as well for the record. Got a hold of a bad can of gas and ended up flushing the tank and lines, two squirts of starter fluid to get everything goin, and were golden! Did a little bit of carb adjustment while I was at it and got a much lower idle than before and now have a better throttle range. Re adjusted the pump tension a little. This evening will be putting in all the other pivots. 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,825 #124 Posted June 30, 2021 Grade 8 7/16 x 20 1.5" for lug nut switch over. 1 Share this post Link to post Share on other sites
Handy Don 16,818 #125 Posted June 30, 2021 8 hours ago, Wheel Horse 3D said: tons of stuff I can think of lifting with a strap When your favorite tool is a loader, every problem looks like a movable load! 1 1 Share this post Link to post Share on other sites
