steader 26 #1 Posted February 19, 2021 Just got a b 100 and need to plow a field. What do I need? Share this post Link to post Share on other sites
ebinmaine 76,184 #2 Posted February 19, 2021 I'm a woods dweller so I'll call in some plow dogs... @PeacemakerJack @WHX24 @Achto @pullstart Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,886 #3 Posted February 19, 2021 Do you have a plow now and will it connect to the tractor's rear hitch? Garry Share this post Link to post Share on other sites
Pullstart 68,572 #4 Posted February 19, 2021 We love us some field plowing! How much ground are you looking to turn? Here’s a small thread started by a plow dog @PeacemakerJack and will cover good and bad times both. What do you need though? More weight than you’d ever think, a good set of Ag tires and the right soil moisture content will be your friend! 2 Share this post Link to post Share on other sites
953 nut 63,370 #5 Posted February 19, 2021 8 hours ago, steader said: need to plow a field. What do I need? Probably need to let the ground thaw out first. Seriously, there needs to be a rear hitch capable of attaching and lifting a plow. There should be a cable from the lift lever rocker shaft (part 19) going back to the lift. Lowell https://wheelhorsepartsandmore.com/ can fix you up with a cable if you need one and Lincoln https://a-ztractor.com/ can help with a hitch and plow. Also you may want tp place an ad here for what you need. https://www.wheelhorseforum.com/classifieds/wanted/?do=form&d=2 Share this post Link to post Share on other sites
Achto 30,346 #6 Posted February 19, 2021 You will need a plow, a slot hitch with a Brinly adapter, or a Brinly hitch, the cable for the slot hitch, and weight. This would allow you to run a Brinly plow. If you happen to have a plow you will need the slot hitch, the cable for the slot hitch, and weight. 1 1 Share this post Link to post Share on other sites
Pullstart 68,572 #7 Posted February 19, 2021 And weight. 2 1 Share this post Link to post Share on other sites
oliver2-44 11,099 #8 Posted February 19, 2021 Check that your tractor has the arm on the arm on the Rockshaft for the Rear Hitch (#19 in diagram posted above) Seems I've read some of the later B series did not have it. Share this post Link to post Share on other sites
