Horse Newbie 7,405 #1 Posted February 13, 2021 (edited) I've ordered a set of decals for my 1994 520H from @Vinylguy. I have found removing the old adhesive from the paint surface rather difficult. I have tried WD-40, mineral spirits, brake cleaner, vaseline, Goo Gone, Goof Off, Windex, and about anything else I can think of. Do any of you have any tips for removing the old adhesive ? I plan on watching @Vinylguy 's tutorial on " Redoyourhorse.com before I apply the new decals. Thanks, Tim Edited February 13, 2021 by Horse Newbie Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #2 Posted February 13, 2021 6 minutes ago, Horse Newbie said: I've ordered a set of decals for my 1994 520H from @Vinylguy. I have found removing the old adhesive from the paint surface rather difficult. I have tried WD-40, mineral spirits, brake cleaner, vaseline, Goo Gone, Goof Off, Windex, and about anything else I can think of. Do any of you have any tips for removing the old adhesive ? I plan on watching @Vinylguy 's tutorial on " Redoyourhorse.com before I apply the new decals. Thanks, Tim Did you use heat (heat gun/hair dryer) when removing them?, this usually lends to more complete adhesive removal. Plain isopropynol alcohol may be your best bet now after heating with a hair dryer. 5 Share this post Link to post Share on other sites
Mike in NC 342 #3 Posted February 13, 2021 (edited) 3M makes an adhesive remover and it works great. Do you have an automotive paint supplier near you? They should have it. It comes in a liquid or a spray. Here is a link of pictures of some of the 3M products. 3M Adhesive Remover Edited February 13, 2021 by Mike in NC 5 2 1 Share this post Link to post Share on other sites
JCM 11,406 #4 Posted February 13, 2021 Both answers to your question are right on. Hair dryer to remove decal then 3M # 08984 general purpose adhesive cleaner. This part # is a 1 quart can which I find used on a rag is more controllable than the spray can. 4 1 1 Share this post Link to post Share on other sites
c-series don 12,382 #5 Posted February 13, 2021 Heat gun, there’s a fine line between just enough heat and too much. Too much heat and you will leave glue residue, not enough and they won’t peel. Just right and they should come off with little residue. Then as Mike said 3M adhesive remover works great. 2 1 Share this post Link to post Share on other sites
Zeek 2,299 #6 Posted February 14, 2021 I use a heat gun to get the vinyl off and then Toluene (Lowes) to take the adhesive off. Xylene works too. Quicker dry means less damage to under surface, if any. I use it to wipe stuff pre-paint so there is no orange peel. 2 1 Share this post Link to post Share on other sites
Horse Newbie 7,405 #7 Posted February 14, 2021 2 hours ago, WVHillbilly520H said: Did you use heat (heat gun/hair dryer) when removing them?, this usually lends to more complete adhesive removal. Plain isopropynol alcohol may be your best bet now after heating with a hair dryer. Thanks @WVHillbilly520H for the response...don't remember what thread it may have been on ( I was probably off topic )... but I must have misunderstood. I remember someone suggesting a heat gun or hair dryer, but I thought they were talking about removing the plastic "silver horse" at the front of the hood. The decals themselves have not been that hard to remove... Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #8 Posted February 14, 2021 2 minutes ago, Horse Newbie said: Thanks @WVHillbilly520H for the response...don't remember what thread it may have been on ( I was probably off topic )... but I must have misunderstood. I remember someone suggesting a heat gun or hair dryer, but I thought they were talking about removing the plastic "silver horse" at the front of the hood. The decals themselves have not been that hard to remove... Its for anything with adhesive, it softens the glue to aid in removal, just don't overheat it. 1 Share this post Link to post Share on other sites
Horse Newbie 7,405 #9 Posted February 14, 2021 2 hours ago, Mike in NC said: 3M makes an adhesive remover and it works great. Do you have an automotive paint supplier near you? They should have it. It comes in a liquid or a spray. Here is a link of pictures of some of the 3M products. 3M Adhesive Remover Thanks @Mike in NC, I'm sure I will be able to find it somewhere... 1 Share this post Link to post Share on other sites
Achto 32,513 #10 Posted February 14, 2021 One of these works exceptionally well for removing decals and decal residue. It will not damage the paint unless you sit in one spot long enough to heat the paint enough to burn it. You really have to try for this to happen though. Other companies make a similar product at a lower price but I prefer the 3M ones. https://www.amazon.com/Stripe-Wheel-07498-Diameter-Mandrel/dp/B00063VT0G/ref=asc_df_B00063VT0G/?tag=hyprod-20&linkCode=df0&hvadid=309807921328&hvpos=&hvnetw=g&hvrand=2671441513515824199&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9019452&hvtargid=pla-451421021261&psc=1 1 1 Share this post Link to post Share on other sites
Digger 66 3,530 #11 Posted February 14, 2021 Hair dryer : 2 Share this post Link to post Share on other sites
