Jeff-C175 7,211 #26 Posted February 9, 2021 20 minutes ago, Ed Kennell said: 0.105" dia. string trimmer line Good idea. I have plenty of that too! I also have some plastic coated fishing line that might be suitable. "SHARK! SHARK!" Share this post Link to post Share on other sites
Handy Don 17,316 #27 Posted February 9, 2021 (edited) My guess is the temp of the air being pushed into the air cleaner housing isn't being changed much by engine heat in its very short passage through the tins. I suspect that tube's main purpose is to source intake air from a place away from the top of the engine keeping it cooler. Unless you're worried about carb icing (pretty unlikely with the carb sitting next to the exhaust manifolds!), I can't think why you'd need warm air for combustion. Engines run better with cool air intake. Am I missing something? Edited February 9, 2021 by Handy Don Share this post Link to post Share on other sites
WHX?? 57,804 #28 Posted February 9, 2021 (edited) Lowell has those lift flags and the plastic covered cable. I also have a newer short chute that I am probably going to parts out if you need those wings and turner spool thingy Ed mentioned Jeff... guessing they might fit. Might even have that lift flag. Edited February 9, 2021 by WHX24 1 Share this post Link to post Share on other sites
Jeff-C175 7,211 #29 Posted February 9, 2021 (edited) 22 hours ago, Handy Don said: carb icing (pretty unlikely with the carb sitting next to the exhaust manifolds!), Not unlikely at all actually. My 70 Chevelle SS suffered terribly from it. Past two snows I had to stop plowing twice to use my heat gun on the manifold and carb to prevent the engine from stalling out. There was about 1/4" of ice on the outside of the intake manifold. Imagine what was inside! When there's high humidity as there has been with these wet snows, and the temps are hovering below freezing, icing is a real concern. Throttle bodies on modern engines have coolant run through them for this reason. Things get incedibly cold when air is pumped through stuff. Ever drain water out of an air compressor tank? Even in the heat of summer my drain valve freezes up! (hmmm, sounds like a personal problem!) Edited February 9, 2021 by Jeff-C175 Share this post Link to post Share on other sites
Handy Don 17,316 #30 Posted February 9, 2021 Ok, got it. Icing can occur, though I cannot recall seeing it mentioned on this site or with regard to small engines. Have you had it happen to one? Now that you bring it up, though, I realized a lot of snowblower engines have a shroud around the carb fed by air heated by the engine fins. Always thought it was to keep snow off but maybe.... I suspect the Chevelle was moving a lot more air through that carb than an 800 cc Onan twin. if it is a concern, perhaps it'd be easier to get more heat from the "hot" side to combat that. Maybe a flap on one of the the exhaust manifold covers (which direct blower air around the manifolds after it has passed through the engine fins). Share this post Link to post Share on other sites
Jeff-C175 7,211 #31 Posted February 9, 2021 1 minute ago, Handy Don said: Have you had it happen to one? Yep, twice in the storm last week and once this recent storm. It happened enough with the KT engines that either WH or maybe it was Kohler had enough complaints that they saw the need to come up with a solution. The Chevelle was a problem because I was not running the stock air filter which included a hose down to the shield around the exhaust manifold. Nearly all carburated cars of the period had that tube to the exhaust manifold. 99% of the time it wasn't needed. Icing only occurs when conditions are high humidity with low temps. Generally when it's cold out the air is dry enough that icing doesn't occur. Here in Joisey by the 'shaw' we get those conditions fairly often. The Chevelle would ice around the venturis even when temps were in the 40s. It would start running like crap and a look inside the carb you could see the icicles hanging from the venturis. I had to run with the stock air filter Spring and Fall. Share this post Link to post Share on other sites
Jeff-C175 7,211 #32 Posted February 9, 2021 1 hour ago, WHX24 said: newer short chute that I am probably going to parts out Looks better than the one I've got! Feel free to PM me if you want to talk prices and stuff! I'd probably be interested in nearly every moving part if the bearings and such are in good shape. Heck, I would buy the whole thing if shipping weren't going to be prohibitive! Share this post Link to post Share on other sites
Ed Kennell 46,985 #33 Posted February 9, 2021 1 hour ago, WHX24 said: Now Jim, I know you didn't put those wings on there backwards. But we don't want to lead Jeff astray. 1 Share this post Link to post Share on other sites
Jeff-C175 7,211 #34 Posted February 9, 2021 22 minutes ago, Ed Kennell said: don't want to lead Jeff astray ummmm... I think it's about 50 (or more!) years too late for that! 2 Share this post Link to post Share on other sites
Jeff-C175 7,211 #35 Posted February 9, 2021 12 hours ago, Jeff-C175 said: I'm not real sure why they are taking intake air from under the tins in the first place I think I figured it out. They're using the cooling air fan on the flywheel as a supercharger! 1 Share this post Link to post Share on other sites
Jeff-C175 7,211 #36 Posted February 9, 2021 (edited) why did this post 3X ? Can I delete posts I made? Edited February 9, 2021 by Jeff-C175 Share this post Link to post Share on other sites
Jeff-C175 7,211 #37 Posted February 9, 2021 (edited) why did this post 3X ? Can I delete posts I made? Edited February 9, 2021 by Jeff-C175 1 Share this post Link to post Share on other sites
WHX?? 57,804 #38 Posted February 9, 2021 3 hours ago, Jeff-C175 said: why did this post 3X ? It happens! 13 hours ago, Ed Kennell said: I know you didn't put those wings on there backwards. No I did not that pic is from when I picked it up but rest assured I did flip them around! It's actually in way better shape now I went through it end to end, all stainless hardware, new bearings, sprocket & idlers. The only problem is the chute base is messed up & probably could be repaired but not by me. I'm tall chute & deuce blower heavy now. Plan was & still is to haul it out to the BS if someone wants it. 1 Share this post Link to post Share on other sites
Ed Kennell 46,985 #39 Posted February 9, 2021 18 hours ago, Ed Kennell said: 18 hours ago, Ed Kennell said: think my KT17 has a winter or summer position for the air cleaner inlet. Yep it is the KT17. I use the summer position as this is a mower only. The air cleaner connects to this hole in the tins for winter use. Share this post Link to post Share on other sites
Jeff-C175 7,211 #40 Posted February 9, 2021 4 hours ago, Ed Kennell said: KT17 Series II I think? Not sure when they switched from the teardrop to the top hat air filter housing. Share this post Link to post Share on other sites
Jeff-C175 7,211 #41 Posted February 9, 2021 6 hours ago, WHX24 said: No I did not that pic is from when I picked it up but rest assured I did flip them around! I'm lookin' and lookin' at the pic and not sure how they are 'backward'? Is the 'bent' edge supposed to og on the housing? I don't see any bolt holes along the other edge... and I blew the pic way up! But, I'm blind in one eye and can't see outta the other ... so... Share this post Link to post Share on other sites
Ed Kennell 46,985 #42 Posted February 9, 2021 Jeff, the bend in the leading edge of wing should be parallel to the side of the blower housing, not sticking as in the pic. They can be flipped over of switched to opposite sides 1 Share this post Link to post Share on other sites
WHX?? 57,804 #43 Posted February 9, 2021 The front bent edge of the wing is supposed to be parallel with the blower. Acts as a drift cutter that way. Some guys put them on backwards thinkin they would grab more snow. Share this post Link to post Share on other sites
WHX?? 57,804 #44 Posted February 9, 2021 Ed's a faster typer.... Share this post Link to post Share on other sites
Jeff-C175 7,211 #46 Posted February 9, 2021 (edited) 10 minutes ago, WHX24 said: drift cutter OK, I see it now. So they're 'upside down' but not necessarily 'backwards' if you follow my logic. Yeah, makes no sense to put that extra load on the end of the wing. Should cut the snow for sure. Edited February 9, 2021 by Jeff-C175 Share this post Link to post Share on other sites
WHX?? 57,804 #47 Posted February 10, 2021 On backwards they can actually pull you over into the drifts & banks. Tom @Shynon built some nifty plates that went from the leading edge back to the housing. If he ain't slumped and passed out in his machineing corner maybe a pic Tom? Share this post Link to post Share on other sites
Shynon 7,646 #48 Posted February 10, 2021 I put these sides on the wings 1 Share this post Link to post Share on other sites
Jeff-C175 7,211 #49 Posted September 5, 2021 (edited) Finally started on the blower today, making a shopping list of parts I need. Jim @WHX??do you still have the blower you were thinking of parting out? or did it go to the BS and get sold? This one has a few minor (fixable) issues with the sheet metal that a welder, hammer and dolly will fix right up. There's some cross-pollination between two threads about my snow moving stuff so I'm linking the other one here: Edited September 5, 2021 by Jeff-C175 Share this post Link to post Share on other sites
Jeff-C175 7,211 #50 Posted September 7, 2021 (edited) How do I get this collar off? Nothing to grab onto with my 3 jaw pullers! Now that I've got it all apart and started on the sheet metal repairs, it's become clear that this thing took a bruisin'. It appears the whole shell is twisted about 3/4" caddy wompus. Not sure how (or IF, I might not NEED to...) I can straighten it. Hopefully even with a little twist it will assemble and run correctly. But I DO need to get that collar off, that bearing seems to be in bad shape. Edited September 7, 2021 by Jeff-C175 Share this post Link to post Share on other sites
