ebinmaine 81,289 #26 Posted February 9, 2021 LOTS of great welding videos online!! Share this post Link to post Share on other sites
BeninCT 451 #27 Posted February 9, 2021 Watched a lot of them just need practice and more patience is all. The welds are strong with good penetration just bumpy and ugly. 2 Share this post Link to post Share on other sites
ebinmaine 81,289 #28 Posted February 9, 2021 31 minutes ago, BeninCT said: Watched a lot of them just need practice and more patience is all. The welds are strong with good penetration just bumpy and ugly. Just due to the fact that you already know what you need to do tells me you'll figure it out. What are you using for a welder? Share this post Link to post Share on other sites
BeninCT 451 #29 Posted February 9, 2021 7 hours ago, ebinmaine said: Just due to the fact that you already know what you need to do tells me you'll figure it out. What are you using for a welder? Lincoln 220V mig setup with argon mix. I have made a few really nice beads so its coming. Finished this thing today and its so strong its totally ridiculous. I bet I could put a 2’ piece of square tube in there and put 1000lbs on the end and the front wheel sof the tractor would pop right off the ground. Total overkill. Zero flex in it with my 230 lbs on it bouncing up and down. Pretty happy with it aside from my welding haha. Makes me think I need a rear bumper/step to put in it, weight rack and weights, maybe a work box to have on in summer months, lawn roller, what else am I missing? 3 Share this post Link to post Share on other sites
DennisThornton 4,773 #30 Posted February 9, 2021 28 minutes ago, BeninCT said: Lincoln 220V mig setup with argon mix. I have made a few really nice beads so its coming. Finished this thing today and its so strong its totally ridiculous. I bet I could put a 2’ piece of square tube in there and put 1000lbs on the end and the front wheel sof the tractor would pop right off the ground. Total overkill. Zero flex in it with my 230 lbs on it bouncing up and down. Pretty happy with it aside from my welding haha. Makes me think I need a rear bumper/step to put in it, weight rack and weights, maybe a work box to have on in summer months, lawn roller, what else am I missing? Nice! And yes, probably overkill but it's one thing you won't have to worry about ever. As soon as I build mine this or similar is going on it. 1 Share this post Link to post Share on other sites
BeninCT 451 #31 Posted February 9, 2021 Thanks! I like that Dennis though might be too big for where I end up running this thing. Might want higher sids too and a solid floor to keep the stuff from bouncing out. Either way you have options 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #32 Posted February 9, 2021 18 hours ago, BeninCT said: @ebinmaine thank you but there is some ugly welding on this thing. Still working on my beads and maybe 1/3 of them are respectable that that leaves a majority to rule. I make up for it with grinding when I feel like it. Can you believe how big it is compared to the factory unit? Haha. Had to move my tail light to the hitch to keep it safe. New painters fear running the paint. I recommend running the paint and then back off. Serious, the best paint job is where ALL of it is JUST about to slide off! Same with new welders. If you don't burn through from time to time your amperage isn't high enough. After practicing pushing the edge your paint won't run anymore and your welds won't go through. But in the beginning burn through something! Test piece perhaps? 1 1 Share this post Link to post Share on other sites
rjg854 13,455 #33 Posted February 9, 2021 30 minutes ago, DennisThornton said: Nice! And yes, probably overkill but it's one thing you won't have to worry about ever. As soon as I build mine this or similar is going on it. Something like this one 4 Share this post Link to post Share on other sites
DennisThornton 4,773 #34 Posted February 9, 2021 6 minutes ago, BeninCT said: Thanks! I like that Dennis though might be too big for where I end up running this thing. Might want higher sids too and a solid floor to keep the stuff from bouncing out. Either way you have options Yeah, it's too wide as is. I've already got it but rather than cut it down I'll most likely make something more suitable. I mounted a luggage rack on my C-85 blackhood. Rough anyway so it didn't cause tears. But the rack gets used a lot for light stuff. I'd like something for 5 gal buckets for the rear. Not sure where I loose steering but surely I could haul 2 sideways. Share this post Link to post Share on other sites
DennisThornton 4,773 #35 Posted February 9, 2021 2 minutes ago, rjg854 said: Something like this one Slick! Share this post Link to post Share on other sites
DennisThornton 4,773 #36 Posted February 9, 2021 2 minutes ago, rjg854 said: Something like this one And did the front weights help with the added weight or with steering in general? Share this post Link to post Share on other sites
rjg854 13,455 #37 Posted February 9, 2021 I had the full set so why not use them 2 Share this post Link to post Share on other sites
DennisThornton 4,773 #38 Posted February 9, 2021 Oh! I've always wanted and never took the time to build something like this: 3 Share this post Link to post Share on other sites
DennisThornton 4,773 #39 Posted February 9, 2021 2 minutes ago, rjg854 said: I had the full set so why not use them Donate to a good cause? Same state. You could still come and visit them. Seriously though, can you tell if the additional up front helps? I have several rears but no fronts. Share this post Link to post Share on other sites
rjg854 13,455 #40 Posted February 9, 2021 1 minute ago, DennisThornton said: Donate to a good cause? Same state. You could still come and visit them. Seriously though, can you tell if the additional up front helps? I have several rears but no fronts. On my plow tractor along with roller chains yes they do help keep me on the straight and narrow while plowing. 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #41 Posted February 9, 2021 1 minute ago, rjg854 said: On my plow tractor along with roller chains yes they do help keep me on the straight and narrow while plowing. Reminds me. Think I just remembered where my #40 repair links are. Thanks for the feedback. I hate not being able to steer. I did without brakes on my snowplow tractor for years. Just fixed it and I keep forgetting to use them! Really need steering at least when you can't stop with the blade down. Doesn't help that the new to me Bolens and the C-85 are my snow plow tractors and the Bolens has a combo clutch break on the left and or course you know how the WHs are. 1 Share this post Link to post Share on other sites
ebinmaine 81,289 #42 Posted February 9, 2021 1 hour ago, BeninCT said: Makes me think I need a rear bumper/step to put in it, weight rack and weights, maybe a work box to have on in summer months, lawn roller, what else am I missing Do a Google search for something like 2-in hitch implements... Overkill. Well I mean I guess you don't want to be hanging enough steel out there to build a battleship from but having a great strong hitch to connect to could hardly be called Overkill... 51 minutes ago, DennisThornton said: After practicing pushing the edge your paint won't run anymore and your welds won't go through. But in the beginning burn through something! Test piece perhaps That is some absolutely excellent advice there. 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #43 Posted February 9, 2021 The worst welds I ever saw weren't from burning or blowing through but from half melted rod piled on top of layer after layer thinking that if you got enough it would hold. Might as well have used drywall compound! Welding needs melting some of the base metal. 1 Share this post Link to post Share on other sites
squonk 48,429 #44 Posted February 9, 2021 Another vote for the frt. hitch! 2 3 Share this post Link to post Share on other sites
DennisThornton 4,773 #45 Posted February 9, 2021 1 minute ago, squonk said: Another vote for the frt. hitch! Can't get much better than that! Strength and height! And steering! With no neck aches! 1 Share this post Link to post Share on other sites
BeninCT 451 #46 Posted February 9, 2021 (edited) 3 hours ago, DennisThornton said: New painters fear running the paint. I recommend running the paint and then back off. Serious, the best paint job is where ALL of it is JUST about to slide off! Same with new welders. If you don't burn through from time to time your amperage isn't high enough. After practicing pushing the edge your paint won't run anymore and your welds won't go through. But in the beginning burn through something! Test piece perhaps? I just need patience is all. I’m busy so always in a rush sadly but like to get stuff done so I rush. Working on it lol. I understand the science and technique and I get good penetration. I see a lot worse with paint on it too so not worried. It’s a tractor! I can imagine myself as a better welder looking at old projects/welds though later in life and cringing. Haha Edited February 9, 2021 by BeninCT Share this post Link to post Share on other sites
BeninCT 451 #47 Posted February 9, 2021 2 hours ago, rjg854 said: On my plow tractor along with roller chains yes they do help keep me on the straight and narrow while plowing. You have #40 roller chains around your fronts? Put them on deflated and pump up until tight? Been thinking about that- plow pushes front sideways sometimes. Slick setup you have there- looks like its way too far out but now that I have this hitch I know that it could handle that. Crazy strong Share this post Link to post Share on other sites
DennisThornton 4,773 #48 Posted February 9, 2021 11 minutes ago, BeninCT said: I just need patience is all. I’m busy so always in a rush sadly but like to get stuff done so I rush. Working on it lol. I understand the science and technique and I get good penetration. I see a lot worse with paint on it too so not worried. It’s a tractor! I can imagine myself as a better welder looking at old projects/welds though later in life and cringing. Haha A huge hurdle to success is the fear of failure! Sometime on some project just spray nothing but runs! Blowup and burn through every weld! Get it over with. I'd say that someone who has never shot a run or burned through hasn't learned how to paint or weld. Perfection is just a touch less than total failure! Learn how to fail! And then back off a little bit! And yes, practice really does help with everything! But so does failure! And knowing why! Push until you fail and watch and learn. 1 Share this post Link to post Share on other sites
rjg854 13,455 #49 Posted February 10, 2021 21 minutes ago, BeninCT said: You have #40 roller chains around your fronts? yes Put them on deflated and pump up until tight? yes Been thinking about that- plow pushes front sideways sometimes. It will help against that 21 minutes ago, BeninCT said: Slick setup you have there- looks like its way too far out but now that I have this hitch I know that it could handle that. Crazy strong It's a combination of things that make it do that. The 2" receiver goes into the slot hitch and then the deck goes into the receiver. It's made for an atv, but I cut it down to the width of the tractor. I use it to take my recycling bins down to the highway, trash on trash day, and retrieving packages that come in the mail, for now. It's rated for 500lbs. It's easier and quicker than having to hook up the tub trailer each time. I can leave it on the tractor and it doesn't take up much room. 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,379 #50 Posted February 10, 2021 This is something I made up years ago for the clevis hitch, let go with the xi I sold a few years back. 4 Share this post Link to post Share on other sites
