squonk 46,840 #1 Posted January 18, 2021 I am getting old Recently retired so I have time to do nothing all day. I replaced the old fluorescent lights a couple weeks ago with LED'S so I can somewhat see again. I was working on the 953 that I HAVE OWNED FOR 2 1/2 YEARS. I noticed what looks like a patch in the block right where a rod would have known to come out to say HI! It's not causing any issues and if it is a patch somebody did one heck of a job. What do you think? 7 Share this post Link to post Share on other sites
ebinmaine 79,124 #2 Posted January 18, 2021 Ain't that somethin. I agree it looks like it's patched. Absolutely would not mess with it until or if it ever presents a leak. Share this post Link to post Share on other sites
pfrederi 20,657 #3 Posted January 18, 2021 If it works don't ____ with it!!! 5 Share this post Link to post Share on other sites
squonk 46,840 #4 Posted January 18, 2021 Oh I ain't touchin it! Unless maybe I drop a 16 HP Thumper in there! 6 Share this post Link to post Share on other sites
stevasaurus 23,705 #5 Posted January 18, 2021 Did you find that using the brail method.?? Bet you won't be jumping any stone piles with that girl. 1 2 Share this post Link to post Share on other sites
squonk 46,840 #6 Posted January 18, 2021 5 minutes ago, stevasaurus said: Did you find that using the brail method.?? Bet you won't be jumping any stone piles with that girl. I used the "I was blind, now I can see" method. A blind squirrel can find a nut once in a while! 4 Share this post Link to post Share on other sites
Stepney 2,357 #7 Posted January 18, 2021 Least it was welded, once upon a time I had a 16hp single B&S powered Roper with a pop-riveted license plate over the side of the block. They had a large cork sheet under it.. only thing that killed it the second time was the cork fragmenting, and plugging up the rod bearing oil hoke.. too bad. 1 1 Share this post Link to post Share on other sites
WHNJ701 4,172 #8 Posted January 18, 2021 7 minutes ago, Stepney said: Least it was welded, once upon a time I had a 16hp single B&S powered Roper with a pop-riveted license plate over the side of the block. They had a large cork sheet under it.. only thing that killed it the second time was the cork fragmenting, and plugging up the rod bearing oil hoke.. too bad. The cork fragments remind me of the old timer years ago telling us about back in the day they used to pack car differentials full sawdust at some repair place 2 Share this post Link to post Share on other sites
DennisThornton 4,773 #9 Posted January 18, 2021 5 minutes ago, Stepney said: Least it was welded, once upon a time I had a 16hp single B&S powered Roper with a pop-riveted license plate over the side of the block. They had a large cork sheet under it.. only thing that killed it the second time was the cork fragmenting, and plugging up the rod bearing oil hoke.. too bad. So I went to all the trouble to tear my K321 down, preheated the whole block, welded it, immediately covered it in hot ashes and waited overnight and all I really needed was a license plate and silicone instead of cork? Honestly, and I'm not a pro rebuilder, but all it needs is to not leak. Too darned bad the cork failed and or course went right for an oil hole! Murphy at work again! 2 Share this post Link to post Share on other sites
DennisThornton 4,773 #10 Posted January 18, 2021 1 minute ago, jabelman said: The cork fragments remind me of the old timer years ago telling us about back in the day they used to pack car differentials full sawdust at some repair place Special sawdust though! Share this post Link to post Share on other sites
Stepney 2,357 #11 Posted January 18, 2021 6 minutes ago, jabelman said: The cork fragments remind me of the old timer years ago telling us about back in the day they used to pack car differentials full sawdust at some repair place Seems to me Barney Fife bought a car just like that! 2 Share this post Link to post Share on other sites
D_Mac 9,337 #12 Posted January 18, 2021 I had an 84 Dodge Charger way back when. When I was looking to buy it the engine block had a small crack in it and it would leak coolant. A friend of mine told me to buy as the seller didnt want much because he thought the engine had to be replaced. So I bought it cheap. My buddy put some kind of goop on it and sealed it right up. I had that little car a few years and put many miles on it without any issues with it leaking ever again. I can not for the life of me remember what he used but it worked great. He used to work at a body shop so I trusted him when he said he could fix it. 2 Share this post Link to post Share on other sites
ebinmaine 79,124 #13 Posted January 18, 2021 @Stepney I've seen old flywheel engines in the way back past with that patchwork but not a newer type. @jabelman I used to work with a fellow who knew of a used car lot/garage the would do that. Quiet things down. ..just long enough. 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #14 Posted January 18, 2021 3 minutes ago, D_Mac said: I had an 84 Dodge Charger way back when. When I was looking to buy it the engine block had a small crack in it and it would leak coolant. A friend of mine told me to buy as the seller didnt want much because he thought the engine had to be replaced. So I bought it cheap. My buddy put some kind of goop on it and sealed it right up. I had that little car a few years and put many miles on it without any issues with it leaking ever again. I can not for the life of me remember what he used but it worked great. He used to work at a body shop so I trusted him when he said he could fix it. There are miracles in a can! Don't always work, sometimes because the diagnostician blew it or it's just too bad. I've used different leak stops for coolant, rear ends, autotrans and oil and was SO pleased that I tried them. Some miracles might get you home, finish your trip or last so long you forget them. Some might cost you whatever the retail is. My luck has been good. Of course I was the diagnostician... Share this post Link to post Share on other sites
squonk 46,840 #15 Posted January 18, 2021 54 minutes ago, D_Mac said: I had an 84 Dodge Charger way back when. When I was looking to buy it the engine block had a small crack in it and it would leak coolant. A friend of mine told me to buy as the seller didnt want much because he thought the engine had to be replaced. So I bought it cheap. My buddy put some kind of goop on it and sealed it right up. I had that little car a few years and put many miles on it without any issues with it leaking ever again. I can not for the life of me remember what he used but it worked great. He used to work at a body shop so I trusted him when he said he could fix it. That's amazing because the 84 Dodge 4 banger would start leaking when you opened the driver's door! 3 Share this post Link to post Share on other sites
Achto 31,898 #16 Posted January 18, 2021 1 hour ago, jabelman said: The cork fragments remind me of the old timer years ago telling us about back in the day they used to pack car differentials full sawdust at some repair place I had a friend pack 4lbs of hamburger into a diff to quiet it down so that he could get a better sales price on a car. I would have hated to be the poor soul that had to open that rear end up to fix it properly. 5 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #17 Posted January 18, 2021 13 minutes ago, squonk said: That's amazing because the 84 Dodge 4 banger would start leaking when you opened the driver's door! 6 cyls didn't Share this post Link to post Share on other sites
WHX?? 56,846 #18 Posted January 19, 2021 (edited) Ahhh lets back up here abit .... when the heck did I say you could retire Squonk!?! You ain't 62 till the end of next month so you ain't collectin SS yet. Digging up them mason jars in the back yard are we? I know you ain't flipping tractors for beer money unless you want me to low ball you on that Power King.... bet he's got a table set up on a street corner selling plug wires to buy a bottle of Thunderbird fellas! NAPA prolly wants you back 'cause you was good at wiping starter grease off the counters! Fine... retire while the rest of us slobs gotta work yet ..... Fine... I'm turning this thread ino a show us your cracked & repaired block then! What you laughing about @oliver2-44 ....... your K91 crank you been pining for may come out of this motor! Edited January 19, 2021 by WHX24 1 4 Share this post Link to post Share on other sites
squonk 46,840 #19 Posted January 19, 2021 3 minutes ago, WHX24 said: Ahhh lets back up here abit .... when the heck did I say you could retire Squonk!?! You ain't 62 till the end of next month so you ain't collectin SS yet. Digging up them mason jars in the back yard are we? I know you ain't flipping tractors for beer money unless you want me to low ball you on that Power King.... bet he's got a table set up on a street corner selling plug wires to buy a bottle of Thunderbird fellas! NAPA prolly wants you back 'cause you was good at wiping starter grease off the counters! Fine... retire while the rest of us slobs gotta work yet ..... Fine... I'm turning this thread ino a show us your cracked & repaired block then! What you laughing about @oliver2-44 ....... your K91 crank you been pining for may come out of this motor! Instead of buying 10 tractors a month, brand new trucks and campers, I don't owe a cent to anybody. Got enough cash to get by until SS kicks in in March . 2 3 1 Share this post Link to post Share on other sites
WHX?? 56,846 #20 Posted January 19, 2021 18 minutes ago, squonk said: Instead of buying 10 tractors a month, brand new trucks and campers, I don't owe a cent to anybody. Buy 'em then .... heard tell banks got plenty of money....life's too short and let yer kids figure yer debt out then...... 3 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #21 Posted January 19, 2021 Next time in WV I will have to get pic of the K161 block that was in the CC Original when dad bought it in 1977 and stayed running until the late 90s. You will love the patch on it. 2 Share this post Link to post Share on other sites
D_Mac 9,337 #22 Posted January 19, 2021 Sad looking back that Dodge had the stones to put the Charger name on those cars. To go from this to that... what were they thinking? 1 Share this post Link to post Share on other sites
squonk 46,840 #23 Posted January 19, 2021 (edited) 11 hours ago, D_Mac said: Sad looking back that Dodge had the stones to put the Charger name on those cars. To go from this to that... what were they thinking? Not only the engines leaked, the bodies did too! I re-sealed a ton of those cars. Pull the front fenders and grab the caulk gun Edited January 19, 2021 by squonk Share this post Link to post Share on other sites
squonk 46,840 #24 Posted January 19, 2021 (edited) 30 minutes ago, WHX24 said: Buy 'em then .... heard tell banks got plenty of money....life's too short and let yer kids figure yer debt out then...... There aren't any to buy anymore around here. Really dried up. You see the same tractors for sale week after week Way overpriced. Paid cash 2 years ago on the GMC. Wife's Toyota has almost 150 on it. Just broken in. Edited January 19, 2021 by squonk 3 Share this post Link to post Share on other sites
tom2p 2,394 #25 Posted January 19, 2021 (edited) 1 hour ago, D_Mac said: Sad looking back that Dodge had the stones to put the Charger name on those cars. To go from this to that... what were they thinking? smh and Ford did something similar with the Mustang ... started small - grew - then grew too big - and then the Mustang II ... ughhh again - smh Edited January 19, 2021 by tom2p 1 Share this post Link to post Share on other sites
