oliver2-44 11,816 #1 Posted January 6, 2021 (edited) I have several Kohler engines I need to overhaul in the next few years. K91 through K341, possible a Kohler twin, and maybe even a Briggs. How is the best way to test operate them if the tractor is not available to bolt them back into to test run? I did a search and not much comes up for "TEST STAND" if you've made something, even simple/crude I'd appreciate information and a picture of it. If I build something simple, I'm thinking a baseplate, choke and throttle cable, fuel tank, key switch battery holder, wiring to starter, coil, points. maybe a power wire for a future electric fuel pump. Do I need a voltage regulator? if not what do I do with the 2 wires from the stator. Seems like a spare frame, dash and fuel tank support would be a good start. But I don't have a lot of room to store something big. Edited January 6, 2021 by oliver2-44 3 Share this post Link to post Share on other sites
JAinVA 4,638 #3 Posted January 6, 2021 (edited) I have a couple Kohler rebuilds to test and I had several used engines to test as well. I wanted to test the used engines without dealing with nasty fuel systems and sketchy wiring. This stand uses mostly all Wheel Horse parts. An overturned 35 gallon plastic trash can protects the fuel tank,battery and control panel if this is left out in the weather. Edited January 6, 2021 by JAinVA 1 13 Share this post Link to post Share on other sites
Pullstart 71,516 #4 Posted January 6, 2021 If you build a plate to accept a number of engines, possible think of battery hood downs in vehicles. A lip or two on the PTO side and a clamp on the flywheel side... it would make it fairly universal. 4 Share this post Link to post Share on other sites
JAinVA 4,638 #5 Posted January 6, 2021 (edited) If you are dealing with WHs only this stand should handle any air cooled engine ever used in a WH if you have all the adapter pieces. The rocker plate engines and and Onans need the specific mounting hardware. At least you have a use for spare frames and surplus 6" wheels. Edited January 6, 2021 by JAinVA 4 Share this post Link to post Share on other sites
8ntruck 9,381 #6 Posted January 6, 2021 Need to add some sort of a brake so you can test run the engines under load. A bucket item one of my friends had was an Allison V1710 V 12 aircraft engine on a test stand with a big enough brake so he could load it up and make it bark. 2 1 Share this post Link to post Share on other sites
oliver2-44 11,816 #7 Posted January 7, 2021 3 hours ago, JAinVA said: I have a couple Kohler rebuilds to test and I had several used engines to test as well. I wanted to test the used engines without dealing with nasty fuel systems and sketchy wiring. This stand uses mostly all Wheel Horse parts. An overturned 35 gallon plastic trash can protects the fuel tank,battery and control panel if this is left out in the weather. @JAinVA I'm guessing your using those 3 switches in place of a key switch. How/What are they used for? Share this post Link to post Share on other sites
JAinVA 4,638 #8 Posted January 7, 2021 (edited) Looking at the panel from the operators station the switch on the right is a 30 amp momentary on switch for the starter solenoid. The switch on the left is an on of switch to turn the engine on or off and is wired depending on the type of ignition, K vs M. The middle switch is for connection to the R and R or charging circuit. You don' need a switch but it was easier to deal with than a terminal strip. There are some that say you shouldn't run the engine with the R and R not connected but I have had no issues long term with the switch on or off. I used these switches because I need to test engines with different ignition systems,points vs modules. Obviously you have a limited ability to test an engine under load with this rig but at least you know it runs and whether it makes any funny noises. If you need any other info about this just ask. Edited January 7, 2021 by JAinVA 6 Share this post Link to post Share on other sites
ebinmaine 81,138 #9 Posted January 7, 2021 @JAinVA VERY nice.... @oliver2-44 I have a pair of the triangular shaker engine mounts. If you need them they're yours for shipping. 2 Share this post Link to post Share on other sites
JAinVA 4,638 #10 Posted January 7, 2021 (edited) Thanks Eric, that is most generous. I have enough but maybe someone needs some. Just trying to cover any questions that may come up. Somehow a personal message to a member ended up as public, Sure it was my bad! Edited January 7, 2021 by JAinVA 1 1 Share this post Link to post Share on other sites
peter lena 10,107 #11 Posted January 7, 2021 JAinVA, good simple idea , makes sense to me , often when working on a problem , you have to come up with something , and usually that is hiding in plane sight . another part of that is , THE REPITITION OF A PROBLEM , IS YOUR GREATEST OPPORTUNITY, TO MAKE THE PROBEM GO AWAY . pete 1 Share this post Link to post Share on other sites
Ed Kennell 47,809 #12 Posted January 7, 2021 I sold a working test stand to a member at the BIG show several years ago. Was it John? @wallfish Share this post Link to post Share on other sites
oilwell1415 563 #13 Posted January 7, 2021 17 hours ago, JAinVA said: What does the NO switch do? 1 1 Share this post Link to post Share on other sites
pfrederi 21,301 #14 Posted January 7, 2021 22 minutes ago, Ed Kennell said: I sold a working test stand to a member at the BIG show several years ago. Was it John? @wallfish Twas me... 1 1 Share this post Link to post Share on other sites
MikMacMike 494 #15 Posted January 7, 2021 16 hours ago, 8ntruck said: Need to add some sort of a brake so you can test run the engines under load. A bucket item one of my friends had was an Allison V1710 V 12 aircraft engine on a test stand with a big enough brake so he could load it up and make it bark. Thats exactly what I was thinking too. A way to add load, that will give a better indication especially when tuning. I did copy a site showing this guy making basically a dyno for small engines. Ill have to look for it and post it. Share this post Link to post Share on other sites
oilwell1415 563 #16 Posted January 7, 2021 A dyno would not be hard to build. You just need a hydraulic pump that will handle the power and rpm you plan to test and a way to measure the torque on the pump and the rpm of the engine. Use a combination of valves to regulate the flow and pressure of the pump and the load on the engine. 1 Share this post Link to post Share on other sites
pfrederi 21,301 #17 Posted January 7, 2021 MVI_0005.AVI 1 2 Share this post Link to post Share on other sites
Ed Kennell 47,809 #18 Posted January 7, 2021 2 hours ago, pfrederi said: Twas me... Sorry Paul, this 77 year old memory bank is jammed to capacity and some data gets lost. Thanks for posting the video. I thought it might give Jim some ideas. 3 Share this post Link to post Share on other sites
oliver2-44 11,816 #19 Posted January 7, 2021 17 hours ago, JAinVA said: The middle switch is for connection to the R and R or charging circuit. You don' need a switch but it was easier to deal with than a terminal strip. There are some that say you shouldn't run the engine with the R and R not connected but I have had no issues long term with the switch on or off. @JAinVA so do I understand correctly the 2 wires from the stator are wired to this switc. Then if the switch is closed those 2 stator leads are shorted together?this switch Thanks everyone, keep the ideas coming Share this post Link to post Share on other sites
JAinVA 4,638 #20 Posted January 7, 2021 (edited) There are two wires from the stator to the R and R .The R and R has a 3 wire plug. Two of the connectors are connected to the stator and the 3rd contact goes to the + battery terminal. The switch has one terminal connected to the R and R and the other to the positive battery terminal. The switch just makes it easier to make this connection and really isn't needed.. The K series have been in service long enough long that the 3 connector plug may have been eliminated. Just to be clear do not take the stator leads and connect them to each other, ever. You will burn something up with the engine running. What I was referring to about the Rand R being disconnected from battery with the engine running is that some people say it will kill the unit. I have not seen this to be true. Edited January 7, 2021 by JAinVA 2 Share this post Link to post Share on other sites
