417Horse 40 #1 Posted January 3, 2021 I've had my 417 since it was new in mid '86 and have never thought about an add-on oil filter kit for it until now. The engine is a KT17 Series 2. What is the part # for the oil filter kit? Also, where does it attach? If there's anyone with a picture of theirs that would be great. - Thanks Share this post Link to post Share on other sites
953 nut 64,136 #2 Posted January 3, 2021 @19richie66 has posted that information on here, perhaps he will chime in. Share this post Link to post Share on other sites
JCM 10,764 #3 Posted January 3, 2021 6 hours ago, 417Horse said: I've had my 417 since it was new in mid '86 WH's do last a long time. Congrats Share this post Link to post Share on other sites
bds1984 1,506 #4 Posted January 3, 2021 I performed that very upgrade to the Series II in my C175. The part number for the oil filter plate is 52 181 03 and was able to find a few for sale on various websites. They are the same as the Magnums so that should help you find one but also keep in mind that some Series II engines do not have the provisions for an oil filter. This was a very straight forward upgrade, two bolts off, gasket and filter adapter on, two bolts on again, and finally the filter with some oil. I did have to notch out the engine tins slightly only because I used a longer filter. Now if I had to do this upgrade all over again with cost not being an issue, I'd go for the remote filter kit only because the filter is a bit of a pain to access, but once a year isn't going to be a deal breaker for me. There are a few informative posts after mine that will help you out. Share this post Link to post Share on other sites
19richie66 17,809 #5 Posted January 3, 2021 6 hours ago, 953 nut said: @19richie66 has posted that information on here, perhaps he will chime in. Pictures from magnum manual. Bought my stuff of the E auction site. Search “kohler filter adapter”. Engine plate/gasket and filter mount are what you really need. You can make hoses. 1 1 Share this post Link to post Share on other sites
417Horse 40 #6 Posted January 3, 2021 Thanks, bds, for the part # and link. Fortunately, it looks like mine has the plate (crud removed for clarity) with A and B port plugs that could be removed. In the second pic, there are 2 hole fillers in the sheet metal that, in my opinion, could be used to extend the supply and return to the filter if it was mounted remotely. I guess that's what those holes are for? If I add the filter, I will probably mount it remotely - just would have to decide where to mount the filter and bracket. 1 Share this post Link to post Share on other sites
19richie66 17,809 #7 Posted January 3, 2021 Those holes are for the oil lines. 👍 1 Share this post Link to post Share on other sites
417Horse 40 #8 Posted January 3, 2021 Thanks, richie, where would you suggest I mount the filter? It would be nice to mount it somewhere that's not behind the drive belt cover. Share this post Link to post Share on other sites
19richie66 17,809 #9 Posted January 4, 2021 That I have no clue. Not a lot of room. If you made the hoses long enough, I believe there is room below the headlights. Small bracket on the frame would work. Run them out and down below the flywheel towards the front. At least that was my plan. 👍 Share this post Link to post Share on other sites
417Horse 40 #10 Posted January 4, 2021 After looking at the area between the engine sheet metal and the steering column, I think I'll exit the engine sheet metal with the hoses and mount the filter bracket on the frame and have the filter bottom pointing toward the drive belt and guard. I'll just plan on removing the belt guard once a year to change the filter. Thanks again for your help. 1 Share this post Link to post Share on other sites
19richie66 17,809 #11 Posted January 4, 2021 Post pictures when you do. Love to see it done. Share this post Link to post Share on other sites
