seven 202 #1 Posted January 1, 2021 First off happy new year all . ! I'm wondering if anyone has tried adding weight to there plow blade . I thought it would help for scraping the packed down snow off of my driveway? 1 Share this post Link to post Share on other sites
SylvanLakeWH 28,949 #2 Posted January 1, 2021 I just go with the blade. Works great. If you lift it manually like I do, weight would not be your friend... 2 Share this post Link to post Share on other sites
Ed Kennell 42,474 #3 Posted January 1, 2021 You could use a solid lift bar. Then you could apply down pressure as needed by pushing the lift lever. 2 Share this post Link to post Share on other sites
ebinmaine 73,632 #4 Posted January 1, 2021 6 minutes ago, Ed Kennell said: You could use a solid lift bar. Then you could apply down pressure as needed by pushing the lift lever. I'll second that. That what Trina and I do. Works AWESOME. @WVHillbilly520H has mounted weights on his plow. 2 Share this post Link to post Share on other sites
JoeM 8,550 #5 Posted January 1, 2021 try tipping at different angle I run mine in the middle. 3 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #6 Posted January 1, 2021 2 minutes ago, ebinmaine said: I'll second that. That what Trina and I do. Works AWESOME. @WVHillbilly520H has mounted weights on his plow. I kinda haphazardly hung 84# on top of the moldboard which still allowed the trip action to work on some of the more solid high spots. All because I couldn't find (and still can't) the solid lift link in made last spring, but I can find my copy of the blueprints. 3 Share this post Link to post Share on other sites
seven 202 #7 Posted January 1, 2021 36 minutes ago, WVHillbilly520H said: I kinda haphazardly hung 84# on top of the moldboard which still allowed the trip action to work on some of the more solid high spots. All because I couldn't find (and still can't) the solid lift link in made last spring, but I can find my copy of the blueprints. Are they hard too install Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #8 Posted January 1, 2021 3 minutes ago, seven said: Are they hard too install What, the lift link or the weights? Those weights the cut outs just barely fit over the the top edge of the blade and honestly just "hung" them on there just to cut the ice/slush that afternoon. Share this post Link to post Share on other sites
SylvanLakeWH 28,949 #9 Posted January 1, 2021 15 minutes ago, seven said: Are they hard too install No. Just replaces the lift chain with a solid link... 1 Share this post Link to post Share on other sites
cschannuth 3,817 #10 Posted January 1, 2021 1 hour ago, seven said: First off happy new year all . ! I'm wondering if anyone has tried adding weight to there plow blade . I thought it would help for scraping the packed down snow off of my driveway? The rule at my house is nobody drives on the driveway until dad hits it with the blade. Even if that means driving through the yard. Undisturbed snow plows easily and cleanly. Yes, they think I’m nuts but it works. It improves traction too since the concrete is clean behind the blade. 2 3 Share this post Link to post Share on other sites
ebinmaine 73,632 #11 Posted January 1, 2021 1 minute ago, cschannuth said: they think I’m nuts I've heard that about me too. 5 Share this post Link to post Share on other sites
cschannuth 3,817 #12 Posted January 1, 2021 Just now, ebinmaine said: I've heard that about me too. It keeps life fun, Eric. Haha 1 1 1 Share this post Link to post Share on other sites
ebinmaine 73,632 #13 Posted January 1, 2021 9 minutes ago, cschannuth said: It keeps life fun, Eric. Haha I wouldn't be any other way!!! 1 1 Share this post Link to post Share on other sites
seven 202 #14 Posted January 1, 2021 40 minutes ago, SylvanLakeWH said: No. Just replaces the lift chain with a solid link... I don't have a lift chain ? Share this post Link to post Share on other sites
ebinmaine 73,632 #15 Posted January 1, 2021 33 minutes ago, seven said: I don't have a lift chain ? Can you post a pick of what you have? 1 Share this post Link to post Share on other sites
Row Cropper 63 #16 Posted January 1, 2021 My blade is heavy enough as is! I have a 54" blade (made for D series tractors) with a custom made cutting edge, much bigger and heavier than stock. It is 3/8" thick and 4" wide. Also, I have added 2"x2" angle iron reinforcement to the top edge of the blade to stop that inevitable bow that occurs in these wider blades. 1 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #17 Posted January 1, 2021 18 minutes ago, Row Cropper said: to stop that inevitable bow that occurs in these wider blades. My older 42" modded to 50" and then an older 54" I found later, actually never bowwed, but that 56" pictured above was slightly bowwed before I brought it home and I did tweak that lighter gauge steel hanging those weights, but still cheaper than a broken bone on icy pavement. 4 Share this post Link to post Share on other sites
ebinmaine 73,632 #18 Posted January 1, 2021 4 hours ago, Row Cropper said: My blade is heavy enough as is! I have a 54" blade (made for D series tractors) with a custom made cutting edge, much bigger and heavier than stock. It is 3/8" thick and 4" wide. Also, I have added 2"x2" angle iron reinforcement to the top edge of the blade to stop that inevitable bow that occurs in these wider blades. I'd like to see pics of that one. Share this post Link to post Share on other sites
SylvanLakeWH 28,949 #19 Posted January 1, 2021 8 hours ago, seven said: I don't have a lift chain ? If no chain than you must have the solid link already...? As @ebinmaine suggests, can you post a picture or two? 2 Share this post Link to post Share on other sites
wallfish 18,426 #20 Posted January 1, 2021 Like Row Cropper mine has a larger heavier scraper edge plus added some extra weight on the middle of plow the frame. That adds weight to the rear as well as the blade. 654 with manual lift and a solid link so being a shorter plow frame it didn't have as much weight as the longer frames do. It's not too bad to lift but it would be nice to graduate to a hydro tractor since there's quite a bit of up and down given the situation here. Just resisting getting older I guess! LoL 3 Share this post Link to post Share on other sites
Ed Kennell 42,474 #21 Posted January 1, 2021 10 minutes ago, wallfish said: it would be nice to graduate to a hydro tractor since there's quite a bit of up and down given the situation here. Just resisting getting older I guess! LoL Everyone needs a hydro with a hydraulic lift John. It just takes some tough guys longer to admit. 2 4 Share this post Link to post Share on other sites
wallfish 18,426 #22 Posted January 1, 2021 12 minutes ago, Ed Kennell said: It just takes some tough guys longer to admit. Maybe more lazy than tough Ed. There's an extra 418-C out there doing nothing since swapping the 2 stage to a 520-HC, plus a snow/dozer blade or 2 somewhere that were supposed to be a new improved bike build. Or, maybe it's just old men and change don't mix well? I like that little 654 for some reason even though it's been mechanically neglected over the past few years. 4 Share this post Link to post Share on other sites
peter lena 9,341 #23 Posted January 1, 2021 SEVEN , what type of finish is on your driveway ? is it paved ,or dirt /gravel? another thing is what finish is on your blade for turning / rolling snow ? do you silicone or fluid film your blade? for ease and swing of snow . depending on snow depth , I usually center cut it , just to break thru , and see how it moves to the plow. I also always ,back cut my width , so I can have a place to put it . as we know , you might only have one chance to move snow , so make your initial moves with that in mind , pete 2 Share this post Link to post Share on other sites
SylvanLakeWH 28,949 #24 Posted January 1, 2021 2 hours ago, Ed Kennell said: Everyone needs a hydro with a hydraulic lift John. It just takes some tough guys longer to admit. 1 hour ago, wallfish said: Maybe more lazy than tough Ed. There's an extra 418-C out there doing nothing since swapping the 2 stage to a 520-HC, plus a snow/dozer blade or 2 somewhere that were supposed to be a new improved bike build. Or, maybe it's just old men and change don't mix well? I like that little 654 for some reason even though it's been mechanically neglected over the past few years. Age and treachery will always beat youth and skill... or is that old plows always dig the same furrow...? 5 Share this post Link to post Share on other sites
seven 202 #25 Posted January 1, 2021 12 hours ago, ebinmaine said: Can you post a pick of what you have? I'm sorry maybe It does it's a charger 12 hp hydro if I go ahead and put that on it shouldn't damage anything will it? Share this post Link to post Share on other sites
